liuxilin1215
第2楼2018/02/12
ISO 13003-2003 Fibre-reinforced plastics — Determination of fatigue properties under cyclic loading conditions
ISO 12817-2013 Fibre-reinforced plastic composites — Determination of open-hole compression strength
ISO 14129-1997 Fibre-reinforced plastic composites 一 Determination of the in-plane shear stressl shear strain response, including the in-plane shear modulus and strength, by the ±45° tension test method
