求助XRD光谱
测试版面
  • 黑色的是氧化石墨烯的X射线衍射光谱,红线是石墨烯/纳米金杂合体的x射线衍射光谱,(111)表示什么?针对此图的描述如下:
    The high-resolution TEM image showed that the lattice spacing of the Au-NPs was about 2.34 Å, corresponding to the distance of (111) lattice spacing of the Au crystal, and the X-ray diffraction (XRD) pattern further suggested the crystalline nature of Au-NPs grown on the graphene surface(如下图)
