Results部分的写法
  • 省部重点实验室
    2011/09/11
论文写作和投稿
  • Tags:
    Results段落是客观地讲述实验结果, 一般不加讨论和解释. 写作方法应注 意以下几点:
    1. 用过去语句.
    2. 有的学科只用文字来讲述实验结果, 但大部分学科往往添加 Figure Table来帮助组织数据.
    3. Figure Table 要分别给予序号, 不统一排序.
    4. Table 要有个题目, 题目就写在Table的上方. 注解文字写在Table的下方. Table有时需要照排版,所以草稿中的Table要单独成页. Table 应该附在稿件的后面, 如放在References之后.例如:
    Table 1. Compound A and compound B affinity for human and mouse melanocortin receptor subtypes
    _________________________________________________________________________
    pKi (Ki, nM)
    Receptor Compound A Compound B
    Human MC1 7.39 8.09
    Human MC2 7.21 5.93
    Human MC4a 6.13 6.53
    Mouse MC1 9.02 5.68
    Mouse MC2 7.51 8.03
    Mouse MC4a 5.63 5.89
    __________________________________________________________________________
    The affinity of ligands for melanocortin receptors in HEK cell membrane was measured by inhibition of [125I]-MSH binding, as described in Methods. a, CHO cell line was used.
    5. 也是考虑到排版的需要, 杂志要求草稿中的每个 Figure 要单独占一页, 并且这一页只是Figure 把序号写在Figure页的背面. Figure应该附在 稿件的后面, 如放在References之后. 例如:
    6. Figure的说明(Figure Caption) 要单独写, 不同Figure放在一起,一般可以放在Refences部分之前或之后. 但不同Figure的说明可以 排在一起. Figure说明中只写介绍Figure的文字,不对Figure的结果进行解释.例如上面Figure例子的说明:
    Figure Captions
    Figure 2. Time course of broth volume () and dry cell weight (DCW, ○) in repeated fed-batch fermentation of penicillin G. From 60 h to finish, the working volume was controlled in the range of 72–80 m3, 8.0 m3 of broth was drawn off at a 24 h interval with the mycelium concentration (DCW) kept stable. Data was the average of 16 batches.
    7. 方程式一般给一个序号, 写在方程的右边的括号中, 例如:
    The distance traveled is given by S:
    S = v t (1)
    where v is velocity and t is time.
  • yuduoling
    第1楼2011/09/11
    不错的分享。虽然现在还没有要发表的
