dahua1981
第2楼2012/04/01
Up to 950 ºC - Immune to EMI and Microwave
The OptoTemp 2000 was designed for reliable operation in the harshest chemical and electrical environments. This fiber optic thermometer is unaffected by microwave/RF radiation and plasma and can measure temperatures up to 950 ºC.
The OptoTemp 2000 features patented technology for a monolithic single-crystal temperature probe that eliminates the need for unreliable mechanical coupling. It measures temperature using the information derived from fluorescence decay.
Benefits
Immune to EMI, RF and microwave
Operates up to 950 ºC
Precise and reliable
Inert probe
Applications
Microwave/RF heating
Chemical processing
Molten metal measurements
Plasma processing
Semiconductor processing
OptoTemp 2000 Controller Specifications
Channels: Up to 4
Temperature range: 10 ºC to 950 ºC
Response time: 250 ms
Precision: +/- 1.0 ºC RMS over 8 samples
Accuracy: +/- 2.0 ºC
Power requirement: 90-260 VAC, 50-60 Hz
Power consumption: 5W @ 7.5 VDC
Output port: RS-232
Display: Back lighted LED
OptoTemp 2000 Probe Specifications
FLEX SUPER ULTRA
Temperature range: 10 ºC to 150 ºC 10 ºC to 400 ºC 10 ºC to 950 ºC
Connector type: ST ST SMA
Overall diameter: 2 mm 3 mm 3 cm*
Active probe length: 15 cm** 15 cm** 15 cm**
Protective sheath material PEEK Ceramic Ceramic
Item Code: OPTOTEMP-2000-FLEX OPTOTEMP-2000-SUPER OPTOTEMP-200-Ultra
Your Price: $2050 $2350 $2750
* A low thermal mass version with exposed 0.2 mm tip is also available
** Longer or shorter length available on custom probes
容百川
第9楼2012/04/01
翻译一下更好!不过这上面提到的光纤探头(=光纤温度传感器器吧?)长度具体没说
