CPSIA Section 108 最近是不是有更新?
RoHS/WEEE指令
  • CPSIA Section 108 最近是不是有更新?
  • 期盼奇迹的孩子
    第1楼2017/09/07
    是的,天祥网上摘的~
    CPSC Exempts Seven Plastics from CPSIA Section 108 Phthalate Content Testing Requirements
    On August 30, 2017, the U.S. Consumer Product Safety Commission (CPSC) published the final rule, 16 CFR 1308 - Prohibition of Children's Toys and Child Care Articles Containing Specified Phthalates: Determinations Regarding Certain Plastics. This rule exempts seven plastics with specified additives from the third-party testing requirement of toys and childcare articles under the Section 108 phthalate content requirements of the Consumer Product Safety Improvement Act of 2008 (CPSIA).
    Following is the list of plastics along with the specified additives:
    1. Polypropylene (PP), with any of the following additives:
    a.The plasticizers polybutenes, dioctyl sebacate, isooctyl tallate, paraffinic, naphthenic, and mineral plasticizing oils, and polyol;
    b.Unrecovered catalysts;
    c.Fillers;
    d.Primary and secondary antioxidants;
    e.Neutralizing agents;
    f.Antistatic agents;
    g.Slip agents;
    h.Metal deactivators;
    i.Quenchers;
    j.UV stabilizers;
    k.Nucleating agents;
    l.Flame retardants;
    m.Blowing or foaming agents;
    n.Antiblocking agents;
    o.Lubricants; or
    p.Colorants.
    2. Polyethylene (PE), with any of the following additives:
    a.The plasticizers glyceryl tribenzoate, polyethylene glycol, sunflower oil, paraffin wax, paraffin oil, mineral oil, glycerin, EPDM rubber, and EVA polymer;
    b.Initiators;
    c.Promoters;
    d.Unrecovered catalysts;
    e.Fillers;
    g.Flame retardants;
    h.Anti-blocking agents;
    i.Slip agents;
    j.Blowing agents;
    k.Cross-linking agents;
    l.Antioxidants;
    m.Carbon black; or
    n.Colorants.
    3. General purpose polystyrene (GPPS), medium-impact polystyrene (MIPS), high-impact polystyrene (HIPS), and super high-impact polystyrene (SHIPS) with any of the following additives:
    a.Unrecovered catalysts;
    b.Internal lubricants;
    c.Chain transfer/transition agents;
    d.Stabilizers;
    e.Diluents;
    f.Colorants;
    g.Aluminum chloride, ethyl chloride, hydrochloric acid;
    h.Iron oxide, potassium oxide, chromium oxide; or
    i.Bifunctional peroxides.
    4. Acrylonitrile butadiene styrene (ABS), with any of the following additives:
    a.The plasticizers hydrocarbon processing oil, triphenyl phosphate, resorcinol bis(diphenyl phosphate), oligomeric phosphate, long chain fatty acid esters and aromatic sulfonamide;
    b.Stabilizers;
    c.Lubricants;
    d.Antioxidants;
    e.Molecular weight regulators;
    f.Initiators/unrecovered catalysts;
    g.Activators;
    h.Emulsifiers; or
    i.Colorants.
    What does this mean?
    The exemption relieves toys and child care article manufacturers using the specified plastics with additives that are listed above from the CPSIA Section 108 phthalate content testing requirement at a CPSC-accepted third-party lab.
    However, it should be noted that children's toys and child care articles must still comply with the substantive phthalates content limits in section 108 of the CPSIA, regardless of any relief from third-party testing requirements. Additionally, the manufacturer must issue a certificate (Children's Product Certificate) stating that the product complies with the CPSC requirements.
    When will this go in effect?
    This rule will become effective September 29, 2017, 30 days from the publication of the final rule in the Federal Register.
    The final rule can be reviewed at: https://www.gpo.gov/fdsys/pkg/FR-2017-08-30/pdf/2017-18387.pdf
  • 该帖子已被版主-chengxiaojun加2积分,加2经验;加分理由:参与讨论
  • 期盼奇迹的孩子
    第2楼2017/09/07
    CPSC豁免CPSIA中七种塑料的强制第三方邻苯二甲酸酯测试
    2017年8月30日,美国消费品安全委员会(CPSC)在联邦公报上发布了最终规则《禁止儿童玩具和儿童护理用品含有特定邻苯二甲酸酯:某些塑料的测定》(16 CFR 1308)。本规则豁免了儿童玩具和儿童护理用品中含有特定添加剂的七种塑料的第三方邻苯二甲酸酯检测要求。
    以下是含有特定添加剂的塑料列表:
    1. 聚丙烯(PP),含以下添加剂:
    a.增塑剂:聚丁烯,癸二酸二辛酯,树脂酸异辛酯,链烷烃,环烷烃,矿物增塑油和多元醇;
    b.未还原的催化剂;
    c.填料;
    d.初级和次级抗氧化剂;
    e.中和剂;
    f.防静电剂;
    g.滑爽剂;
    h.金属钝化剂;
    i.淬灭剂;
    j.紫外线稳定剂;
    k.成核剂;
    l.阻燃剂;
    m.吹制或发泡剂;
    n.防粘剂;
    o.润滑油;
    p.着色剂。
    2. 聚乙烯 (PE),含以下添加剂:
    a.增塑剂:三苯甲酸甘油酯,聚乙二醇,葵花油,石蜡,石蜡油,矿物油,甘油,EPDM橡胶和EVA聚合物;
    b.引发剂;
    c.促进剂;
    d.未还原的催化剂;
    e.填料;
    f.抗静电剂;
    g.阻燃剂;
    h.防粘剂;
    i.滑爽剂;
    j.发泡剂;
    k.交联剂;
    l.抗氧化剂;
    m.炭黑;
    n.着色剂。
    3. 通用聚苯乙烯(GPPS),中等强度聚苯乙烯(MIPS),高抗冲聚苯乙烯(HIPS), 和超高抗冲聚苯乙烯(SHIPS), 含以下添加剂:
    a.未还原的催化剂;
    b.内部润滑剂;
    c.链转移剂;
    d.稳定剂;
    e.稀释剂;
    f.着色剂;
    g.氯化铝,氯乙烷,盐酸;
    h.氧化铁,氧化钾,氧化铬;
    i.双功能过氧化物;
    4. 丙烯腈-丁二烯-苯乙烯(ABS),含以下添加剂:
    a.增塑剂:烃加工油,磷酸三苯酯,间苯二酚双(磷酸二苯酯),低聚磷酸酯,长链脂肪酸酯和芳香族磺酰胺;
    b.稳定剂;
    c.润滑油;
    d.抗氧化剂;
    e.分子量调节剂;
    f.引发剂/未还原的催化剂;
    g.活化剂;
    h.乳化剂;
    i.着色剂。
    这意味着什么?
    儿童玩具和儿童护理用品制造商在使用上述含有特定添加剂的塑料时,豁免免除了需在CPSC认可的第三方实验室进行CPSIA第108节的邻苯二甲酸酯测试。
    但是,需要注意的是,即使第三方检测要求被免除,儿童玩具和儿童护理用品仍必须满足CPSIA第108节中对邻苯二甲酸酯的含量限制。此外,制造商必须出具证书(儿童产品符合性证书)以证明产品满足CPSC要求。
    什么时候会生效呢?
    这一规则将于2017年9月29日生效,从联邦公报的最终规定发布的30天内。
    最终规则可见于:https://www.gpo.gov/fdsys/pkg/FR-2017-08-30/pdf/2017-18387.pdf
  • ian.cheng
    第3楼2017/09/07
    期盼奇迹的孩子(v2709113) 发表:CPSC豁免CPSIA中七种塑料的强制第三方邻苯二甲酸酯测试
    以下是含有特定添加剂的塑料列表:
    1. 聚丙烯(PP),含以下添加剂:
    b.未还原的催化剂;
    c.填料;
    d.初级和次级抗氧化剂;
    e.中和剂;
    f.防静电剂;
    g.滑爽剂;
    h.金属钝化剂;
    i.淬灭剂;
    j.紫外线稳定剂;
    k.成核剂;
    l.阻燃剂;
    m.吹制或发泡剂;
    n.防粘剂;
    o.润滑油;
    p.着色剂。
    2. 聚乙烯 (PE),含以下添加剂:
    b.引发剂;
    c.促进剂;
    d.未还原的催化剂;
    e.填料;
    f.抗静电剂;
    g.阻燃剂;
    h.防粘剂;
    i.滑爽剂;
    j.发泡剂;
    k.交联剂;
    l.抗氧化剂;
    m.炭黑;
    n.着色剂。
    a.未还原的催化剂;
    b.内部润滑剂;
    c.链转移剂;
    d.稳定剂;
    e.稀释剂;
    f.着色剂;
    g.氯化铝,氯乙烷,盐酸;
    h.氧化铁,氧化钾,氧化铬;
    i.双功能过氧化物;
    b.稳定剂;
    c.润滑油;
    d.抗氧化剂;
    e.分子量调节剂;
    f.引发剂/未还原的催化剂;
    g.活化剂;
    h.乳化剂;
    i.着色剂。
    这意味着什么?
    什么时候会生效呢?
    豁免的意思是不是说这些胶料可以不用测试108节中的 邻苯了
  • wangqing1
    第4楼2018/01/17
    不好意思啊,点错了
    期盼奇迹的孩子(v2709113)发表:CPSC豁免CPSIA中七种塑料的强制第三方邻苯二甲酸酯测试
    以下是含有特定添加剂的塑料列表:
    1. 聚丙烯(PP),含以下添加剂:
    b.未还原的催化剂;
    c.填料;
    d.初级和次级抗氧化剂;
    e.中和剂;
    f.防静电剂;
    g.滑爽剂;
    h.金属钝化剂;
    i.淬灭剂;
    j.紫外线稳定剂;
    k.成核剂;
    l.阻燃剂;
    m.吹制或发泡剂;
    n.防粘剂;
    o.润滑油;
    p.着色剂。
    2. 聚乙烯 (PE),含以下添加剂:
    b.引发剂;
    c.促进剂;
    d.未还原的催化剂;
    e.填料;
    f.抗静电剂;
    g.阻燃剂;
    h.防粘剂;
    i.滑爽剂;
    j.发泡剂;
    k.交联剂;
    l.抗氧化剂;
    m.炭黑;
    n.着色剂。
    a.未还原的催化剂;
    b.内部润滑剂;
    c.链转移剂;
    d.稳定剂;
    e.稀释剂;
    f.着色剂;
    g.氯化铝,氯乙烷,盐酸;
    h.氧化铁,氧化钾,氧化铬;
    i.双功能过氧化物;
    b.稳定剂;
    c.润滑油;
    d.抗氧化剂;
    e.分子量调节剂;
    f.引发剂/未还原的催化剂;
    g.活化剂;
    h.乳化剂;
    i.着色剂。
    这意味着什么?
    什么时候会生效呢?
