熊猫宝宝
第11楼2008/07/27
carrier box 运载盒
carrier gas 载体气
carrier plate 输送板
carrier rack 可携式老化测试接线架
carrier size 承载齿轮尺寸
carrier tape 输送带
carry ladle 盛桶,浇汁
carry over 挟带
cartridge brass 弹筒(壳)黄铜
cascade 串级
case case carbon 表皮,表层含碳量
case depth 硬化深度
case hardening 表面硬化
case-hardened glass[ 表面]硬化玻璃
case-hardening steel 表面碳他钢
cased glass 套色玻璃
casing 套色
cassette cleaning equipment 输送匣盒洗涤装置
cassette transfer 晶圆匣盒传送机
cassette-to-cassette handling 匣盒间转运处理
cassette/magazine 晶圆匣盒/晶圆收纳盒
cassetteless wet cleaning equipmet 无盒湿式洗涤装置
cassiterite 锡石(矿)
SnO2 cast 铸造
cast alloy 铸性合金,铸造合金
cast dies 铸造钢模
cast iron 铸铁
cast iron pipe 铸铁管
cast refractory 筹造耐火材料
cast steel 铸钢
cast structure 铸造组织
cast-weld assembly 泰接铸件
castable refractory 铸斑铸坑耐火物
castibility 铸造性,可铸性
casting 铸造,铸件
casting crack 铸裂
casting defect 铸疵
casting design 铸件设计
casting fin 飞边
casting fluidity 铸造流动性
casting lug 铸件凸出块
casting manipulations 铸造作业
casting oil 铸造油
casting rate 浇铸速率
casting sand 铸砂
casting skin 铸件表皮
casting spot 电泳
casting steel 钢铸件
casting strain 铸造应变
casting stress 铸造应力
casting temperature 浇铸温度
casting time 浇铸时间
castomatic process 自动铸造方法
cat's eye 猫眼泡
Catalan furnace 卡特郎冶炉(原始熟铁鼓风冶炉)
catalyst 催化剂,触媒
catalysts 含钴触媒
catalyzed spraying 触媒喷涂
cataphoresis 悬链拱
catastrophic oxidation 高温剧烈氧化
category 范畴类别
catenary arch 教堂窗饰玻璃
cathedral glass 猫眼泡
cathod 阴极
cathod filament 阴极丝
cathod sputtering 阴极溅射
cathode coupling 阴极耦合
cathode/target electrode 阴极/靶电极
cathodic control 阴极控制
cathodic polarization 阴极极化
cathodic protection 阴极防蚀法,阴极防蚀
cathodic protection current 阴极保护电流
cathodic reaction 阴极反应
cathodic vacuum etching 阴极真空蚀刻(腐蚀)
cathodic-corrosion 阴极腐蚀
cathodouminescence 阴极萤光
cation 阳离子
cauliflower top 花菜头钢锭
caulking 膏紧,填隙
causal metal 高索金属(沃斯田灰铸铁)
caustic alkali 荷性硷
caustic embrittlement 荷性脆他
caviation 涡穴作用
caviation damage 涡穴损伤
caviation erosion 涡穴冲蚀,孔蚀
cavity 孔穴
cavity wall 空心墙
cazin 镉锌焊料(钢缆用焊料18%Zn 其余为Cd)
CCT (continuous-cooling transformation) diagramCCT 图(连续冷却变态图)
CD uniformityCD 均质性
CE (carbon equivalent) meter CE 计(碳当量测定计)
celadon 青瓷
celeste blue 天蓝
celite 铁铝酸四钙
cell 功能电路胞
cell based IC 以功能电路胞为基础之
IC cell compiler 功能电路胞编辑器
cell constant 电池常数
cell distortion 晶胞歪扭
cell furnace 箱炉
cell potential 电池电位
cellobiose 纤维霸醣
cellophane 赛珞凡
cellular structure 细胞状组织
celluloid 赛璐珞
cellulose 纤维素
celsian 钡长石
Celsius 摄氏温度刻度
cement carbide 黏结碳化物
cement clinker 水泥烧块,水泥熟料
cement efficiency 水泥效率
cement gel 水泥胶滞体
cement gun 水泥枪
cement kiln hood 水泥窑罩
cement molding1. 水泥模法 2水泥塑造
cement mortar 水泥曼料
cement paste 水泥糊
cement rock 水泥岩
cement sand 水泥砂
cement spaceratio 水泥容积比
cement steel 渗碳钢
cement, latex 生胶结着剂
cement-aggregate reaction 水泥—骨材反应
cement-water ratio 灰水比
cementation1. 渗碳法,渗入法 2.淀置法(如:在稀硫酸铜中以铁置换铜)
cementation index 胶结指数
cementing agent 胶合剂
cementite 雪明碳体
center block 车尺部方块
center brick 中心砖
center of symmetry 对称中心
center upset forging 中部锻粗锻件
center upsets 中部锻粗件
center upsetting 中部锻粗法
centering 对准中心,定心
centigrade 摄氏温度
centrifugal blast 离心喷光
centrifugal blower 离心鼓辈机
centrifugal cast iron pipe 离心铸铁管
centrifugal casting 离心铸造法
centrifugal drying equipment 离心乾燥设备
centrifugal spray cleaning equipment 离心喷雾洗涤装置
Ceralumin 西拉铝明(含1-3%Cu,1-2%si,0.3-1.5%Fe
ceramal 瓷金(与cermet 同)
ceramic 陶瓷
ceramic casting 陶模铸造
ceramic filter 陶质泸器
ceramic nozzle 陶质喷嘴
ceramic processing 陶瓷制程
Ceramic Resonator 陶瓷谐振器
ceramic ware 陶瓷器
ceramic whiteware 白陶瓷器
ceramic-to-metal seal 陶瓷金属封接
ceramics 窑业;窑业;窑瓷
ceramics turbo 陶瓷涡轮
cereal binder 壳粉黏结剂
cermet 陶金
cermet (ceramic)瓷金
Cerrobase alloy 史罗合金(一种易泰合金)
Cerrobend 史罗本德低熔点合金(熔点为70。C 含50%Bi,27%Pb,13%Sn,10%Cd )
cerromatrix 史罗基低熔点合金(熔点为227-102。C)
cerrotru 史罗储低熔点合金(熔点为138.5。C 含58%Bi,42%Sn 之共合晶合金)
Ceylon plumbago 锡兰石墨
chafing 擦粗
chafing-fatigue 摩擦疲劳
chain hydrometer 链式比重计
chain iron 链条铁
chain reaction 连锁反应
chain steel 链条用钢
chain-type furnace 链式炉
chainotte 烧粘土
chalcedony 石髓
chalk 白呈
chamber cleaning 反应室清除
chamber controller 恒温槽控制器
chamber dryer 室式乾燥器
chamber kiln 室窑
chamber oven 室炉
chamber vessel 小室容器
chamfer grinding machine 去角取面研磨机
chamois 倒角,去角
chamotte 烧粉,烧粘土
chamotte brick 烧粉砖,耐火砖
chamotte sand 烧粉砂
champleve enamel ware 无线珐琅;明线釉
change of phase 相变化
change of state 状态变化
channel 糟型料
channeling 空道(频道)
chaplet 砂心撑
characteristic curve of hardening 淬火特性曲线
characteristic radiation 特性辐射
characteristic x-ray 特性
x 射线
characterization 特徵化、特性记述
charcoal 木炭
charcoal iron 木炭铁
charcoal pig iron 木炭生铁
charcoal powder 木炭粉
charcoal process 木炭法(制造熟铁法之一)
charge1. 加料2.电荷
charge carrier 电载体
charge conjugation 电荷共轭
charge density 电荷密度
charge sensitivity 电荷灵敏度
熊猫宝宝
第12楼2008/07/27
charge size crucible capacity 最大坩埚装填容量
charge symmetry 电荷对称性
charge up 充电,使绝缘物带电
charged meson 带电介子
charged particle 带电粒子
charger 充电器
charging 充电
charging door 加料门
charging hopper 加料斗
charging machine 加料机
Charpy impact test 夏比冲击试验
Charpy impact value 夏比冲击值
Charpy test 夏比试验
chase unit 凹槽单元
chatelier-type microscope 倒置式显微镜
chatter1. 颤震(机器) 2.波纹(加工面)
checkers 格子砖
checking 裂痕(涂料)
checking, heat 热裂
cheek flask 中间砂箱
chelating agent added cleaning chemical 添加螫合剂洗条药品
chemical activity 化学活性
chemical affinity 化学亲和力
chemical attack 化学侵蚀
chemical beam epitaxial growth system 化学分子束磊晶生长系统
chemical bonded refractory 化学胶结耐火物
chemical cabinet 化学药剂储存室
chemical cleaning 化学清洁法
chemical coating 化学保护层
chemical contouring 化学铣边
chemical effect 化学效应
chemical equivalent 化学当量
chemical filter 化学吸附过滤器
chemical finishing 化学饰面
chemical hygrometer 化学湿度计
chemical lead 硬铅
chemical luminescence chemiluminescence 化学发光
chemical mechanical poslishing 化学机械磨
chemical milling 化学铣制
chemical plating 化学电镀
chemical polishing 化学抛光
chemical porcelain 化学用瓷
chemical reaction 化学反应
chemical regenertor 药液再生器
chemical stoneware 化学用焙器
chemical storage tank 药液储存槽
chemical treatment 化学处理
chemical vapor deposition system 化学汽相沉积系统
chemical-flux cutting 药剂切割
chemically amplified resist 化学放大型抗蚀剂
chemically precipitate metal powder 化学沈面金属粉末
chemicals feeding facilities 药品注入设施
chert 燧石
cherty limestone 矽质石灰质
chest knife 刮刀
chill crack 淬裂
chill mark 淬纹
chill plate 急冷板
chilled glass 强化玻璃
china 瓷器
china clay 瓷土
china process 成瓷法
china stone 陶石
Chinese blueMohammedan blue Chinese motif 中国式所意
chip 片纹;切屑
chip alignment 晶片姿势调整
chip burn-in 晶片老化测试
chip on board 基板晶片焊接技术/
COB chip on glass 玻璃基板晶片焊接术/
COG chip size package 晶方尺寸构装
chip/die 晶片/小晶片
chipping 剥离
chlorination equipment 加氯设备
Choline-based cleaning solution 柯林基体洗涤液
chopper mechanism 断续器机构
chrarged body 带电体
chroma signal measurement 彩色信号测试
chrome green 铬绿
chrome ore 铬矿
chrome refractory 铬质耐火物
chrome spinel 铬尖晶石
chrome yellow 铬黄
chrome-alumina pink 铬铝红
chrome-magnesite refractory 铬镁耐火物
chrome-tin pink 铬锡红
chrome-zircon pink 铬钴红
chromite 铬铁矿
chromophore 发色团
chrysoberyl 全绿宝石
chrystile 纤维蛇纹石;温石棉
chuck cleaning mechanism 夹盘洗条机构
chunk glass 光学玻璃块
cinnabar 辰砂
circle brick 扇形砖
circle cutting 圆形切割
circuit circuit simulator 电路模拟器
circular table 圆盘;旋转盘
clamp kiln 野烧窑
clashing color 斗彩
clay 黏土
clay building brick 建筑黏土砖
clay shredder 切泥机
clay slate 黏板岩
clay substance 黏土物质
clean draft chamber 洁净通风室
cleaner 清洁剂;清洁器
cleaning after CMPCMP 後之清洗
cleaning equipment 洗涤装置
cleaning evaluation 洗条评价
cleaning tact timing 洗条流程时间
clear glaze 清釉
cleats 瓷夹板
cleavage1 晶劈面2劈开
Client Server System 顾客伺服器系统
clinker 熟料;烧块
clinkering zone 烧成带
clinoenstatite 斜顽辉石
clock 时钟脉冲
clock tree synthesis 时钟树合成
clockwise 顺时针旋转
cloisonne enamelware 景泰蓝
closed pot 有盖熔罐
closed-circuit grinding 闭路研磨
closet suite 卫生瓷组
club shape 马球球杆形
cluster 簇团
cluster tool 组合设备工具
co-simulation 协同模拟器
co-sputtering system 共同溅镀系统
CO2 bubbler 二氧化碳起泡器
coagulants feeding equipment 凝聚剂注入装置
coagulo -sedimentation tank 凝结沉淀槽
coal tars 煤膏
coal-tar epoxy coating 煤膏环氧涂膜
coal-tar monomers 煤膏单体
coal-tar pitch 煤膏沥青
coarse grinding 粗磨
coated abrasives 砂纸
coated fabrics 漆布
coated paper 铜版纸
coated products 涂膜产品
熊猫宝宝
第13楼2008/07/27
coater 涂敷机
coating and extrusion 涂布及压挤
coating and lamination 涂布及层合
coating methods 涂布方法
coating tanks 涂布囤
coatings 涂膜
coaxial cylindrical plasma enhanced CVD system 同轴圆筒型等离子体增强型
CVD 系统
coaxial lighting 同照射照明
cobalt 钴
cobalt aluminates 铝酸钴
cobalt blue 钴蓝
cobalt catalysts 钴触媒
cobalt compounds 钴化物
cobalt metabororates 偏硼酸钴
cobalt naphthenate 环烷酸钴
cobalt soaps 钴皂
cobalt-60 钴60
cobalt-60 irradiation 钴60照射
cobaltic ion 钴离子
cobaltite 辉砷钴矿
cobwebbing 蛛网
cocatalyst 辅触媒
cocatalyst-catalyst ratios 辅正触媒比
cocatalysts 辅触媒
coconut oil 椰子油
cocoon coatings 茧衣
code, definition 界说规范
codes 规范
coefficient of elasticity 弹性系数
coefficient of friction 摩擦系数
coefficient of scatter 散射系数
coefficient of thermal expansion 热胀系数
coefficient of variation 变异系数
coefficient of viscosity 黏度系数
coenzymes 辅梅
coherent growth nuclei 谐长核
cohesion 内聚力
cohesion energy 内聚能
cohesive set 内聚组
cohesive-energy density 聚能密度
coil building 盘停砌成
coil coating 线圈涂膜
coiled polyelectrolytes 旋弯聚电解物
coils 旋弯
coin mark 硬币特徵标痕
coincidence effect 符合效应
coining 刻造
coir fibers 椰纤维
coke oven 炼焦炉
cold crushing strength 常温抗碎强度
cold crystallization 冷结晶
cold cure 冷硬化
cold drawing 冷抽
cold forming 冷成
cold heading 冷作头
cold hobbing 冷切压
cold molding 冷模塑
cold moldings 冷模
cold pressing 冷压
cold repair 冷修
cold rubber 低温硫化橡胶
cold wall 冷壁
cold welding 冷焊
cold working 冷加工,冷作,常温加工
cold-forming studies 冷成研究
cold-fromed structures 冷成构成
cold-soda pulps 冷钠成纸浆
cold-tube process 冷管方法
cold-water-swelling starches 冷水膨胀淀粉
coldframes 冷框
colemanite 硬硼酸路钙石
collage painting 图案拼贴油漆
collagen 生胶质
collagen fibril 生胶质原纤维
collagen-fibers 生胶质纤维
collagens, invertebrate 无脊椎动物生胶
collagens, vertebrate 脊椎动物生胶
collagraphy 拼贴广告术
collar 轴;环;圈
collaring 缩颈
collet heater 吸具加热器
collet holder 具有吸具之保持工具
colligative properties 总括性
collimate sputtering 准直溅镀
collimators 准直仪
collodion 胶棉
collodion, denitrated 脱硝胶棉
colloid 胶体
colloid mill 胶体磨机
colloid stabilizer 胶体安定剂
colloidal 胶态
colloidal evaporation process 胶态蒸发方法
colloidal particles 胶粒
colloidal properties 胶体特性
colloidal suspensions 胶态悬浮液
colloidal systems 胶态物系
colloids 胶体
colloids, irreversible 不可逆胶体
colloids, macromolecular 巨分子胶体
colloids, reversible 可逆胶体
colophony 松香
color 颜色
color bleeding 脱色
color change 变色
color comparisons 比色
color concentrates 色精
color control 颜色控制
color dispersion 颜色散布
color filter test 彩色滤光器试验
color glass condensate 色玻璃凝聚
color index 比色指数
color linearity test 彩色再现性试验;彩色线条试验
color matching 配色
color measurement 量色法
color monitoring, continuous 连续色素侦测
color reactions 显色反应
color stability 颜色安定度
color standars 颜色标准
color tests 颜色试验
colorant 着色剂
colorant-mixture 着色剂配合
colorants 着色剂
coloration 上色
colored glaze 色釉
colored polymers 着色聚体
colorfastness 不褪色性
colorimeter 比色计
coloring 上色
column alignment 行列调准
column chromatographic fractionation 柱式移差分划
column chromatography 柱色移差术
column control 行列控制;栏控制
column performance 柱效能
columnar structure 柱状组织
comb rack 栅架
comb-shaped polymers 梳状聚体
combination grain 混合粒度
combination termination 化合终止
combing 精硫
combustion 燃烧
combustion chamber 燃烧室
comet appearance 慧星状模样
comlex catalysts 复体触媒
commercial fibers 商品纤维
commercial grade 商品级
commercial lignins 商品木质
commercial polyblends 商品搀合体
commercial rayons 商品嫘萦
comminution 粉碎
common frankincense 蓝丹
commons 粗砖
communications cable 通讯电缆
compaction 压实
compactor 压缩器
comparative-cost studies 比较成本研究
comparator 比较器
compatibility 互适性
compeb mill 属仓磨
complex coacervate 复体凝聚层
complex copolymerization 复体并聚
complex instruction set computer(CISC) 复杂指令集电脑
complex propagation constant 复体传播定值
complexes 复体
compleximetric titations 复体滴定
complexing agent 复合剂
compliance 柔量
component1 成分2组件
composite efficiency 复合效率
composite pigment 复合颜料
composite propellants 复合推进剂
熊猫宝宝
第14楼2008/07/27
composites 复合体
composition board 复合板
composition brick[ 普通]建筑砖
compound glass 复合玻璃
compound mill 复合磨
compound rolls 复[式]辊[轧]机
compounding 配合
compounding extruder 配合挤压剂
compounding of rubber 橡胶配合
compreg 胶压木材
compressibility 压缩性
compression 压缩
compression and transfer molding 压送模塑法
compression and transfer molds 压送模
compression mold 压(缩)模(型)
compression molding 压缩模制
compression ratio 压缩比
compression set 压缩组件
compression sintering 压缩烧结
compression test 压绚试验(从机)
compression tests 抗压试验
compression zone 压缩带
compression-crimped yarns 压送纱
compressive strength 压缩强度
compressive test 压缩试验
Compton scattering 康卜吞散射
computer 电脑
Computer aided engineering(CAE) 电脑辅助工程
Computer aided testing(CAT) 电脑辅助测试
computer memory units 电脑记忆单位
computer-aided design(CAD) 电脑辅助设计
computerization 电脑(计算机)操作
computerized color matching 电脑配色
computers 电脑
concentration distribution 浓度分布
concentration gradient distribution 浓坡分布
concentration method 浓度方法
concentric-cylinder devices 同心圆筒装置
concentric-cylinder rheometer 同心圆筒流变计
concrete 混凝土
concrete aggregate 混凝土骨材
concrete block 混凝土块
Concurrent design 同时进行设计
condensation mechanism 缩合历程,(凝缩机构)
condensation polymerization condensation polymers 缩合聚体
condensation resins 缩合树脂
conditioning 调整
conditioning time (adhesion)调理时间(黏附)
conditioning zone 调整带
conductance 导电度
conduction bands 导电带
conduction heating 导电加热
conductive glass 导电玻璃
conductive polymers 导电聚体
conductivity 导电性
conductivity, electrical conductor 导电体
cone 示温锥
cone and plate rheometer 锥钣流变计
cone crusher 锥[形][轧]碎机
cone equivalent 示温锥当值
cone wheel 锥形京轮
cone-screen test 锥筛试验
cones 锥形体
confectionery 糖果厂
configuration 阵列
configurational infrared bands 显示阵列的红外线带
configurational interaction 阵列的交互作用
configurations 立体基阵
conformal coating conformation 扭键基阵
conformational infrared bands 扭键体红外线带
Congo copal 刚果玷巴脂
Congo red 刚果红
congruent compound 合熔化合物
congruent melting 合熔
conical ball mill 锥形球磨[机]
conical refiners 锥形精制机
coniferyl alcohol 松柏醇
conjugated diene polymers 共轭双烯聚体
conjugated dienes 共轭双烯
conjugated polyene sequences 共轭聚烯序次
conjugated polymers 共轭聚体
conjugated proteins 缀合蛋白质
connecting canal 连接槽
consistometer 稠度计
constant kK 定值
constant temperature thermode/constant heat tool 恒温热压接合工具
constant-deformation tests 定变形试验
constant-load tests 定载试验
constant-rate drying 定速乾燥
constant-rate period 定速阶段
constitution 构造
constitutive equations 构造等式
construction applications 建筑用途
construction materials 建筑物料
construction paper and board 建筑纸板
contact adhesives 接触黏合剂
contact angle 接触角
contact cements 接触胶合剂
contact check 接触确认
contact lenses 接触镜片
contact molding 接触模铸
contact probe 接触用探针
contact-proximity aligner 密接-近接对准曝光器
containers 容哭
containers, blow-molded 吹模容哭
contaminants 污垢物
contamination level 污染量
Conti abrader 康贴磨蚀机
continuous failure check function 连续故障自我诊断功能
continuous kiln 连绩窑
continuous-pour process 连续浇铸法
continuously charged CZ method 连续补充CZ 法
contraflow 反流
control panel 控制板
control-air source equipment 控制空气源设备
controllability 可控制性
conventional molding die 惯用型成型铸模
conversion 转化[作用]
conversion kits 转换成套工具
converter 史炉
coolagen, reconstituted 重组生胶
coolant apparatus 冷却剂装置
coolant separator 冷郤剂分离器
cooler 冷却器
cooling arch 冷却拱(玻)
cooling stage 冷却阶段载物台
cooling zone 冷却带
coordination number 配位值;配位数;共位值
熊猫宝宝
第15楼2008/07/27
cope 上[砂]箱
copolymer copper enamel 铜胎珐琅
copper head 铜斑
copper red 铜红
copy chamfering 去角取面复制
copy grinding 研磨复制
copy master 复制母型
coral red 珊瑚红
cord 筋痕
core 核心;磁心
correlation 相互关系,相关
correlative double sampling 相关双重取样法
corresponding burn-in system of factory automation 工厂自动化对应之老化测试系统
corrosion 腐蚀
corrugated sheet glass 波形玻璃
corundum 刚石
cost of ownership 经营成本
coulombic force counterclockwise 反时针旋转
course 层
covalent bond 共价结合键,共价键
cove skirting 内转角砖
cover coa 面涂
cover glass 盖玻璃
covering power 遮盖力
coxial magnetron sputtering system 同轴磁控管溅镀系统
CPU coreCPU 核心
crack 裂痕
cracking off 火切
crackle 碎纹
crackle ware 碎纹瓷
cradle frame 摇篮活动框架
crank 垫饼;撑架
crash forming 碰撞成形
cratering 弹坑状,陨石坑状
crawling 釉缩
crazing 惊纹;细纹
creep 潜变,潜伸
creep feed grinding 低速输送研磨
crimping 卷边
crimping glass 癸绉玻璃
cristobalite 白矽石
critical dimension loss 临界尺寸损失
critical path 关键路径
critical resolved shear stress critical speed 临界速率
crizzle 细纹(玻)
crooked wire/wire sway 呈弯曲之引线/引线倾斜
cross contamination 交互污染
cross coupling 交叉偶合
cross feed device 交叉给料装置
cross slide table 交叉滑动台
cross talk 串音,串影
cross-bend test 横向弯曲试验
cross-fired furnace 横焰炉
crosslinked polymer crowding barrow 手推车
crown 窑顶
crown brick 拱题砖;窑顶砖
crown glass 晚玻璃
crucible lift mechanism 坩埚升降机构
crucible lift rata 坩埚升降速率
crucible lift travel 坩埚升降行程
crucible rotation rate 坩埚旋转速率
crucible shaft 坩埚轴
crushing rolls 辊碎机
crushing strength 抗碎强度
cryolite 冰晶石
crystal 晶体;结晶
crystal glass 水晶玻璃
crystal habit 晶体习性
crystal lattice 晶格;晶体点阵
crystal lift mechanism 拉晶升降机构
crystal lographic axis 晶轴
crystal orientation 晶体方位;晶体取向
crystal originated particle 结晶起因之微粒
crystal rotation rate 结晶旋转速率
crystal structure 晶体组织
crystal surface 结晶表面;晶面
crystal system 结晶系;晶系
crystalline crystalline glaze 结晶釉
crystallization 结晶作用
cull 残留树脂
cullet 玻璃屑
cup gun 杯式喷枪
cup insulator 杯形绝缘体
cup shaped diamond grinding wheel 杯型钻石研磨机
cup wheel 杯形磨轮
cupel 烤钵
cupola 熔铁炉
curb bend 外转角砖
cure curie point 居里点
Curie temperature 居里温度
curing 养护
curing compoundcuring agent curing oven 硬化炉/烤箱
curing time 硬化时间
curling 卷曲
current source(force)voltage measurement 施加电流只电压测试
curtain arch 帘拱
curtain wall 帘墙
custom IC 客户定制
IC customer owned tool 客户自备工具
cut glass 雕玻璃
cut off 切开;切断
cutter 切工;切刀;雕工
cutting tools 割削工具
cutting-off table 切坯台
CW (continuous wave) laser annealer 连续波雷射退火处理机
cyanite 蓝晶石
cycle based simulator 周期期底模拟器
cycle time 循环时间
cycling test 温度循环试验
cyclone 旋风器
Czochralski method 切克劳斯基法
熊猫宝宝
第16楼2008/07/27
D-nickelD 镍(含4-5%Mn 之镍合金)
dacite 石英安山石
Dacron polyester fibers 达克隆聚脂纤维
Daetwyler-Schiltknecht abrasion machine 戴许磨耗机
dairy bronze 奶罐青铜(20%Ni, 8%Zn, 4%Sn, 其余为Cu)
dairy products 乳酪产品
dam bar 堵住杆,纬
dam block 水闸方块
Damage line[ 疲劳]损害比例
Damage ratio 达马新法(熔接高低碳钢而形成多层材料装饰品之一种方法)
damascene 金属镶嵌法
Damascening 大马森合金(含10%
Sn 之青铜)
Damaxine alloy 制振能
Dammar 达玛脂
Dammar gum 达玛胶
Damp proofing and permeability reducing agent 防水剂
damper 风门
Damping capacity damping test 制振族验
dancer roller 上下跳动滚轮
Dandelion metal 登德耐易金属(含18%Sb,10%Sn, 其余为Pb 之轴承合金)
dapple 不匀
Darcy's law 达西定律
dark condition 黑暗条件
Dark field 暗视野
dark field microscopy 暗场显微法
dart-drop testing 双轴弯曲试验
Darwin's concept 达尔文观念
Dash etching 达斯蚀刻
dash's neck 达斯(缩细)颈部
dashpots 缓冲筒
data interpretation 数据阐明
data level source 数据位阶电源
data logging memory 资料记录记忆器
data logging/data log 数据记录/数据记录表
data memory 数据记忆器
data scramble function 数据打散功能
data topological function 数据拓扑功能
datolite 矽钙硼石
Daubing[ 耐火砂]自补,涂抹
day tank 日量熔槽
Daylight 净距(压机)
daylight fastness 色耐阳光度
Dc diode sputtering system 直流二极管溅镀系统
DC measurement 直流测量单元
DC parameter test system 直流参数测试系统
DC parametric test/DC testDC 参数试验/直流测试
DC test 直流测试
De Broglie law 德波格里定律(现代电子绕射技术基础)
de-airing 除气法
de-aluminification 脱铝作用(铝青铜)
de-emulsification 解乳化
de-enamelling 去珐琅
De-Lavaued process 德拉瓦[离心铸管]法
de-skew 相位或时间偏差之补偿
deacetylated chitin 去乙醯卖质
Deactivation 反活性化
deactivators 去活化剂
Dead clay 僵土
dead plate 静板
Dead soft cast iron 极软铸铁
Dead soft steel 极软钢
dead spots 僻区
dead weight type/natural weight type 净重式
dead-burned 僵烧
Dead-burned dolomite 全烧白云石
Dead-burned magnesite 全烧镁石
dead-end polymerization 终端聚合
Deaeration 脱气
Deags 脱气
debiteuse 浮标砖
debranching enzymes 脱支梅
debugger 除错程式
Deburring 去满边
Debye characteristic temperature 戴比特性温度
Debye circles 狄拜圈
Debye equation 狄拜等式
Debye's concept 狄拜观念
Debye-Huckel approximation 狄胡近似法
Debye-Huckel theory 狄胡理论
Debye-Scherrer camera 戴薛氏照相机
Debye-Scherrer diagrams 狄拜图谱
decaborane 十硼十四氢
decaborane polymers 十硼十四氢聚体
decal 印花
decalcomania 印花
Decalescence 减辉
Decalescence point 减辉点
decanedioic acid 癸二酸
Decanning 去套管
decanoic acid 癸酸
decarboxylation 去羧基作用
Decarburization 脱碳
Decarburized depth 脱碳深度
Decarburized layer 脱碳层
Decarburized structure 脱碳组织
decay 衮变
decay time 衮变时间
deceleration mode 减速模式
dechlorination equipment 除氯设备
decibel 分贝
Decoloration 消色
decolorizer1 去色剂 2 脱色剂
decomposition 分解
decompression section 去压部位
decor paper 装饰纸
decor sheet 装饰板
decorating 装饰
decorating kiln 红炉;彩烧窑
Decorative coating 装饰护膜
Decorative concrete 装饰混凝土
decorative effects 装饰效应
decorative laminates 装饰层板
decorative ribbon 装饰带条
Decoring 砂心清除
decorvtive backcoat 回布装饰
decyl acrylate 丙烯酸癸酯
decyl alcohol (1-
decanol)癸醇
Deep eltch 深蚀
Deep forming 深成形
Deep hardening steel 深硬化钢
deep level 深能阶
deep level transient spectroscopy 深能阶暂态光谱学
deep submicron design 深态次微米设计
Deep-drawing steel 深冲[用]钢
deep-submergence system 深浸系统
deep-submergence vehicles 深浸媒体
deerskins 廘皮
熊猫宝宝
第17楼2008/07/27
dee[-pile fabrics 长毛织物
defasher 塑模溢料残渣去除装置
defect 瑕疵,缺陷
defect lattice 缺陷格子
defect semiconductor 瑕疵半导体
defect structure 缺陷组织
defects 缺点
Deflagration 爆燃(燃烧)
deflashing 去毛边
deflocculant 反凝剂
deflocculants 反凝剂
deflocculation 反凝
defoaming agents 去泡剂
deformability 变形度
deformable particles 可变形粒子
Deformation 变形
Deformation band 变形带
deformation eutectic 变形共熔物
deformation mechanisms 变形历程
deformation properties 变形性质
deformation rate 变形率
Deformation structure 变形组织
deformation temperature 变形温度
Deformation texture 变形织构
Deformation twin 变形双晶
Deformation velocity 变形速度
deformation width of wire 变形线宽
deformation, reversible 可逆变形
deformation-stress dependencies 随应力变形
deformation-time dependencies 随时间变形
deformations, infinitesimal 极微变形
deformed ball diameter 变形球径
defroster 除霜器,防结冰装置
Degadation 败坏,降级
Degasification 脱气
degassing 放气
Degassing flux 脱气熔剂
Degassing rate 去气率
degating 去浇口
Degaussing 去磁
degermination 去芽
Deghdrogenation 脱氢
degradation 退解
degradation of plastics 塑胶退解
degradation of styrene polymers 苯乙烯聚合物退解
degradation, latent 潜伏退解
degradative processes 退解过程
Degreaser 去油剂
degree of branching 分支度
degree of crosslinking 交连度
degree of crystallinity 结晶度
degree of cure 硬化度
degree of degradation 退解度
Degree of fatique 疲劳程度
Degree of freedom 自由度
degree of hydration 水合度
degree of isomerization 异构度
degree of isotacticity 整排度
degree of orientation 定向度
degree of polymerization 聚合度
Degree of saturation 饱和度
degree of substitution 取代度
Degydration 脱水
Dehardening 减硬
dehydration 脱水
dehydration bake 脱水烘烤
dehydrochlorination 脱氯化氢
dehydrogenated rosin 脱氢松香
dehydrogenation 脱氢
dehydrogenation processes 脱氢法
deionization 去离子作用
deionized water cooling 去离子水冷却
deiron demanganese equipment 除铁除锰装置
delay model 延迟模型
delay time 延迟时间
Delayed elasticity 延迟弹性
Delayed fracture 延迟破断
Delayed queching 延迟火
Delayed transformation 延迟变态
Delayed yield 延迟降伏
delayed-tack adhesives 迟固黏着剂
Deleterious substance 有害物质
delft ware 德弗特陶器
dellusterauts 褪光剂
delta brassδ 黄铜
delta bronzeδ 青铜
Delta ironδ 铁
Delta metalδ 合金
Delta solid solutionδ 固溶体
delustering 褪光
Demagnetizer 去磁器
Demagnetizing curve 消磁曲线,去磁曲线
demounting machine/demount station 晶圆卸装机
denaturation 变性
dendrite 树枝状结晶;树状突
Dendritic powder 树枝状粉未
Dendritic segregation 树枝状偏析
dendritic spherulites,fibrous 纤维状桠球
Dendritic structure 树枝状组织
Denier 丹尼值
Denitriding 脱氮
dense1 致密(陶) 2高折射率(玻)
Dense flint 重火石玻璃
Densener 冷铁
Densificatiokn 压紧
Density 密度
density crystallinity 密度结晶
density defect 密度缺点
density measurements 密度测量
density method 密度法
Density ratio 密度比
density-gradient column 密度坡柱
density-gradient sedimentation 密度坡沈积
Density-theoritical 理论密度
Dental gold 牙科用金(含5-12%Ag, 4-10%Cu, 其余为Au 之合金)
dental porcelain 牙用瓷
denuded zone 无缺陷领域
Deoxidation (deoxidization)脱氧,去氧
Deoxidized copper 脱氧铜
Deoxidizer 脱氧剂
Deoxidizing 去氧,脱氧
Deoxidizing agent 脱氧剂
Deoxigenation 脱氧
dependence of life time on current density plot 寿命与电流密度之依存性关系图
dependence of life time on temperature plot 寿命与温度之依存关系图
Dephosphorization 脱磷
Depleted uranium 耗竭铀,耗乏铀
Depolarization 去极化作用
Depolarizer 去极化剂
Deposite attack 沈积侵蚀
Deposite protection 沉积防蚀
Deposition 沉积
deposition chamber 沉积室,蒸镀室
deposition rate 蒸镀速率
depressed die pad 下凹晶片焊垫
Depth of chill 冷硬深度
depth of focus 聚焦深度
Derby[ 金属]圆饼(特指铀金属饼又名biscuit)
Descale 去锈
design automation conference 自动设计学术研讨会
design automation(DA) 设计自动化
design for testability 可测试性程式
design kit 设计套组
design rule check 设计法则查验
Desilverizing 去银
Destructive testing 破坏性试验
Desulphurization 脱硫
Deval abrasion test 戴佛磨损试验
developer 显影机
developer temperature control 显影液温度控制
developing rate 显影速率
developing uniformity 显影均质性
development environment 研发环境
device 装置,元件
device model 装置模型,元件模型
device program 装置程式
device simulator 装置模拟器
device under test 被测试装置
devitrification 失透;反玻化
devitrified glass 失透玻璃
devitrite 失透物
Dew point 露点
Dewaxing 脱蜡
Dewpoint indicator 露点计
Dextrin 糊精
Dezincification 脱锌
DH degassing processDH 去气法
DHP copper DHP 铜
sofg di-vacancies 双空位
dialysis 透析;渗析
Diamagnetic substance 反磁性体
Diamagnetism 反磁性
Diamond 金刚钻,钻石
Diamond cubic 钻石立方
diamond CVD 金钢钻
CVD diamond electrodeposition wire 电解金钢砂沉积线
Diamond lattice 钻石[型]格子
Diamond polishing 钻石[细粉]抛光
diamond pyramid hardnessDPH Diamond pyramid hardness test 钻石[角]
熊猫宝宝
第18楼2008/07/27
Diamond structure 金钢石锯
Diamond waw 锥硬度试验
diamond wheel 金刚石磨轮
diaphram pump 隔膜泵
diaspore 水铝石
Diatomaceous earth 钻石[型]组织
diatomitediatomaceous earth diatomite filter 珪藻土过滤器
dic cavity 型腔,模槽
dicalcium silicate 矽酸二钙
Dichromate treatment 金普(Pr, 59),金女(Nd,60)之通称
dicing 切割
dicing saw network management 切割锯刀网路管理
dicing saw/dicer 切割锯刀/切割机
dickite 二重高岭土
Didymium 麦藻土
Die 模
die alignment 晶片调准
Die block 模
die bonding 晶片接合,晶片焊接
Die bottom 模块
Die cast 铸模
Die cast alloy 压铸
Die casting 压铸合金
Die casting machine 压铸法
die cavity 晶片固定腔
Die clearance 压铸机
Die cushion 模垫(压机)
die dropping rate 晶片掉落率
Die electric 电介质,电介体
Die forging 模锻
Die impression 模型
Die insert 模嵌块
Die layout 模布置
Die life 模寿命
Die lock 模锁
Die lubricant 模具润滑剂
Die making 制模
Die mismatch 模错位
die obnder 晶片接合机
Die opening 模距
die pad/island 晶片焊垫/孤岛
die plate 印刷版,铅版
Die press quenchiong 模压卒火
die pressing 模压
Die proof 验模件
Die quench 夹模卒火
Die seat 模底
Die set 模组
Die setting 装模
Die shank 模柄
die shear strength 晶片抗切强度
die shear tester 晶片切变强度测试机
Die shift 模移量
Die shoe 模托(压机)
Die sinking 刻模
Die sinking machine 刻模机
Die slide 模滑条(压机)
die sorter 晶片分选机
Die space 模面大小
Die steel 模用钢
Die temperature 模温
die tray 晶片托盘
Die upper 上模
Die, cast 下模
Die, composite 组合模
Die, compound 复序模
Die, conterlocked 对锁模
Die, continental 样板模
Die, drop-through 下穿模
Die, finishing 完成模
Die, flat 平模
Die, floating 浮动模
Die, gripper 夹持模
Die, inserted 嵌型模
Die, inverted 倒置模
Die, lower 下模
Die, moving 动模
Die, multiple 多件模
Die, multiple cavity 多内模
Die, multiple-impression 多型模
Die, multiple-part 多件模
Die, plate 样板模
Die, progressive 顺序模
Die, push-through 穿通模
Die, return 返回模
Die, roll 滚筒模
Die, single-covity 单内模
Die, single-impression 单型模
Die, single-operation 单序模
Die, sizing 挤准模
Die, slidikng 滑动模
Die, solid 整体模
Die, split 分开模
Die, stationary 定模
Die, steel-rule 钢条模
Die, subpress 模架模
Die, swage 型锻模
Die, template 样板模
Die, top 上模
Die, transfer 自送连制模
Die, trimming 自边模
die-by-die alignment 晶片间对准
die-by-die leveling 晶片间调平
die-by-die tilting 晶片间倾斜转动
Dielectric 介电
Dielectric constant 介电常数
Dielectric insulator 介电绝缘体
Dielectric strength 介电强度
Differential aeration corrosion 氧差腐蚀
differential DC measurement 差动直流测试
Differential dilation curve 示差膨胀曲线
Differential gear 差速齿轮
Differential heating 差别加热
Differential micrometer 差动分厘卡
differential pressure gauge 差压计
Differential quenching 示差卒火
Differential thermal analysis 示差热分析
Differential thermocouple 示差热电偶
differential thermogravimetry 示差热重量法
Diffraction 绕射
Diffraction (x-ray)绕射线(X 射线)
Diffractometer 绕射仪
diffused wafer 经扩散晶圆
Diffusion 扩散
Diffusion activation energy 扩散活化能
Diffusion annealing 扩散退火
Diffusion bonding 扩散接合
Diffusion boundary laver 扩散境界层
Diffusion coating 扩散护膜
Diffusion coefficient 扩散系数
Diffusion coefficient (D)扩散系数
Diffusion constant 扩散常数
Diffusion hardening 扩散硬化
Diffusion hole 扩散孔
Diffusion internal friction 扩散内耗
Diffusion normalizing 扩散正常化
Diffusion process 扩散法
Diffusion pump 扩散帮浦
diffusion sintering 扩散烧结
Diffusion transformation 扩散变态
Diffusion zone 扩散带
Diffusion-controlled precipitation 扩散控制沉
Diffusion-controlled transformation 扩散控制变态(转换)
Diffusionless transformation 无扩散变态
Diffusivity1 扩散性2扩散率
digital (control bonding)
head 数位控制压接头
Dilatation curve 膨胀曲线
Dilatometer 热膨胀仪
Dimension1 尺寸2因次3维,度
Dimension change 尺寸变化
Dimensional instability 尺寸不稳定性
Dimensional stability 尺寸安定性
Dimensional tolerance 尺寸公差
Dimethylglyoxime test 定性试验
dimming test 耐朦试验
dimple 凹坑,表面微凹
DIN (Deutsche Industrie Normen)德国工业标准
dinas brick 矽砖
Dings-Crockett separator 丁一式分离机
diode parallel plate plasma enhanced CVD system 二极管平行板等离子增强型
CVD 系统
diode sputtering system 二极管溅系统
Diopside 透辉石
Diorite 闪长岩
dip brazing 热浸硬焊
dip developer 浸渍式显影机
Dip transfer 浸送(熔接时金属由电极至熔池)
Dipcoat 浸涂,浸覆
Dipole 偶极,双极
Dipole materials 偶极性材料
dipping 浸渍
Direct arc furnace 直接电弧炉
Direct arc heating 直接电弧加热
Direct chill casting 直接冷铸
direct displacement type cleaning equipment 直接置换式洗涤装置
Direct extrusion 顺挤,直接挤制
direct firing1 直接喷燃(泥) 2敞烧法(陶)
Direct heat method 直接加热法
direct index function 直接索引功能
Direct interchange diffusion 直接交换扩散
direct pick up 直接拾取
Direct quench aging 直接卒火时效
Direct redrawing 顺向再拉延
Direct reduction process 直接还原法
Direct stress 正交应力
direct teemingtop pouring Direct tempering 直接回火
Direct transformation 直接变态
direct writing 直接描画
direct-arc furnace 直热电弧炉
Directional properties 方向性
Directional solidification 方向性凝固
Directionality 方向性
熊猫宝宝
第19楼2008/07/27
Dirt 渣
Dirt inclusion 夹灰
Dirt trap 集灰阱
Disappearing filament pyrometer 隐丝[光学]高温计
disappearing-filament pyrometer 隐丝光测高温计
Discaloy 迪卡洛(耐热钢之一种)
Discard 去锭头
Discontinuous eutectic 不连续共晶
Discontinuous precipitaion 不连续析出
Discontinuousdiscontinuous yielding 不规则降伏
discrete component test system 离散元件测试系统
dishing 凹状扭曲研磨
Dishing press 碟压机
disintegration 崩解
disintegration index 散解指数
disintegrator 散解机
disk feeder 盘饲机
Dislocation 差排
Dislocation climb 差排爬登
Dislocation density 差排密度
dislocation free crystal 无位错结晶
Dislocation line 差排线
Dislocation locking 差排楔梢
Dislocation strength 差排强度
Disordered solid solution 无规律固溶体
Disordering 非规律化
dispenser 配料机,点胶机
dispenser nozzle 配料机喷嘴
Dispering agent 播散剂
Dispersed shrinkage 分散缩孔(铸疵)
Dispersion 播散
Dispersion effect 播散效应
Dispersion hardening 播散硬化
Dispersion strengthening 播散强化
Dispersion type fuel 分散型[核子]燃料
Dispersoid 散播物
Displacement energy 移位能
Displacement spike 原子移位区
Disposable carbide tip 弃换式碳化物刀尖块
Disruptive strength 破裂强度
Dissimilar metal corrosion 异极[金属]腐蚀
dissociation pressure 解离压力
Distance hardness 端距硬度
Distillate 馏出物
Distilled water 蒸馏水
distortion 歪变,畸变
distributed processing 分散式处理
Distribution coefficient 分配系数
diver method 潜取[样]法
Divergent lens 发散透镜
division wall 隔墙
Divorced cementite 分离雪明碳铁
Divorced pearlite 粒状波来铁
DNS 碳金目钢
dobbin 转盘乾燥器
doctor blade 刮刀片
document glass 文件玻璃
dog house 进料口;浮标砖入口
doloma 白云石灰
Dolomite 白云石
Dolomite brick 白云石砖
domain 域
Domain wall 磁[区]壁
Dome 窥窿(圆题室)
dome brick 圆顶砖
dome jig 圆顶夹具
dome plug 炉顶塞砖
donor annihilation 消除氧气施体
Donor impurity 施素不纯物
donor killer 氧气施体杀手
Donor level 授素准位
Dopant 掺杂剂
Doping 掺杂
doping defect 掺缺缺陷
doping system 掺杂系统
Doppelduro process 杜氏火焰硬化法
Dore bullion 多尔锭(金银锭)
Dore metal 多尔金属(金银合金)
Dore silver 多尔银(含少量金)
Dorr agitator 杜尔搅动器
Dorr mill 道尔磨机
Dorr thickener 杜尔浓稠槽
Dorrco filter 杜柯过滤机
Dose 剂量
dot logging 点纪录
Dotwelding 点熔接
Double annealing 双重退火
Double carbide 复碳化物
Double contraction 双重收缩
double crucible method 双重坩埚法
double draining 再排浆(搪瓷)
Double equilibrium state 复平衡状态
Double extra deuse flint 双超重火石玻璃
Double normalizing 霸重正常化
Double oriented silicon iron sheet 双向性矽钢片
double pass preheater 双程预热器
Double quenching 双重卒火
double side lapping machine 双面磨光机
double side polishing machine 双面抛光机
double sided aligner 基板上下两面对准曝光器
Double skin 夹层(锻铸件外层瑕疵)
double telecentric lens 双重远心透镜
Double tetrahedral unit 双四面体单元
Double thermochemical treatment 双重热化常处理
Double-arch hammer 双拱鎚
Double-end upset forging 双端锻粗
Double-end upsets 双端锻粗件
Double-end upsetting 双端锻粗法
double-faceware 双面搪瓷器
Double-frame hammer 双架鎚
double-frit glaze 双玻料釉
Double-stage nitriding 双重氮化法
Dow metal 陶氏金属(一种镁合金)
Dow process 陶氏法
Dowel1 合钉,定位销2双尖钉
down and up cut 同方向及逆方向交互切割,反覆切割
down cutting 下行切割
down flow asher/down stream asher 下游灰化机
Down hand welding 水平焊接
down set 下移安置
down sizing 小型化
Down sprue 下浇道
down stream plasma etching system 分离型等离子体蚀刻系统
down-draught kiln 倒焰窑
down-draw process 下拉法(玻)
DPH (diamond pyramid hardness)
DPH 硬度(同维氏硬度)
Draft1 拔模斜度2绘图3通风,通气4吃水(船)
Drag 落砂(铸疵)
Drag flask 下砂箱
drag-ladledragade drag-line 拖索挖掘机
Dragline 拖索
drain box 废液回收箱
drain castinghollow casting drain tile 排水瓦管(从土木)
draw bar 拉引棒砖
Draw bend 抽丝珠
draw bending 拉延曲面
Draw ring 拉延环
Drawability 拉延性,可拉性
Drawebench 拉制机台
Drawing1 回火2拉制,抽制3绘图
drawing chamber 拉引间
Drawing deep 深拉延,深度引长
Drawing die 拉模
Drawing wet 湿拉延
Drawing, dry 乾拉延
Drawing, Shallow 浅拉延
dressing 修整
dressing carriers /conditioning carriers 修整/条理用承载齿轮
Drift1 冲销2轻敲
Drift test 顶进定量变形试验
Driop hammer forming 落鎚成形
driver 驱动器
driver/comparator 驱动比较器
Drop 落砂(铸疵)
drop arch 低拱
Drop cutting 下穿切割
Drop feed carburizing 滴注渗碳
Drop forging 落鎚锻
Drop hammer 落鎚
Drop test1 坠重试验2坠落试验
Drop-through die 下穿模
Dross 浮渣
Drude-Lorentz law 朱罗式定律(金属高导电率)
Drum mixer 鼓形拌合机
Dry battery 乾电池组
dry body 乾坯
Dry cell 乾电池
熊猫宝宝
第20楼2008/07/27
dry cleaning equipment 乾式洗涤设备
dry copper 乾铜(含多量氧化亚铜之脆性铜)
Dry corrosion 乾蚀
Dry cyaniding 乾式氰化法
dry developing 乾式显影
dry etching system 乾式蚀刻系统
Dry ice 乾冰
dry mixing 乾混法
dry pan 乾辗盘
Dry permeability 乾砂通气性
dry powder honing machine 乾式溢料残渣喷砂清除机
dry pressing 乾压
Dry process 乾式法
dry process enameling 乾法搪瓷
Dry quenching 乾式卒火
Dry sand 乾沙
Dry sand molding 乾模法
dry shrinkage 乾燥收缩
dry spray 乾喷
dry strength 乾强度(陶)
Dry tempering 乾式回火
dry vacuum pump 乾式真空泵
Dryer1 乾燥器2乾燥剂
Drying 乾燥
Drying agent 乾燥剂
drying equipment 乾燥设备
dual cut 双加工切割
dual damascene 双道金属镶嵌法
Dual drum mixer 双鼓形拌合机
dual scan 双重扫描
dual timing generator 双向定时信号产生器
Ductile crack 延性破裂
Ductile fracture 延性断口
Ductile rupture 延性破坏
ductile to brittle transition temperature 延脆性过渡温度,延性转脆温度
Ductile [cast] iron 延性铸铁(琅状石墨化铸铁)
ductile-to-brittle transition temperature 延脆性过渡温度,延性转脆温度
Ductility 延性
Ductility test 延性试验
Ductility transition 延性转变
due in-out sequence control 装载卸载最适当顺序控制
Due, locked 互锁模
dulling 失泽(釉)
Dumet wire 杜梅线(包铜之镍铁合金线)
dummy dispense 假配药
dummy wafer 仿真晶圆,虚设晶圆
dumortierite 蓝线石
Dump1 炉座2废弃物
Dump test 压丹试验
dunting 冷裂
Duoskop 袖珍型摆动及弹硬度试验计
Duplex grain 混粒
duplex process 双重熔解法
Duplex steel 双重[精炼]钢
Durability 耐久性
Dural plat 杜拉夹层板(被覆轻合金,杜拉铝心,1-3%
Mg-Al 被覆)
Duralumin 杜拉铝
Duranel 杜拉耐(Al-coa 之产品商业名,不锈钢与铝之复合材料片)
Duranickel 杜拉镍(一种时效硬化镍合金)
Durenhete 杜拉钢(抗湿度钢,含1%Cr, 0.3%Mo) Durex 杜拉铜(含45%石墨, 10%锡之多孔青铜)
Durilium 杜拉系铝(杜拉铝型合金)
Duriron 杜拉铁(含15%
Si,0./75%C 之铁合金)
duronze 土拉铜(一种矽青铜)
Durville casting 堆维铸造法
Dust 微尘
dust coat 粉涂
dust collector 集尘器
dust proof 防尘;粉尘(水泥)
dusting 粉解(水泥);撒粉(法)(陶)
DUT board 被测试基板
DUT ground relay 被测试装置接地线切断继电器
DUT interface 被测试装置介面
DUT power supply 被测试装置电源
Dutch gildig 荷兰镀金漆
Dutch gilding 荷兰金(含15%-20%锌之铜箔)
Dwell 暂停(压机)
Dwight-Loyd machine 维一劳氏煆烧机
dye absorption 吸色;染料吸入(陶)
Dye penetrant 染色浸夜
Dye penetrant check 染料透入检查法
dye penetration 渗色;染料渗入(陶)
dynamic burn-in system 动态老化测试系统
dynamic clamp 动态钳位(制)
dynamic functional test 动态功能试验
Dynamic hardening 动态硬化
Dynamic load 动态负荷
Dynamic modulus of elasticity 动弹性模数
dynamic pattern tracer 动态图案追踪除错程式
dynamic power current measurement 动态电源电流测试
Dynamic quenchikng 动态卒火
Dynamic strength 动力强度
Dynamic test 动态试验
Dysprosium (Dy, 66)镝
