dahua1981
第4楼2012/02/17
Jaz模块化光学传感组件
Jaz是光纤传感领域的革命,Jaz的实力是毋庸置疑的。Jaz超越了传统意义上的光学传感器,其独特的功能和可扩展的平台使它非常适合野外应用、遥测、过程及质量控制。
全新!Jaz现在有LED模块可供选择,这使得开关LED变得简便易行。不必更换整个模块,现在您只需拧动三个螺丝就可以更换LED部件。我们可提供白光LED灯泡或450 nm, 590nm, 640 nm的LED及模块。
dahua1981
第5楼2012/02/17
XR-Series Miniature Fiber Optics Spectrometers
The XR-Series of Extended Range Spectrometers from Ocean Optics are responsive across a wide spectral range, providing you an optical resolution of ~2.0 nm (FWHM) and the convenience of a single, monolithic spectrometer to cover all wavelengths from ~200-1050 nm.The XR Option is now available for our USB2000+, Jaz-EL200 and USB4000 Spectrometers and in custom systems.
Special Grating Extends Wavelength Range
The ability to provide UV-NIR coverage in a single miniature spectrometer has always been a challenge and daisy-chaining multiple USB spectrometers is not always practical or convenient.
Enter the XR-Series. Thanks to its new 500 lines/mm groove density grating, we can now offer our flagship spectrometers with broader spectral coverage and good optical resolution. This grating delivers 850 nm of spectral range and is blazed at 250 nm. Because their optical bench designs are not affected, the USB2000+, Jaz-EL200 and USB4000 experience no trade-off in performance with the new grating.
Preconfigured Broad-Range Options
Our XR gratings are integrated into three familiar spectrometers - each preconfigured for general-purpose UV-NIR applications.
USB2000+XR USB4000-XR Jaz-EL200-XR
Spectrometer Type: USB2000+ advanced electronics spectrometer USB4000 general-purpose spectrometer Jaz modular sensing suite with battery for portability
Grating: Grating #31, 500 lines/mm, blazed at 250 nm Grating #31, 500 lines/mm, blazed at 250 nm Grating #31, 500 lines/mm, blazed at 250 nm
Spectral Range: 200-1050 nm 200-1050 nm 200-1050 nm
Entrance Slit: 25 µm 25 µm 25 µm
Optical Resolution (FWHM): ~1.7-2.1 nm ~1.7-2.0 nm ~1.7 nm
Order-sorting filter: Yes Yes Yes
Detector collection lens: No No Yes
Battery module: No No Yes
Starting at: $3,595 $3,595 $4,190
Frequently Asked Questions
What applications do XR-Series Spectrometers suit?
Solar irradiance measurements, atomic emission line analysis, plasma analysis, process applications and more.
How are you able to provide the extended range option in USB-series and Jaz Spectrometers?
The new diffraction grating provides coverage from 200-1050 nm, but that’s only part of the story. The broad range doesn’t do you much good if you are unable to manage higher-order spectral sorting. So we developed a proprietary order-sorting filter that is applied directly to the detector to eliminate second- and third-order effects.
What spectrometer models are available with the XR-1 grating?
Our standard options will be preconfigured versions of the USB2000+, USB4000 and JAZ-EL-200. We may also be able to accommodate custom configurations in other USB spectrometer models as well. Please contact an Applications Scientist for details.
Why select a 25 µm slit as the standard option in the XR-series Spectrometers?
Selecting a 25 µm slit allows us to maintain good optical resolution across the entire spectral range. Also, unless your application involves low levels of light, the slit width is appropriate.
Why would I choose an XR-series Spectrometer versus the HR4000CG-UV-NIR?
The HR4000CG is an excellent, high-performance spectrometer, especially if your application requires sub-nanometer (<1.0 nm FWHM) optical resolution. For some applications, however, that extra performance – which comes at a higher price -- may not be necessary. With the XR-series Spectrometers, broad-range coverage is not limited to a single option.
dahua1981
第6楼2012/02/17
具有低杂散光和优秀的处理能力的光谱仪 |
物理特性 | |
尺寸: | 149.9 mm x 119.4 mm x 63.5 mm |
重量: | 954 g (2.1 lb) |
探测器 | |
型号: | Sony ILX511B |
检测范围: | 200-1100 nm |
像元: | 2048 |
光谱特性 | |
波长范围: | 360-825 nm |
光学分辨率: | <1.6 nm FWHM over the spectral range |
信噪比: | 250:1 at full signal |
A/D 分辨率: | 16 bits |
暗噪声: | 50 RMS counts; 300 counts peak to peak |
动态范围: | 2x108 (system); 1300:1 (single acquisition) |
积分时间: | 1 ms - 20 s |
杂散光: | 0.03% SRPR @ 400 nm |
线性校正: | >99.8% |
资格证书: |
线性校正: | >99.8% |
资格证书: | CE Mark, RoHS |
dahua1981
第7楼2012/02/17
光纤氧气传感探头配件
![]() | 光纤氧气传感器是结合光谱仪的化学传感器,用于溶解氧和气态氧浓度的光谱分析系统。 光纤氧气传感器采用模块化设计。用户选购时,先选择传感器镀膜配方,然后选择不同类型的光纤探头,传感器镀膜将被应用所选择光纤探头上。我们根据你的选择构建完整的系统。所有系统构件分别收费。 |
以下几种探头是成品,其它的按用户要求定制:
AL300是一种500 微米 OD(300 微米 中心直径) 铝制光纤探测器,用于需要高空间分辨的应用。
18G 是一种300 微米光纤包覆在一个18号不锈钢针探测器。
FOXY-21G 是一种300 微米光纤包覆在一个21号不锈钢针探测器。
"OD光纤探测器,用于直接置换1/8" OD O2 电极。
FOXY-T1000 是一种6.35 mm OD光纤探测器,用于工艺环境和高压环境。
FOXY-T1000-RTD 是一种6.35-mm OD 光纤探测器,内含RTD,用于工艺环境。FOXY-T1000 RTD仅能与USB-LS-450联合使用。
我们在FOXY探测器上使用硅橡胶保护涂层以改进抗化学性,排斥周围光线和消除折射率影响。如果你在液体中或涉及从气态到液态的变化的情况使用,由于散射效应能够使传感器丢失校正数据,所以我们推荐一种保护层。保护层是免费的。
dahua1981
第8楼2012/02/17
光纤pH值传感器
光纤pH传感器系统包括一个与固定比色指示剂染色材料相连接的探针、一个光源、一个光谱仪和一个OOI传感器软件。用户也可以使用自己的指示剂材料,也可以从我们的透光和反射光薄膜的产品系列中选择适用的材料。校准包括高pH值和低pH值样品的光谱记录,和至少一个pH值标准,比如NIST可追踪标准。
透射和反射pH值薄膜
透射薄膜用于干净、透明的样品,薄膜包括一个纤维素板,外包亲水聚合物,内置指示剂染色材料。反射薄膜用于混浊液或吸收样品。
薄膜的性能
当薄膜被浸入水中,薄膜颜色会随时间慢慢褪去,所以必须更换薄膜。薄膜的响应速度很慢(数量级为分钟级别),并且受到离子进入材料的扩散速度的限制。通过增加搅拌速度,增化离子和增加温度的方法,可以增加响应速度,而不会影响pH值的测量。薄膜适合几乎所有的水性样品环境,包括某些溶剂。
TP300型探针
TP300型紫外-可见光探针采用一种具有化学惰性的PEEK聚合物材料,在光路的端口(RT-PH)上放置透射薄膜。光通过光纤和薄膜照射到反射镜上;然后反射回来,再次通过薄膜到达一个接收光纤,回到光谱仪。样品可以自由地在薄膜的两面流动。通过使用RTP-2-10(2-10mm可调)透射探针,TP300型紫外-可见光探针可以用于常规的透射测量。
项目 规格
光纤类型 (2)纤芯直径300µm (1根照明光纤,1根读取光纤)
外层直径 3.175 mm
长度 探针107.9mm,光纤2m
光学材料 熔融石英
内部材料 金属铝
压力 100 psi
路径长 与RT-PH尖端共长16mm
外部材料 光纤外包装PVC,套管PEEK聚合物
连接器 SMA 905
操作温度 在PEEK套管下高达220℃
RF200型探针
RF200型紫外-可见光反射薄膜探针包括一个6+1的光纤束,外层是内直径为6.35mm的化学惰性物质托朗。探针尖端可以旋入探针腔体,内置直径3.17mm到4.76mm的反射指示剂材料。6个光纤与光源接触,中间的光纤与光谱仪连接。样品只能从一侧与传感材料接触。
pH值传感用的透射指示剂染色薄膜
项目 薄膜类型
pH值范围
颜色变化
F-PR 苯酚红 6.5~8.5 黄色-紫色
F-CR 甲酚红 8.0~10.0 橙色-紫色
F-MCP m-甲酚紫 8.5~10.5 黄色-紫色
F-TB 百里酚蓝 9.0~12.0 黄色-紫色
F-BY 亮黄 7.0~9.0 黄色-红色/紫色
F-xxx 透明薄膜(未染色) 参照物 未定义
FILM-300 透射薄膜样品装
pH值传感用的反射指示剂染色薄膜
项目 薄膜类型
pH值范围
颜色变化
FNY-PR 苯酚红尼龙 8.0~10.0 橙色-紫色
FR-CR 甲酚红 8.5~10.5 黄色-紫色
FR-MCP m-甲酚紫 9.0~12.0 黄色-紫色
FR-TB 百里酚蓝 9.0~12.0 黄色-紫色
FR-BY 亮黄 7.0~9.0 黄色-红色/紫色
FILM 反射光薄膜样品装
禁止转售
在此确认的商品不得出现下列情况:如全部或部份的、用于商业出售或出租、转售给借用者、购买者或受让人,除非购买者持有当前有效的执照、配额或销售代表协议,并在协议中明确允许此类的商品转让行为。如果您有兴趣得到这样的许可执照,请与我们的销售部门联系。
pH值测量参考文献
Spectrophotometric Determination of Freshwater pH Using Bromocresol Purple and Phenol Red. Author: Yao, Wensheng; Byrne, Robert H. Source: Environmental Science and Technology v. 35 no6 (Mar. 15, 2001) p. 1197-201
Spectrophotometric Determination of Seawater pH Using Phenol Red. Author: Robert-Baldo, Gillian L.; Morris, Michael J.; Byrne, Robert H. Source: Analytical Chemistry v. 57 (Nov. 1985) p. 2564-77
dahua1981
第9楼2012/02/17
拉曼光谱仪探头
![]() | 我们提供多种拉曼光谱仪的光纤探头,每一种探头都具有完全滤掉瑞利线的功能,能够很好的收集信号,并具有紧凑、耐用的探头设计。不同的探头具有不同的激励波长,可以适用于实验室、工业生产和环境监测等方面的应用。我们的RIP系列探头来之于我们的合作伙伴InPhotonics公司。 以下探头均与海洋光学公司的拉曼光谱仪的配置相兼容。 我们还有 RAM-PR-S 探头,此探头可以单独订购也可作为R-3000拉曼系统中的组件一起订购。 |
PRB型探头只可选择532nm、633nm和783nm的激励波长,激光滤波106。其它各型探头可选择514nm、532nm、670nm、785nm和830nm的激励波长,激光滤波108。
