色谱柱: | Diamonsil C18 250 X 4.6 mm,5 μm (Cat#:99903) Diamonsil C18(2)250 X 4.6 mm,5 μm (Cat#:99603) Platisil ODS 250 X 4.6 mm,5 μm (Cat#:99503) Spursil C18 250 X 4.6 mm,5 μm (Cat#:82006) |
流动相: | 乙腈:0.1%磷酸二氢钠(用磷酸调pH 值至3.0±0.5)=50:50 |
流速: | 1 mL/min |
柱温: | 30 ℃ |
检测器: | 228 nm |
进样量: | 10 μL |
