tutm
第9楼2012/10/03
英国华莱士仪器公司(Wallace Instruments),有台仪器应该就是做这个的,“Compression Stress Relaxometer Mk III - C11”,只是可能要他们配上ASTM的测试头,楼主可以看下
http://www.wallaceinstruments.co.uk/products/compression/wallace-compression-stress-relaxometer-mk-iii-c11
夹具
General: | |||
Overall Dimensions: | 380 wide x 365 deep x 665 mm high | ||
Weight of Instrument: | 55 kg net. | ||
Electricity Supply: | 110/240 volts AC. 60/50 Hz. 1 ph. 24 watts max. | ||
Air Supply: | Standard Model 300 kPa. 4.5L Free air per minute. or 1.5L Free air per cycle. | ||
Maximum Jig Height: | 120 mm. | ||
Minimum Jig Height: | 30 mm. | ||
Weight of Jig: | 1830 g. | ||
Load Ranges: | |||
Standard: | 0 - 2.2 kN | 0 - 225 kgf | 0 - 500 lbf |
Available: | 0 - 220 N | 0 - 22 kgf | 0 - 50 lbf |
0 - 1.1 kN | 0 - 112kgf | 0 - 250 lbf | |
Operating Speeds: | |||
Fast approach: | 2 mm/sec. maximum. | ||
Minumum rate of load increase on Standard Model: | 0.25 N/sec. | ||
祖国的小草
第10楼2012/10/08
非常感谢 我研究一下
General: | |||
Load Ranges: | |||
