【序号】:1 【作者】:Chakrawarti, P.B., Chakrawarti, M., Maini, P., 【题名】:Chemical equilibrium studies on some bivalent metal chelates ofcephalexin. 【期刊】:J.. Ind. Chem. Soc 【年、卷、期、起止页码】:2000,77, 85-87 【链接网址】
【序号】:2 【作者】:Moratal, J.M., Borras, J., Donaire, A., Martinez, M., 【题名】:Coordinating properties of the cephalexine antibiotic 【期刊】:Inorg.Chim. Acta 【年、卷、期、起止页码】:1989,162, 113-119 【链接网址】
【序号】:3 【作者】:Orabi, A. S. 【题名】: Physicochemical properties of ampicillin and amoxicillin as biologically active ligands with some alkali earth, transition metal, and lanthanide ions in aqueous and mixed solvents at 20, 30, and 40 degrees C 【期刊】:Journal of Solution Chemistry 【年、卷、期、起止页码】:2005,34,1,95-111 【链接网址】
【序号】:4 【作者】:Zayed, M. A. Abdallah, S. M. 【题名】: Synthesis and structure investigation of the antibiotic amoxicillin complexes of d-block elements 【期刊】:Spectrochimica Acta Part a-Molecular and Biomolecular Spectroscopy 【年、卷、期、起止页码】:2005,61,9,2231-2238 【链接网址】
【序号】:1 【作者】:Naz, NarjisIqbal, Muhammad Zafar 【题名】:Synthesis, Spectroscopic and Biological Studies of Transition Metal Complexes of Novel Schiff Bases Derived from Amoxicillin and Sugars 【期刊】:Journal of the Chemical Society of Pakistan 【年、卷、期、起止页码】:2009,31,6,440-446 【链接网址】
