【讨论】老师帮忙看看这图片表示什么意思
透射电镜(TEM)
  • 后面这个曲线能说明什么问题?
    文献中是这样说的
    A rocking curve together with the corresponding diffraction
    pattern are shown in Figure 4b. Examination of different
    rocking curves of the {10–14} reflections yielded an average
    mosaic spread of 3.9 ± 1.1 degrees. Interestingly, the half width
    of the {11-10} reflections is significantly smaller (1.7 ± 0.3),
    indicating an anisotropic mosaic spread of the single crystalline
    assembly. In contrast to the X-ray diffraction patterns of
    the pseudo-octahedral macrocrystals electron diffraction spots
    of individual crystallites (Fig. 3) show no broadening. Thus
    the broadening of the X-ray diffraction peaks is due to slight
    variations in the orientation of the crystallites, probably due to
    the incorporation of organic network material between individual
    crystallites.
  • ywngs
    第1楼2007/01/11
    能把这篇文章贴出来么?
  • bingshui
    第2楼2007/01/12
    好的
    谢谢老师
    帮忙看看
    文章挺长的
  • ywngs
    第3楼2007/01/13
    期待版主验证一下!
  • bingshui
    第4楼2007/01/18
    为什么斑竹不通过啊的?等了这么长时间,是我发的东西有问题吗?
  • 天黑请闭眼
    第5楼2007/01/18
    你压根没发上来!在编辑帖子或者发贴模式下:
    传文件需要输入附件名称(随便取)然后点击浏览,选中文件(最好压缩成rar文件),然后点击上传。等正文里有了反应(刚开始没有办法正常显示,需要验证),再点击确定提交即可。
    bingshui 发表:为什么斑竹不通过啊的?等了这么长时间,是我发的东西有问题吗?
