zyl3367898 2013/05/06
http://www.sfncc.org.cn/Z_Show.asp?ArticleID=2289 http://db.foodmate.net/additive/read_additivexz.php?pid=705希望对你有所帮助。
lololol 2013/05/11
[b][font=Arial, Helvetica, Tahoma, sans-serif][size=16px][color=#666666]Tocopherol Succinate[/font][/size][/color][font=Arial, Helvetica, Tahoma, sans-serif][size=16px][color=#666666][back=#ffffe1] [/font][/size][/color][/back][/b] [b]Predicted data is generated using the ACD/Labs’ ACD/PhysChem Suite, for more information see their [url=http://www.acdlabs.com/products/pc_admet/physchem/physchemsuite/]website[/url].[/b] [table=100%][tr][td][url=http://www.acdlabs.com/logp]ACD/[b]LogP[/b][/url]:[/td][td]10.159[/td][td]# of [b]Rule of 5[/b]Violations:[/td][td]2[/td][/tr][tr][td][url=http://www.acdlabs.com/logd]ACD/[b]LogD[/b] (pH 5.5)[/url]:[/td][td]8.98[/td][td][url=http://www.acdlabs.com/logd]ACD/[b]LogD[/b] (pH 7.4)[/url]:[/td][td]7.19[/td][/tr][tr][td]ACD/BCF (pH 5.5):[/td][td]1000000.00[/td][td]ACD/BCF (pH 7.4):[/td][td]33247.36[/td][/tr][tr][td]ACD/KOC (pH 5.5):[/td][td]533830.80[/td][td]ACD/KOC (pH 7.4):[/td][td]8597.75[/td][/tr][tr][td]#H bond acceptors:[/td][td]5[/td][td]#H bond donors:[/td][td]1[/td][/tr][tr][td]#Freely Rotating Bonds:[/td][td]17[/td][td]Polar Surface Area:[/td][td]72.83 Å[sup]2[/sup][/td][/tr][tr][td]Index of Refraction:[/td][td]1.498[/td][td]Molar Refractivity:[/td][td]155.355 cm[sup]3[/sup][/td][/tr][tr][td]Molar Volume:[/td][td]529.618 cm[sup]3[/sup][/td][td]Polarizability:[/td][td]61.587 10[sup]-24[/sup]cm[sup]3[/sup][/td][/tr][tr][td]Surface Tension:[/td][td]37.5320014953613 dyne/cm[/td][td][b]Density[/b]:[/td][td]1.002 g/cm[sup]3[/sup][/td][/tr][tr][td][b]Flash Point[/b]:[/td][td]186.97 °C[/td][td]Enthalpy of Vaporization:[/td][td]97.392 kJ/mol[/td][/tr][tr][td][b]Boiling Point[/b]:[/td][td]625.837 °C at 760 mmHg[/td][td][b]Vapour Pressure[/b]:[/td][td]0 mmHg at 25°C[/td][/tr][/table] 这是个计算值,参考一下吧
lololol
第9楼2013/05/11
Predicted data is generated using the ACD/Labs’ ACD/PhysChem Suite, for more information see their website.
ACD/LogP: | 10.159 | # of Rule of 5Violations: | 2 |
ACD/LogD (pH 5.5): | 8.98 | ACD/LogD (pH 7.4): | 7.19 |
ACD/BCF (pH 5.5): | 1000000.00 | ACD/BCF (pH 7.4): | 33247.36 |
ACD/KOC (pH 5.5): | 533830.80 | ACD/KOC (pH 7.4): | 8597.75 |
#H bond acceptors: | 5 | #H bond donors: | 1 |
#Freely Rotating Bonds: | 17 | Polar Surface Area: | 72.83 Å2 |
Index of Refraction: | 1.498 | Molar Refractivity: | 155.355 cm3 |
Molar Volume: | 529.618 cm3 | Polarizability: | 61.587 10-24cm3 |
Surface Tension: | 37.5320014953613 dyne/cm | Density: | 1.002 g/cm3 |
Flash Point: | 186.97 °C | Enthalpy of Vaporization: | 97.392 kJ/mol |
Boiling Point: | 625.837 °C at 760 mmHg | Vapour Pressure: | 0 mmHg at 25°C |
