kite503
第1楼2020/01/07
Ask your teacher to calculate the bond length.
Usually, IR bands can explain the interactions and prove the components. It is quite difficult to calculate the bond length, because the peak position is largely effected by the state of your sample and interaction of near molecules. Of course, different resolutions of IR spectrum will show different location of the same peak.
