对于豁免铅的 小部件有可溶的要求 ,对于非小部件的,都有总含量要求,除非是被豁免的,个人认为!
376618968(376618968) 发表:“In addition, materials now or in future listed in the mostcurrent revision of 16 CFR 1500.88 or 16 CFR 1500.91 as exempt from testing and certification requirements are excludedfrom this requirement for the purposes of determining compliance.” 来自F963
1.如上所述,总铅含量属于豁免范围的,那溶出铅含量还需要测试吗?
"This section specifies requirements and testmethods for total lead and the migration of antimony, arsenic,lead, barium, cadmium, chromium, mercury and selenium in accessible substrate materials. Accessible glass, metal and ceramic toys or parts of toys, that are small parts (that is, thatfit into the test fixture specified at 16 CFR 1501 (see Fig. 3), are also subject to this requirement." 来自F963
2.如上所述,非小部件金属,玻璃和陶瓷不需要做溶出测试,那需不需要测试总铅测试呢?
