  • 熊猫宝宝
    第21楼2008/07/27
    E.B.M (electron beam machining)电子束加工,电刻
    E.C.M. (electrochemical machining)电化加工
    E.D.M (electrical discharge machining)放电加工
    Earing 成耳(冲压)
    Early-strenghth cement 早强水泥
    earth bar/grounding bar 接地棒
    earthenware 陶器;瓦器
    easy fired 易烧
    Easy glide plane 易滑面
    easy-flo 易流硬焊料(含Ag50%,Cd18%,Su16.5%,Cu15.5% 之四元共晶)
    eaves tile 詹瓦
    Ebonite 硬橡胶(皮)
    Eccentric converter 偏心转炉
    Eccentric upset forging 偏心锻粗
    Eccentric upsets 偏心锻粗件
    Eccentric upsetting 偏感锻粗法
    Economizer[ 锅炉]节热器
    Eddy current 涡[电]流
    Eddy current loss 涡[电]流损失
    eddy current method 涡电流法
    Eddy current test 涡[电]流试验
    edge bead removal /E.B.R 边缘球状物去除
    edge bending 侧向弯曲
    Edge crack 边缘裂纹
    edge dislocation 刃差排
    edge exclusion 周边除外范围
    edge lining 钩边
    edge polisher 边缘抛光机
    Edge runner 混砂机
    edge sensor 边缘感测器
    edge-runner mill 轮辗机
    Edger 磨边器,成边器
    Edging 磨边,成边
    Edging impression 成边型
    Edging stone 磨边路
    EDS testEDS 测试
    Effective aperture 有效孔径
    Effective case depth 有效硬化深度
    Effective strain 有效应变
    Effective stress 有效应力
    Efferrescing steel (同rimming steel)赤静钢
    efficiency of target utilization 靶子利用效率
    efflorescence 粉化;吐霜
    efflorwick test 吓霜试验
    Effluent 流出物
    Eggert'stube 爱格特管(快速比色,测钢中之碳用)
    eggshell porcelain 蛋壳簿瓷
    eggshelling 蛋壳耳(搪瓷)(陶)
    Einsteinium (Es,99)金爱
    ejecter 拆卸器
    Ejection 顶出
    Ejector1 顶出器2.喷射器
    Ejector plate 顶出板
    Elastic after-effect 弹性余效
    Elastic constant 弹性常数
    Elastic constraint 弹性抑制
    Elastic deflection 弹性挠曲
    elastic deformation 弹性变形
    elastic emission machining 弹性碰撞机械加工
    Elastic fatigue 弹性疲劳
    Elastic hardness 弹性硬度
    Elastic hysteresis 弹性迟滞
    Elastic limit 弹性限
    Elastic medium 弹性媒质
    Elastic modulus 弹性模数,弹性系数
    Elastic reactance 弹性抗
    Elastic strain 弹性应变
    Eldred's wire 爱瑞得导线(镀铜,镍铁心封於玻璃内之导线)
    electret 驻极[电介]体
    Electric arc furnace 电弧炉
    Electric arc welding 电弧熔接
    electric flame off 电火炬
    Electric furnace 电炉
    Electric furnace iron 电炉生铁
    Electric furnace steel 电炉钢
    Electric furnace steel making 电炉炼钢
    Electric induction 电感应
    Electric induction furnace 感应电炉
    Electric micrometer 电测分厘卡
    electric porcelain 电瓷
    Electric precipitation 电力析出
    Electric resistance furnace 电阻炉
    Electric resistance heater 电阻加热器
    Electric resistance strain gage 电阻应变计
    Electric resistance thermometer 电阻温度计
    Electric resistance welding 电阻溶接
    Electric spark maching 放电加工(同
    E.D.M)
    Electric steel 电炉钢
    Electric welding 电熔接,电焊
    Electric-arc cutting 电弧切割
    Electric-furnace ferrosilicon 电炉矽铁
    Electrical dipole 电隅极
    Electrical discharge machine (EDM)电蚀机,放电加工机
    Electrical heating 电加热
    Electrical resistivity 电阻率
    electrical rule check 电器法则查验
    Electro graphy 电蚀刻
    Electro hydralic forming 电液成型
    Electro striction 电致伸缩
    Electro-deposited coating 电积层
    Electro-deposition 电 [淀]积
    Electro-forming 电铸
    electro-luminescence method 场致发光法
    electro-migration check 电性选移查检
    electro-migration test 电性迁移试验
    electro-osmosis 电渗
    Electro-osmosis (或electro smose)电渗透作用
    electro-phoresis 电泳
    Electro-plating 电镀
    Electro-slag refining (ESR)电渣精炼
    Electro-type metal 电铸版合金
    Electrocast refractory 电铸耐火材料
    electroceraimcs 电用陶瓷
    Electrochemical corrosion 电化腐蚀
    electrochemical cyaniding 电解氰化
    electrochemical equivalent 电化当量
    Electrochemical grinding 电化研磨
    Electrochemical series 电化序
    Electrocoating 电咏护膜,电着护膜
    electrode materials 电极材料
    Electrode potential 电极电位
    electrode ring 电极环
    electrodeposition 电[淀]积
    electroformed diamond blade 电铸钻石刀片
    electrofusion 电熔
    Electrokinetics 动电常
    Electroless plating 无电镀金
    electrolysis 电解
    electrolysis treatment 电解处理
    electrolyte 电解质
    electrolytic cell 电解电池
    electrolytic cleaning 电解清洁法
    electrolytic copper 电解铜
    electrolytic de-rusting 电解去锈
    electrolytic deflash 电解树脂残渣去除
    electrolytic discharge aided grinding machine 电解放电辅助研磨机
    electrolytic dissociation 电[解]离解
    electrolytic etching 电 [解]浸蚀
    electrolytic hardening 电[解]硬化
    electrolytic ionized water /electrolysis-ionized water 电解电离水
  • 熊猫宝宝
    第22楼2008/07/27
    electrolytic iron 电解铁
    electrolytic pickling 电解浸洗
    electrolytic polishing 电解抛光
    electrolytic powder 电解粉未
    electrolytic protection 电解防蚀法
    electrolytic refining 电解精炼
    electrolytic solution tension 电解溶压
    electrolytic toughpitch copper 电解勒炼铜
    electrolytical series 电解序列
    Electromagnet 电磁体,电磁铁
    Electromagnetic forming 电磁成形
    Electromagnetic lens 电磁透镜
    Electromagnetic wave 电磁波
    electromechanical polishing 电解机械抛光
    Electrometallurgy 电化冶金,电冶学
    Electromotive force series 电动势序
    Electron alloy 伊兰镁合金(含铝锌镁基合金)
    Electron balance 电子天秤
    electron beam 电子束
    electron beam annealer 电子波束退火处理机红
    electron beam cell mask 电子束功能电路胞光罩
    electron beam control 电子束控制
    electron beam evaporation system 电子束蒸镀系统
    electron beam exposure system 电子波束曝光系统
    electron beam melting furnace 电子束熔解炉
    electron beam prober 电子波束探针
    electron beam test system 电子波束测试系统
    electron beam welding 电子束熔接
    electron beam zone-refining 电子束区带精炼
    Electron cloud 电子云
    Electron compound 电子化合物
    Electron configuration 电子组态
    Electron Coupling Resonance (ECR)
    plasma enhanced CVD systemECR 等离子体增强型CVD 系统
    sputtering system 电子耦合谐振溅镀系统
    electron cyclotron resonance 电子回旋加速器共振
    electron cyclotron resonance etching system 电子回旋加速器共振蚀刻系统
    Electron diffraction pattern 电子绕射图
    Electron diffratction 电子线绕射
    electron flood gun 淹没式电子枪,电子流枪
    Electron furnace iron 电炼生铁
    Electron gun 电子枪
    Electron lens 电子透镜
    Electron microscope 电子显微镜
    Electron negative potential 电子负电位
    Electron optics 电子光学
    Electron pair 电子隅
    Electron photomicrograph 电子显微照片
    electron probe micro analysis 电子探针微分析
    electron probe microanalysis 电子探针分析
    Electron probe microanalyzer 电子探测显微分析仪
    Electron ratio 电子比
    electron shading effect 电子遮掩效应
    Electron spin 电子自旋
    electron suppressor 电子抑制器
    Electron volt 电子伏特
    Electron wave 电子波
    Electronic charge 雯子电荷
    electronic design automation(EDA) 电子设计自动化
    electronic design interchange format(EDIF) 电子电路设计互换格式
    Electronic polarization 电子极化
    electronic system design automation tool 电子系统自动设计工具
    Electrophoresis 电咏
    Electrophoretic plating 电咏镀
    electropositive potential 正电位
    Electroslag remelting process 电渣再熔法
    Electroslag welding 电渣熔接
    electrostatic chuck 静电夹头,静电夹盘
    electrostatic discharge protection 静电放电保护
    electrostatic fluidized bed 静电浮床
    Electrostatic mineral separation 静电矿物分离机
    Electrostatic precipitation 静电沉积
    electrostatic scan 静电扫描
    Electrostatic separation 静电分离
    Electrostatic spraying 静电喷涂
    electrothermal equivalent 电热当量
    Electrothermic method 电热法
    Electrotype 电铸板
    Electrotyping 电铸版术
    Electrovalent compound 电价化合物
    Electrowinning 湿式电冶
    Eletrode1. 电极2.熔接条
    Eletrum 白黄金(40-50%Au, 其余为Ag)
    elevator kiln 升降窑
    elevator unit 升降机单元
    Elinvar [steel] 恒弹性钢
    Elphal 依尔花法,钢皮差面沉积纯铝法
    Eluant solution 洗涤液
    Elutriation 淘析(液体中分离大小,粉未颗粒的方法)
    email sur bisque 素三彩
    emaillieuen 插画珐琅
    embeded array 埋入行阵列
    embeded system 埋入型系统
    Embossing 浮花压制法压凸
    embrittlement 脆性
    Emerg colth[ 金钢]砂布
    Emerg paper[ 金钢]砂纸
    Emergizer 促进剂(渗碳)
    Emery 钢砂,钢石粉
    Emission electrton microscope 发射电子显微镜
    Emissivity 发射率
    emissivity correction 发射率校正
    Emitter 射极
    Empirical proportioning 经验配合
    emulator 模拟除错器
    Emulsified oil quenching 乳化油卒火
    Emulsion 乳液,乳胶
    Emulsion cleaner 乳化清洁剂
    Enamel1. 搪瓷2.瓷漆
    Enamel coating 搪瓷护膜
    enamel color 珐琅色彩
    enamel glaze 珐琅釉
    Enamel paint 瓷漆
    Enameled iron ware 搪瓷[铁]器
    Enameled wire 漆包线
    enamelling 施珐琅;搪瓷
    enamelling iron 搪瓷胎铁
    Encapsulation 封装
    Enclosure 夹杂物,包壳
    encoustic tile 彩纹瓦
    end arch 端拱砖
    end chipping 最终结晶屑
    end skew 端斜砖
    end wall 端墙
    end-station 终端站
    endless band saw 环型条带锯
    Endothermic gas 叹热型气体(热处理保护气)
    Endothermic reaction 吸热反应
    Endurance limit (fatingue limit)疲劳限
    Endurance ratio 疲劳比
    Endurance strength 疲劳强度
    Endurance test 疲劳试验
    Enduron 安久乐(一悝含铬钼矽之铁系耐蚀合金)
    Energy band 能带
    energy contamination 能量污染,杂质能量
    energy gap 能隙
    Energy level 能阶,能准位
    Energy packet 能,束
    Enfield rolling mill 恩菲德巴钢机
    engine-turning lathe 机动车床
    engineering change order 工程变更次序
    engineering work station(EMS) 工程工作站
  • 熊猫宝宝
    第23楼2008/07/27
    English 英文
    English bond 英式砌法
    English crystal 高铅水晶玻璃
    English white 白垩
    engobe 化粧土;釉底料
    engravers brass 刻版黄铜(一种含铅黄铜)
    engraving 刻花
    enhanced global alignment 增强型全晶圆调准
    Enriched uranium 浓缩铀
    Enrichement 浓缩
    Enthalpy 焓
    Entrained air 输气(混凝土)
    Entrapped air 陷入空气(混凝土)
    Entropy 熵
    Environment control 环境控制
    environmental scanning electron microscope 环境控制扫描型电子显微镜
    Epitaxial growth 叠晶生长,同轴生长(晶体)
    epitaxial growth system 磊晶生长系统
    epitaxial wafer 磊晶晶圆
    Epithermal neutrons 超热中子(具有在分裂中子与热中子间能量之中子)
    Epoxy resin 环氧树鲁
    Epsilon carbideε 碳化物
    Epsilon compoundsε 佮合物(电子比为7:4,例如CuZn3)
    Equations of state 状态方程式
    equi-blast cupola 等吹熔铁炉
    Equiaxial polytggonal grain 等轴多角形晶粒
    Equicohesive temperature 等结合温度(晶粒内晶粒界强度相等时之温度)
    Equigranular 等粒状
    equilibrium (phase)平衡
    Equilibrium diagram 平衡图
    Equilibrium potential 平衡电位
    Equilibrium segregation 平衡偏析
    equilibrium segregation coefficient 平衡偏析系数
    Equilibrium state 平衡状态
    equivalence factors 当量因素
    equivalent fault 等效故障
    Equivalent section 比量断面
    equivalent weight 当量
    Equlibrium 平衡
    erase error 删除错误
    erase error allowance 删除错误容限
    erase fail 删除失误
    Erbium (Er,68)铒
    Erichsen [cupping] test 爱理逊压凹试验
    Ermalite 艾马来铁(高延性铸铁)
    Ernst hardness tester 恩氏硬度计
    Erosion 冲蚀
    Erosion-corrosion 阵蚀,腐蚀
    Erosion-resistrance 耐冲蚀性
    Erubescite 硫铜石,斑铜矿(Cu2FeS3)
    Ester 酯
    estimated wire length 估计布线长度
    etch back 回蚀
    Etch bands 浸蚀带
    etch fiqure 蚀迹
    etch pit density 腐蚀坑密度
    etch rate 蚀刻速率
    etch residue 蚀刻残余物
    etch selectivity raito 蚀刻选择比,蚀刻选择性
    etch uniformity 蚀刻均质性
    Etchant 浸蚀液,蚀刻液
    etched wafer 经蚀刻晶圆
    etching1 蚀刻2浸蚀
    etching chamber 蚀刻处理室
    etching end point detection 蚀刻终点检测
    Etching pit 蚀乙
    etching system 蚀刻系统
    etching wafer 刚蚀刻晶圆
    Ethyl silicate 矽乙酯
    Ettinghausen effect 埃丁赫逊效应(晶体之一种物理效应)
    eucryptite 锂霞石
    Eureka 尤瑞卡铜(电阻线之一种,近似康史登铜)
    Europium (Eu, 63)铕
    eutectic 共晶
    Eutectic alloy 共晶合金
    eutectic bonding 共晶接合
    Eutectic carbide 共晶碳化物
    Eutectic cast iron 共晶铸铁
    Eutectic cell 共晶单胞
    Eutectic cementite 共晶雪明碳体(铁)
    Eutectic colong 共晶集团
    Eutectic graphite 共晶石墨
    Eutectic mixture 共晶混合物
    Eutectic reaction 兆晶反应
    Eutectic temperature 共晶温度
    eutectoid 共析
    Eutectoid alloy 共析合金
    Eutectoid cementite 共析雪明碳体(铁)
    Eutectoid composition 共析成分
    Eutectoid ferrite 共析肥粒体(铁)
    Eutectoid hardening 共析硬化
    Eutectoid line 共析线
    Eutectoid point 共析点
    Eutectoid reaction 共析反应
    Eutectoid steel 共析钢
    Eutectoid structure 共析组织
    Eutectoid temperature 共析温度
    Eutectoid transformation 共析变态
    evacuated wet etching system 减压抽气浸渍式蚀刻系统
    Evanohm 艾文姆台金(一种镍铬铝铜合金)
    Evaporation coefficient 蒸发系数
    Evaporation loss 蒸发损失
    evaporation material 蒸发材料
    Evaporation ratio 蒸发比
    evaporation source 蒸发源
    event driven simulator 事件驱动模拟器
    Everdur 艾未狄合金(一种矽青铜)
    Ewald chart 厄互特图(X-ray)
    ExB magnetron sputtering system 直交电磁场型溅镀系统
    excavator 挖掘机
    Exchange energy 互换能
    Exchange force 互换力
    Exchange-cunent density 交换电流密度
    excimer laser stepper 准分子雷射步进机
    Excitation 激发,激励
    Exciting level 激励准位
    excluding backside deposition 防止背面沉积
    exclusing backside deposition 防止背面沉积
    Exfoliation 表皮脱落
    exhaust for developer 显影剂排放
    Exhaustion creep 耗竭潜变
    Exogenous metallic inclusion 外来金属夹杂物
    Exothermic reaction 放热反应
    Exothermic-base atmosphere 放热式蒙气,放热式炉器
    expand stage 黏胶片扩展夹片台
    Expanded metal 展成金属(网)
    Expanded r-field 扩张r 区
    Expanding metals 胀大金属(铋合金)
    expansion 展开
    Expansion coefficient 膨胀系数
    expansion ratio 晶圆黏胶片扩展率
    Expansion scab 膨胀剥砂
    expectation value pattern 期待值图案
    expected pattern 预期图案
    Explosibility 爆炸性
    Explosion testing 爆炸试验
    Explosion welding 爆炸熔接
    Explosive antimony 爆炸锑
    Explosive bonding 爆炸接合
    Explosive forming 爆炸成形
    explosive pressing 爆炸压制
    exposed area ratio 蚀刻面积率,曝光面积率
    exposure 曝光
    Extended dislocation 扩展差排
    extension board 延伸接线板;扩张接线板
    Extensometer 伸长计
    external gettering 外部吸器
    external torch unit 外界火炬装置
    External upset 向外锻粗锻件
    External upset forging 向外锻粗
    External upsetting 向外锻粗法
    Extra dense flint 特火石玻璃
    Extra light flint 特轻火石玻璃
    Extra-hard cold work 特硬级冷加工(冷巴至断面缩小50.0%)
    Extra-spring-hared cold work 特弹簧硬冷加工(冷巴至断面缩小68.7%)
    extraction electrodes 提取电极
    Extraction replica 萃取印模(电子显微镜)
    extraction voltage 提取电压
    Extractive metallurgy 提炼冶金学
    Extrapolation of creep data 潜变数据外推法
    extrinsic gettering 非本徵吸器
    Extrinsic semi-conductor 他激半导体,他半导体
    Extrudability 挤制性
    Extruding 挤延
    extrusion1 凸出(疲劳滑动面)2挤裂
    Extrusion cold 冷挤制
    Extrusion, backward 逆向,挤制
    Extrusion, forward 顺向,挤制
    Extrusion, hydrostatic 液压挤制
    Extrusion, impact 冲击,挤制
    Extrusion, reducing 减缩,挤制
    Eyelet 小孔
    Eyeleting 小眼圈
    Eyepies 目镜
  • 熊猫宝宝
    第24楼2008/07/27
    F.D.P (Firths Decay Proof)
    F.D.P [不锈]钢
    F.S.L. 一种含0.05%
    C, 18.5%Cr, 10%Ni 之低碳不锈钢
    Faber Du Faur Retort 法普佛甑
    Fabriacation 制造,打造构制,组合
    face brick 饰砖
    face down bonding/face bonding 面朝下接合
    face wall 面墙
    Face-centered cubic (f.c.c.)面心立方
    face-centered cubic (FCC)面心立方
    Face-centered cubic lattice 面心立方格子
    Face-centered orthorhombic 面心斜方
    Facet 小面
    facience 法恩陶
    facing brick 面砖
    Facing sand 面砂
    facing target sputtering (FTS)
    system 相面对靶子溅镀系统
    Factor of safety 安全因数
    Fahlum metal 法鲁金属(Pb60%, Sn40%)
    fail bit map 错误位元图表
    fail mark 不良记号
    fail-make inspection function 不良标记检查功能
    Failure analysis 损坏分析
    failure analysis memory 故障解析记忆器
    Falling weight test 落重试验
    false path problem 错误路径问题
    false set 假凝
    famille noire enamel 黑地彩
    famille rose 胭脂红;粉彩
    famille verte 绿地形
    family box 族系箱
    family head 族系原头
    Faraday effect 法拉第夜应
    faraday system 法拉第系统
    Fast breeder reactor 快滋生反应,快增殖反应器
    Fast neutron 快中子(能量超过0.1Mev)
    fast traverse 快速通过速度
    fat clay 富黏土(从土木)
    Fat sand 高黏土砂
    Fatigue corrosion 疲劳腐蚀
    Fatigue crack 疲劳裂痕
    Fatigue fracture 疲劳破裂
    Fatigue limit 疲劳限
    Fatigue notch factor 疲劳凹痕因数
    Fatigue test 疲劳试验
    Fatigue test machine 疲劳试验机
    Fatigue tester 疲劳试验机
    fault 缺陷
    fault analysis 故障分析
    fault circuit 故障电路
    fault coverage 故障概括率
    fault dictionary 故障辞典
    fault simulator 故障模拟器
    Fayalite 铁橄榄石,铁矽酸盐
    Faying surface1 接合面2 待接合面
    Feal 费尔合金(25%Al, 其余为Fe 有良好制振性)
    feather combing 梳花
    feather marking 羽状痕迹
    feed gums 种籽胶
    Feed ring 环冒口
    Feed riser 冒口
    Feed water 给水
    feeder 饲机
    feeder channel 饲槽
    feeder gate 饲料闸
    Feeding rod 冒口搅棒
    Feldspar 长石
    feldspathic glaze 长石岫
    feldspathoid 似长石
    felsophyne 矽长斑石
    felsparfeldspar Feltmetal 金属纤维毡
    Feran 包铝钢条
    Fermi level 费米准位(原子)
    Fermi surface 费米面(原子)
    Fermium (Fm, 100)镄
    Fernichrome 费理铬(一种能封入铅玻璃内之材料,含37%Fe,30%Ni,25%Co,8%Cr)
    Ferrari cement 佛拿里水泥
    Ferric oxide 三氧化二铁
    ferrimagnetism 亚铁磁性
    Ferrious material 铁系金属
    Ferrite1 肥粒铁2 磁性氧化物
    ferrite (ceramic)1肥粒铁2磁性氧化物
    Ferrite grain size 肥粒铁晶粒度
    Ferrite martensite 肥粒形麻田散体
    Ferritic cast iron 肥粒铁铸铁
    Ferritic decarburized depth 脱炭层之肥粒铁深度
    Ferritic stainless steel 肥粒铁不锈钢
    ferro boron 硼铁
    Ferro-alloy (ferroalloy)合金铁
    ferro-bronge 铁青铜(8%Fe, 0.7%Cr, 其余为Cu)
    Ferro-chrome 铬铁
    Ferro-electric materials 铁电材料(如BaTiO3)
    Ferro-manganese 锰铁
    Ferro-molybdenum 钼铁
    Ferro-phosphorus 磷铁
    Ferro-silicon 矽铁
    Ferro-titanium 钛铁
    Ferro-tungsten 钛铁
    Ferro-vanadium 钨铁
    Ferrochrome-silicon 矽铬铁
    ferroele ctric 强电介体(从电机)
    ferroelectric thin film 铁电薄膜强诱电体薄膜
    Ferrograph 磁滞仪
    Ferrolum 包铅钢
    ferromagnetic 强磁的
    Ferromagnetic domain wall 铁磁区壁
    Ferromagnetic spinel 铁磁性尖晶石
    ferromagnetism 铁磁性,强磁性
    Ferromanganese-silicon 矽锰铁
    Ferron 福朗(含35%Ni, 15%Cr,其余为铁的一种抗氧化合金)
    Ferronickel 镍铁
    Ferrose-forric oxide 磁性氧化铁(Fe3O4)
    Ferroselenium 矽铁
    Ferrostan 电镀马口铁(镀锡冷卷钢)
    ferrous alloy 铁合金
    Ferrous metallurgy 钢铁冶金学
    Ferrous oxide 氧化亚铁
    Ferrox cube 软磁磁体族
    Ferry 福里合金(一种含55%
    Cu, 45%Ni 之高电阻材料,类似康史登钢)
    Fertile material 可育材料
    Fery radiation pyrometer 费氏辐射高温计
    fetrafluoroethylene oxide 氧化四氟乙烯
    Fettling 修整(1 铸件加工前之修整 2 炉衬之修整)
    Fiber metal 纤维金属
    Fiber reinforced plastice (FRP)纤维加强塑胶
    Fiber stress 纤维应力
    Fiberfax 岩绒,金刚纤维
    fiberglass 玻璃纤维
    fibre, ceramic 陶瓷纤维
    Fibrous falc 纤维状滑石
    Fibrous structure 纤维组织
    Fick's first law 菲克(扩散)第一定理
    Fick's law 菲克[扩散]定律
    Fick's second law 菲克(扩散)第二定理
    fiducial mark 基准标记
    Field batch weight 工地盘重
    Field control 工地控制
    Field effect transistor (FET)场效应电晶体
    field-drain pipe 工地排水管
    figured glass 压花玻璃
    Filberflow 纤维流纹
    filed programmable gate array 现场可程式闸门阵列
    filed programmable interconnect 现场可程式互接
    filler 填充料
    Filler metal 熔填金属
    fillet 接合剂渗出痕迹,接合轮廓
    film strength 乾釉强度
    Film test 薄膜试验
    filter (活性炭)过滤器
    filter block 泸砖
    filter candle 泸筒
    filter cke 泸饼
    filter cloth 滤布
    Filter press 压滤机
    filtration equipment with coagulation 凝聚过滤设备
  • 熊猫宝宝
    第25楼2008/07/27
    fin 缝翅
    final energy magnet 终极能量磁铁
    final polishing 最後加工抛光仕上研磨
    final test 最後测试
    final wafer test 晶圆後端测试
    Fine aggregate 细骨材
    fine alignment 精细对准
    Fine gilt 薄层镀金
    Fine grain 细晶粒,细[颗]粒
    fine grinder 细研机
    fine grinding 细磨
    Fine pearlite 微粒波来铁
    fine pitch 精细节距
    fine powder 超微粒
    Fine-grained steel 细晶粒钢
    fineness moldulus 细度模数
    Fineness of cement 水泥细度
    Finess number 粒度(铸砂)
    Finger gate 指形铸口
    finial 屋脊饰
    fining 澄清
    Finishability 饰面难易度
    Finished steel 精炼钢
    Finishing impression 完成型
    Finishing machine 整面机
    Finishing mill 完成巴机
    Finishing roll 未巴辊
    Finishing temperature 完成温度
    Fink process 芬克浸铝法
    Finkle-Mchr process 芬克莫尔法
    finl set 终凝
    finyl chloride polymers 氯乙烯聚体
    fir brick 火砖
    fir resistance 耐火性
    fire back 垫[背]火砖
    fire box 火箱
    Fire brick 耐火砖
    fire bridge 火坝
    Fire clay 耐火泥
    fire crack 热裂
    fire finished 火修光
    Fire magnesite-chrome brick 烧镁铬砖
    fire mark 火痕
    fire pillar 火柱
    fire polished 火焰磨光
    fire proofing tile 坐火瓦
    Fire refining 火法精炼
    Fire sand 耐火砂
    Fire welding 固态接合,接火
    Fire-box steel 火箱钢
    Fire-cracking 热裂
    firecaly 火黏土
    Fired chrome brick 烧铬砖
    Fired magnesite brick 烧镁砖
    Firestone 耐火石
    firing1 烧成2点火
    firing expansion 烧制膨胀
    firing range 烧制范围
    firing shrinkage 烧[成][收]缩
    firingtemperature 烧成温度
    first bonding 第一接合,第一压接
    First coat1 底漆2 第一涂层
    first dislocation generation 初次发生位错
    First stage annealing 第一段退火
    firsts 一级品
    Firth hardometer 费氏硬度计
    Firty 耐火性
    Fish scale 鳞状破面
    fish-scale 鳞剥
    fisheyes 鱼眼(因氢脆性之裂开面)
    Fishtail 鱼尾式
    Fissile material 可分裂材料
    Fission 分裂
    Fission fragment 分裂碎片
    Fission poison 分裂毒物
    Fission product 分裂产物
    Fissionable material 可分裂材料
    Fissium 分裂碎片合金
    fitting 配件
    five points thickness variation5 点厚度变动
    Fixed carbon 固定碳
    fixing block 受钉砖块
    fixture board 夹具基板
    Fizeau interferometer method 菲氏干涉计法
    flabby cast 软铸物
    Flake1 小片2 裂纹3 白疵
    Flake graphite 片状石墨
    Flake graphite cast iron 片状石墨铸铁
    Flaking 剥落
    Flame annealing 火焰退火
    Flame cleaning 火焰清除法
    Flame cutting 火焰切割
    Flame hardening 火焰硬化
    flame photometer 焰度计
    flame plating 焰镀[法]
    Flame scaling 焰烤锌皮法
    flame sensor 火焰感测器
    Flame softening 火焰软化
    Flame spectro fluorimetry 火焰光谱分析
    Flame spraying 火焰喷涂
    Flame straightening 火焰矫直
    Flame strengthening 火焰强化
    Flame-plating 火焰涂层
    flame-spraying 焰喷[法]
    Flame-tempering 火焰回火
    flameless combustion 无焰燃烧
    Flanging 摺缘
    Flappin [of copper] 翻搅
    flare bed 发焰道
    Flare test 顶进定量变形试验(与drift test 同)
    Flaring 扩口
    Flash 飞边,溢边
    Flash and fire point test 闪点及燃点试验
    flash lamp annealer 闪光灯退火处理机
    flash memory E/W cycle test system 快闪记忆体删除写入周期测试系统
    Flash point 闪点
    Flash radiography 闪烁放射性摄影
    Flash roasting 闪燃煆烧
    flash shield 溢边护罩
    flash wall 闪火墙
    Flash welding 闪电熔接
    Flash-butt welding 闪电对头熔接
    Flask1 砂箱2 烧瓶
    flat bar1 扁条2 扁条钢
    flat collet 平面吸具
    Flat dies 平模
    Flat grain 平纹
    flat zone length 热平坦区长度
    Flat-die forging 平模锻造,平模锻件
    Flat-die hammer 平模鎚
    flat-ware 浅皿
    flatness 平面度
    flatness quality area 平面度适用区域
    Flats 扁钢(1/8~1/4寸厚两尺以卷宽之卷钢片)
    Flattener 矫平机具
    flatting 平整[法]
    Flemish bond 法式砌法(从土木)
    Flexibility 凸挠性
    flexural strength 抗弯强度
    Flexure tests 弯曲试验
    Flint 火石,燧石
    flint clay 燧石黏土
    Flint glass 火石玻璃
    flint shot 燧石粒
    flip chip bonder 倒装片接合机
    flip chip bonding 侧装片接合
    float glass process 浮制玻板法
    float polishing 浮动抛光
    Float test index 浮游试验指数
    floatation equipment 漂浮分离设备
    floater 浮舟(玻)
    floating agent 浮剂
    Floating die 浮动模
    floating license 浮动许可证
    Floating zone crystal growing 浮融带晶体生长法
    floating zone melting method 浮动区熔法
    Floating-zone refining 浮融带纯化
    floc testwater test flocculant 絮凝剂
    Flocculation 絮凝,凝聚
    Flong 纸型(活字版铸版用)
    flood casting 泄注法
    floor brick 地砖
    Floor molding 地模法
    floor planner 平面规划器
    floor quarryquarry tile floor tile 铺地砖
    Flotation 浮选
    Flow ability 流动性
    Flow ability of sand 铸砂流动性
    flow blue 霁青
    Flow brightening 亮锡法
    Flow coating 流动施膜
    Flow line1 加工流程2 锻造流线
    Flow line network 流线网,流程网
    flow machine 致流机
    Flow off 溢流口
    flow pattern defect 流体图案缺陷
    Flow spinning 切刀旋转法
    Flow stress 流度应力
    flow table 流度台
    flow test 流度试验
    Flow through 溢流道
    Flow welding 熔流熔接
    Fluctuating stress 波动应力
    flue gas 烟道气
    fluid-energy mill 流体能磨
    Fluidity 流体性
    Fluidity index 流体性指数
    fluidized bed 流体化床
    Fluidized sand 流动性铸砂
    Fluidized sand molding 流动性铸砂造模法
    fluidized-bed coating 流体床法护膜
    Fluon 氟罗央(PTFE 的商业名称)
    Fluorescence 萤光
    Fluorescence analysis 萤光分析
    Fluorescence particle inspection 烛光颗粒检验
    Fluorescent material 萤光材料
    Fluorescent penetrant test 萤光透入剂试验
    fluorite 萤石
    Fluorite (fluorspar)萤石
    Fluoroscopy 萤光分析术
    fluorspar 萤石
    Flush quenching 闪激卒火
    flux1 助熔剂2焊剂3熔剂4通量(磁电)
    flux factor 熔剂因数
    flux line 玻膏面
    Flux-covering 熔剂覆盖
    Fluxing 熔剂处理
    Fly ash 飞灰
    flying arch 跳顶拱
    Flying saw 随动锯机
    Flying shear 随动剪机
    Flying spot microscope 飞点式显微镜
    foam concrete 泡沫混凝土
    foam glass 泡沫玻璃
    foamed clay 起泡黏土
    foamed concrete 起泡混凝土
    Foaming 起泡
    focal plane 焦点平面
    focal plane deviation 焦点平面偏差
    Fog quenching 喷雾卒火
    Foil 箔
    Foil heat treatment 箔袋热处理
    Fold 摺痕
    Folding defect 摺叠瑕疵
    Follow board 嵌模板
    Fool's gold 愚人金(黄铁矿FeS2)
    Foolner process 福药法(磷酸盐处理)
    foot print 脚印
    Footing 基脚
    Foppl test 福贝耳[硬度]试验
    Forbidden band 禁带(原子)
    force fill process 加压填埋空隙
    forced draft 强制通风
    Forced gas convection 强制气对流
    Fore blow 前期吹风
    Fore hand welding 前进熔接
    Fore hearth 前炉
    Foreign atom 外来原子
    Forge hammer 锻鎚
    Forge iron 锻铁
    Forge rolls 锻辊
    Forge welding 锻造熔接,锻接
    Forgeability 锻造性
    Forged steel 锻钢
    forging 1锻造2锻件
    Forging dies 锻模
    Forging machine 锻机
    Forging, closed-die 1闭模锻造 2 闭模
  • 熊猫宝宝
    第26楼2008/07/27
    Forging, cold 冷模
    Forging, flat-die 1 平模锻造 2 平模
    Forging, hammer 鎚锻
    Forging, hand 手工锻造
    Forging, high-energy-rate 高能率锻造
    Forging, high-velocity 高速锻造
    Forging, hot 热锻
    Forging, machine 机械锻造
    Forging, open-die1 开模锻造2 开模锻件
    Forging, pancake 扁圆锻件
    Forging, press 压机锻造
    Forging, roll 轧机锻造
    Forging, smith 手工锻造
    Forging, upset1 锻粗锻造2 锻粗锻件
    fork 铁叉
    form chamfering 整形去角取面
    Formability 成形性
    formal verification 正式验证
    formatter 格式编制器
    Forming 成形
    forming gas 组成气体
    Forming, bulge 胀大成形
    Forming, compression 压缩成形
    Forming, contour roll 型辊成形
    Forming, creep 潜伸成形
    Forming, drop hammer 落鎚成形
    Forming, electrohydraulic 电液成形
    Forming, electromagnetic 电磁成形
    Forming, explosive 爆炸成形
    Forming, high-energy-rate 高能井成形
    Forming, hydraulic 液压成形
    Forming, magnetic pulse 电磁震动成形
    Forming, multiple-slide 多滑块成形
    Forming, press 压机成形
    Forming, press-brake 折条机成形
    Forming, radial-fraw 径拉成形
    Forming, rubber-diaphram 橡胶膜成形
    Forming, rubber-pad 橡胶垫成形
    Forming, rubber-punch 橡胶冲成形
    Forming, shrink 收缩成形
    Forming, stretch 拉伸成形
    Forming, three-roll 三辊成形
    Forming, wacuum 真空成形
    Forming, wire 线料成形
    Forms 模板
    Forrester flotation machine 富尔斯特浮还机
    forsterite 镁橄榄石
    Forsterite (Mg2SiO4)矽酸镁石
    forward annotation 正向注解
    Forward extrusion 顺向挤制
    Forward spinning 顺向旋挤
    Forward welding 前进熔接
    Foucault current method 傅科电流法
    Fouling 积垢(船底海藻贝壳)
    fouling index(FI) 污浊指标(FI)
    Fouling resistance 防垢性(铅底)
    Foundation 基础
    Founder 铸工
    Founding 铸造
    Foundry1 铸造2铸造场
    Foundry coke 铸焦
    Foundry defects 铸疵
    Foundry ladle 铸造浇斗,铸造盛通
    Foundry losses 铸造损耗
    Foundry pig 铸造生铁
    Foundry pig iron 铸造用生铁
    Foundry returns 回炉料
    Foundry sand 铸砂
    Foundry type metal 手植活字合金
    four (point)
    probe method 四(点)探针法
    Four-high mill 四辊巴机,四重式轧机
    four-way type 四方向方式
    Fourier transform infrared spectroscopy 傅立叶转换红外光谱学
    four(point)probe method 四(点)探针法
    Fractional crystallization 分段结晶
    Fractography 断口型像学
    Fracture mechanics 破断力学,破坏力学
    Fracture stress 破断应力
    Fracture surface 破断面
    Fracture test 破断试验
    fracture toughness 破裂韧性
    Fracture transition 脆断转移[温度]
    Frame filter press 框式压泸机
    frame memory 视帧记忆器;图框记忆器
    Frame work structure 构架结构
    framework 架构
    Francium (Fr, 87)金法
    Frand-Read source 法一瑞式[差排]源
    Frank partial dislocation 法兰克部份差排
    Frary metal 法拉钡合金(一种铅钨钡合金)
    Free carbon 游离碳
    Free cementite 游离雪明碳铁
    free cutting brass 易切黄铜
    free cutting bronze 易切青铜
    Free cutting steel 易切钢
    Free electron 自由电子
    free energy 自由能
    Free ferrite 游离肥料铁
    Free lime 游离石灰
    Free water 游离水份
    Free-cutting metal 易切金属
    free-flow bender 开放弯曲机
    freeze-casting 冻铸法
    freezing 冷凝,冻结凝固
    freezing and thawing test 冻结融解试验
    Freezing cuve 冷凝曲线
    Freezing method 冷凝法
    Freezing point1 凝固点; 2 冰点
    Freezing range 凝固范围
    French chalk 法兰西白呈(即滑石3
    MgO4SiO2、H2O)
    French metal 法兰西金属(一种精炼锑)
    French process 法兰西法(一种提锌法)
    Frenkel defect 佛兰克缺陷(晶格缺陷)
    Fresh water 淡水
    Fretling corrosion[ 紧压]磨蚀,移擦腐蚀
    friction element 摩擦元件
    Friction oxidation 摩擦氧化
    friction pressfriction-screw press Friction sawing 摩擦锯切
    Friction screw press 摩擦螺杆压机
    Friction welding 摩擦熔接
    Frictional loss 摩擦损耗
    frifluoroacetylnitrile 亚硝酸三氟乙醯
    Fringe 晕纹
    frit 熔块;玻料
    fritted glass ware 玻釉玻璃器
    fritted glaze 熟釉;玻料釉
    fritted porcelain 玻料瓷
    Fritting1 烧结(同sintering) 2 上釉料
    frizzling 绉缩(陶)
    frog ring 辙叉环
    Fromont test 傅瑞孟[冲击]试验
    front end design 前端设计
    front side reference method 前侧基准法
    Front slagging 前渣法
    Frontier alloy 佛兰提合金(一种铝锌合金)
    frost glass 磨砂玻璃
    Froth flotation 泡漆浮选
    Fry's reagent 傅蕊族剂
    fuel cell 燃料电池
    fuel cell stack 燃料电池堆
    Fuel cycle 燃料循环
    Fuel element 燃料元件
    Fuel fabrication 燃料构制
    Fuel oil 燃料油
    Fuel ratio 燃料比
    Fuel reprocessing 燃料再处理
    Fugacity (fugasity)1 挥发度 2 挥发性
    Full annealing 完主退火
    full automatic growing furnace 全自动成长炉
    full cutting 全切割
    Full hardening 完全硬化
    Full insert 整体嵌件
    Full mold process 全模法
    full site 全体区分地段
    Full-killed steel 全静钢
    Full-mould casting process 金模铸造法
    Fuller 半圆型鎚
    fuller earth 漂白土
    Fuller's ideal curve 富乐理想曲线
    Fullering 歛缝,填隙
    fullering bar 填隙棒
    Fullering fmpression 歛缝型
    Fully-killed steel 全静钢
    Fulminates 雷酸盐(不稳定易爆材料)
    fume 烟气
    function test 功能测试
    Functional ceramics 功能陶瓷
    functional description language 功能记述语言
    functional schematic editor 功能检图编辑器
    Fundamental vector Furnace 基本向量炉
    Fundation translation vector 基本平移向量
    funerary ware 明器
    furnace angle 炉体倾斜角
    furnace annealer 电热炉退火处理机
    furnace lift travel 炉移动行程
    Furnace lining 炉衬
    furnace tube cleaning equipment 炉心管洗涤设备
    Furnace, baking 烘焙炉
    furnace, batch [type] 批式炉
    furnace, bell-type 钟罩式炉
    furnace, bogie hearth 钟罩式炉,拖车式炉
    furnace, box 箱式炉
    Furnace, car bottom 车底式炉
    Furnace, chain type 链式炉
    Furnace, continuous 连续式炉
    Furnace, continuous-strand 连绩回式炉
    Furnace, conveyor (conveyer)输送带炉
    Furnace, direct arc 直接电弧炉
    Furnace, high frequency 高周波电炉
    Furnace, holding 保温炉
    Furnace, indirect arc 间接电狐炉
    Furnace, lift off cover 离盖式炉
    Furnace, overhead conveyer 高吊输送炉
    Furnace, pit 坑式炉
    Furnace, preheating 预热炉
    Furnace, pusher 推式炉
    Furnace, remelting 再泰炉
    Furnace, roller hearth 滚子炉
    Furnace, rotary-hearth 转膛炉
    Furnace, screw feed 螺旋送料炉
    Furnace, slot-type 槽式炉
    Furnace, tunnel 隧道炉
    furnace, walking beam 动梁炉
    fuse data 熔丝资料
    fuse link 链丝熔丝
    Fuse-quench process 熔化急冷法
    Fused alumina 熔凝铝氧
    Fused quartz 熔凝石英
    Fused sand 熔砂
    fused silica 熔矽石
    Fused zone 泰融带
    Fused-cast refractory 熔铸耐火材料
    fused-salt electrolysis 泰盐电解
    Fused-silica frick 熔凝矽砖
    Fused-silica refractory 泰凝矽质耐火材料
    Fusible alloy 易熔合金
    Fusible pluger 易熔塞
    Fusing pyrometer 融点高温计
    fusion1 熔化,熔解 2 熔合(核子)
    fusion casting 熔铸法
    Fusion of packing materials 填料熔合
    Fusion penetration 熔融穿入
    Fusion point 熔融点
    Fusion range 熔融区
    Fusion sawing 熔融锯
    Fusion temperature 熔融温度
    Fusion welding 熔融泰接
    fusion-flow test 熔流试验(搪瓷)
    fuzzy texture 疏松结构(搪瓷)
  • 熊猫宝宝
    第27楼2008/07/27
    g-line stepperg 线步进机
    G-valueG 值
    gable tile 山墙瓦
    gable wall 投料墙
    gadget 支架
    gaffer 吹制领班
    gage (gauge)1量规 2号规(线) 3样板
    gage length 标距
    gagger 撑条
    gaging 规测
    gain refiner 微晶剂
    galena 方铅矿(Pb S)
    gall 浮硝
    galleting 碎瓦片(陶)
    galling1(压紧面间)擦伤2吸住,紧贴
    gallium 金家
    gallium antimonide 锑化金家
    gallium arsenide 砷化金家(Ga As)(一种半导体)
    gallium phosphide 磷化金家(Ga P)(一种半导体)
    Gallo tannin acid 没食子酸
    galvanic action[ 丹尼尔]电池作用
    galvanic cell 化学电池
    galvanic corrosion 电池腐蚀
    Galvanic deposit 电[池性]沈积
    galvanic potential 电转电位
    galvanic series 电转序(电转电动势次序)
    galvanized iron 镀锌铁
    galvanized steel sheet 镀锌钢片
    galvanized steel wire 镀锌钢丝
    galvanizing 电积镀锌法
    galvanizing 热浸镀锌
    galvanizing 热镀锌法
    galvannealing 镀针退火
    galvanostatic polarization curve 电流恒定极化曲线
    Galvznizing 镀锌法
    galvznizing embritllement 镀锌脆性
    gamma brassγ 黄铜,咖玛黄铜
    gamma dispersionγ 色散,咖玛色散
    gamma ironγ 铁
    gamma loopγ 区,咖玛区
    gamma radiationγ 辐射,咖玛辐射
    gamma rayγ 射线
    gamma solid solution 咖玛固溶体
    gamma structure 咖玛结构
    gamma-radiographyγ 射线照相术,咖玛射线照相术
    gamma-ray fluoroscopyγ 玛对线萤光照相检验
    gamma-rays 咖玛射线(波长小於0.5A 之电磁辐射线)
    gang bonding 多端子接合
    gangue 脉石
    ganister 矽石
    gap frame press 弓架压机
    gap grading 不连续粒度
    Gardner mobilomete 贾得纳流度计
    Gareis—Endell plastometer 贾恩塑性计
    garnet 石榴石
    gas adsorption method 气[体]吸附法
    gas box 瓦斯筒收纳箱
    gas carburizing 气体渗碳法
    gas centrifuge process 气体离心法
    gas classification 气体分级法
    gas coke 煤气焦碳
    gas concrete 充气混凝土
    gas constant 气体常数
    gas cutting 焰割
    gas cyaniding 气体氰化法(碳氮处理)
    gas feed system 瓦斯输送系统
    gas hole 气孔
    gas law 体定律
    gas permeability 透气性
    gas pickling 气(体)浸(渍)法
    gas porosity 气体孔隙率
    gas pressure bonding 高温气的等压法
    gas source molecular beam epitaxial growth system 瓦斯源分子束磊晶生长系统
    gas turbine 燃气涡轮机
    gas welding 气体熔接,气焰熔接
    gas-cooled reactor 进步型气冷反应器
    gas-cooled reactor 气体冷却反应器
    gas-shielded arc welding 气护电弧熔接
    gaseous diffusion process 气体扩散法
    gasket corrosion (crevice corrosion)隙腐蚀 (裂隙腐蚀)
    gassing of copper 铜之汽损
    gassy surface 疏松结构
    gate1 进模口2闸
    gate array 闸门阵列
    gate cutting 切断成型铸模树鲁流导闸门之残留树脂
    gate insert piece 插入闸门之分割用隔片
    gate level description 闸门位阶记述
    gate stick 浇道棒
    gate value 栅型阀
    gather 蘸料
    gather hole 蘸料口
    gating system 浇注系统
    Gaudin's equation 高丁公式
    gauge 曲脚
    gauge factor 磨度计因数
    gauge length 标距
    gauging of cement 水泥稠度标准化
    Gauss 高斯(磁感应或磁场强度单位)
    Gazal process 盖撒法
    Ge-Si alloys 锗矽合金(热电材料)
    gear bronze 齿轮青铜
    Geiger counter 盖氏计数器
    Geiger-Mueller counter 盖格-密勒计数器
    gel 凝胶,乳胶体
    gelatine, gelating 明胶
    general attack 主面侵蚀
    geochemistry 地质化学
    Geomagnetic field 地磁场
    Georgian glass 方网玻璃
    Gerber's law 盖柏定律(有关疲劳行为)
    German silver (nickel silver)德银(α相之铜镍针合金);白铜,洋银
    germanium nitride 氮化锗
    germanium oxide 氧化锗
    Germanuium (Ge, 32)锗
    Germination 伟晶作用
    Gero degassing process 吉罗去气法
    Getter 收气剂
    gettering 吸器,除器
    getting 采掘
    Ghost band (ghost line)魔带,魔线
    Gibbs free energy 吉布自由能
    Gilard &Dubrul factor 吉杜因数(玻)
    Gilding 镀金
    gilding bronze 拟金黄铜(含 5%
    Zn 之黄铜)
    Gillmore needle 吉摩针(泥)
    Gilt 包金件(以薄金属被覆之银或其他非铁金属)
    glaceramic 玻陶
    Glaging 上釉
    glass 玻璃
    glass enamel 玻璃珐琅彩料
    glass eye 玻泡(玻)
    Glass fiber 玻璃纤维
    glass fibre 玻璃纤维
    glass fost 玻白
    glass frit sealing equipment 玻璃料密封装置
    glass house 玻璃工场
    Glass naol 玻璃绒
    glass to metal seal 玻金封点(玻)
    glass transition temperature 玻璃转换温度
    glass-bonded mica 玻结云母
    glass-coated steel & glass-lined steel 玻衬器皿
    glass-forming engobe 玻化化粧土
    Glassy (amorphous)玻璃质(非晶质)
    glaze 釉(陶)
    glaze fit 釉适性(陶)
    glazer 火焰磨光炉;磨光机
    glazes 釉彩
    glazing 上岫;施釉(从化工)
    Glide plane 滑动面
    Glo-crack 萤光示裂法
    global 总体
    global alignment 全晶圆对准
    global backside indeal range 总体背面理想范围
    global backside variation 总体背面理想范围
    global flatness 总体平面度
    global leveling 全晶圆调平
    global tilting 全晶圆倾斜转动
    Globar 格罗棒(碳化矽电热棒)
    Globular cenentite 球状雪明碳铁
    Globular pearlite 球状波来体
    Globurizing 球状化
    glory hole 小烘炉
    gloss 光泽
    gloss point 岫熔点
    glost0fire 岫烧
    Glow discharge nitriding 辉光放电氮化
    glut arch 焚口(陶)
    GO/NO-GO test 性能良?判定试验
    gob 玻璃膏球
    gob process 玻器制法
    Goggles 护目镜
    Gold (Au, 79)金
    gold bronze 金色青铜(α\铝青铜,今3-5%Al 其余为Cu)
    gold decoration 金饰(陶)
  • 熊猫宝宝
    第28楼2008/07/27
    Gold leaf 金叶(3-5
    X10-6inch 原金箔)
    gold rubyglass 金赤玻璃
    gold scouring 刮亮
    Goldchmidt Thermit process 戈德史密特铝热法
    goldstone glaze 金路岫
    Gonell air elutriator 哥涅淘析机
    Goniometer1 测塞器 2 测向仪
    Goodmans law 古德曼定律(疲劳行性)
    Goskar dryer 哥斯卡乾燥机
    Gothic pitch 哥德斜度
    Gottignies kiln 哥近尼[多隧]窑
    Gouge 半圆凿
    gouging test 抗磨试验(搪)
    Gradation 级配
    grade 等级
    Graded aggregate 级配骨材
    Graded standard sand 级配标准沙
    Gradient 梯度,倾差
    gradient freeze method 凝固温度梯度法
    Gradient mold 斜度模铸锭模
    Grading 分级
    grading analysis 级配分析
    Grading curve 级配曲线
    grading incidence interferometer method 倾斜入射干涉计法
    Graduating 刻度
    grain 晶粒
    Grain boundary 晶[粒境]界
    Grain boundary attack 晶界侵蚀
    Grain boundary reaction 晶界反应
    Grain coarsening 晶粒粗化
    Grain coarsening temperature 晶粒化温度
    Grain contrast 晶粒[反光]对比
    Grain fineness number 颗粒细度
    grain grit 粗粒;磨粒粒度
    Grain growth 晶粒生长
    grain of maximum size 最大魔粒
    grain percentage 魔粒率;磨料百分比
    Grain refinement 晶粒微化
    Grain refining 晶粒微化
    Grain refining temperature 晶粒微化温度
    Grain size 晶粒度,晶粒大小
    grain size analysis 粒度分析
    Grain structure 晶粒组织
    graininggraining oxide Gram-atom 克原子
    Granite 花岗石
    granite ware 斑点单轴搪瓷
    Granodising 锌面磷酸盐(黑层)处理
    granular activated carbon 颗粒状活性碳
    Granular pearlite 粒状玻来铁
    Granular power 粒状粉未
    Granulated slag 粒状熔渣
    Granulation 粒状化,造粒
    Granulation method 粒化法,造粒法
    Graphite 石墨
    Graphite carbon 石墨碳
    Graphite corrosion 石墨腐蚀
    Graphite crucible 石墨坩埚
    Graphite electrode 石墨电极
    Graphite flake precipitation 片状石墨析出
    graphite heater annealer 石磨加热器退火处理机
    Graphite steel 石墨钢
    Graphite, rosette 菊花状石墨
    Graphite-claybrick 石墨黏土砖
    Graphitization 石墨化
    Graphitizer 石墨化促进剂
    Graphitizing anneal 石墨化退火
    Graphitizing inoculant 石墨化接种剂
    Graphtic, embrittlement 石墨脆他
    Grate1 炉条 2隔栅
    Graticude 影规(化学镜头中之十字线刻度)
    Gravimetric method 重量法
    Gravity casting 重力铸造
    Gravity die casting 重力金属模铸造法
    Gravity drop hammer 自落鎚
    gravity filter 重力过滤器
    gravity process 玻膏滴制法
    Gravity segregation 垂力偏析
    Gravity sintering 重力烧结
    gray scale pattern recognition 灰色标度器案识别
    Gray [cast] iron 灰口铸铁
    Grazed brick 釉砖
    grazing 衬垫表面剥落
    green 生坯
    Green casting 生铸件(未热处理之铸件)
    Green compact 生压胚
    Green density 粉胚体密度(粉未冶金)
    green house 生坯间(陶)
    Green permeability 湿砂透气性
    Green pressing 生压胚
    Green rot 线朽铬线(含高镍之镍铬合金之一种高温腐蚀现象)
    Green sand 湿模砂
    Green sand mold 湿砂模
    Green sand molding 湿砂造模法
    green spot 深斑
    green strength 生坯强度(陶)
    Green strentgth 湿砂强度
    Green-tin 灰锡(锡在-13.2。C以下所成之硬脆钻石形结构)
    green-ware 生坯
    Greninger chart 格林氏图
    Grerin forming 盖瑞成形(在压模及橡皮垫间金属片成形之专利名称)
    Grey cast iron 灰口铸铁
    Grey pig iron 灰品生铁
    Griffith Crack Theory 格利菲(潜在)裂痕定理
    Griffith cracks 郭氏裂纹(玻)
    Grillo process 葛利罗法
    Grindability 易磨性
    Grinding 研磨
    Grinding aid 研磨助材
    Grinding burn 研磨烧仿(局部过热产生裂缝)
    Grinding crack 磨夸
    grinding machine 研磨机
    grinding wheel 磨轮;砂轮(陶)
    grinding with electrolytic inprocess dressing 电解研磨修整
    Grip slide 夹持滑块
    Gripper die 夹持模
    grisaille 影青法(陶)
    Grit1 粒2粒度
    Grit blosting 喷粒碍理
    grits 粒度
    Grizzly 栅筛
    Grog 烧料,熟料(经煆烧之一种非塑性材料)
    grogs 烧粉
    grooved roller 凹沟滚轮
    Grooving corrosion 沟蚀
    Gross heating value 总热量
    ground etctrode 接地电极
    ground laying 撒粉着色[法](陶)
    ground mass 基料
    ground-coat 底涂(珐琅)
    ground-hog kiln 艺陶窑
    Group displacement law 移族定律
    Grout 水泥浆
    Grout malding 水泥浆造模法
    Grouting agent 灌浆助剂
    growing crystal diameter 生长中结晶直径
    Growth 生长,胀大
    Growth of bubble 气泡生长
    Growth of cast iron 铸铁生长
    growth rate 生长速率
    Grtaphitizing inoclation 石墨化接种
    guide pulley 导线滑轮
    Guide roll 导辊
    guide roller 导线滚轮
    guide tube 导管
    Guillet diagram 吉利氏图
    guillet equivalent 超利氏当量(黄铜锌当量)
    Guillotine shears 框氏截剪机
    Guinier Preston zone (G.P. zone)G-P 层,G-P 带 Guinier-Preston (G-P) zone G-P 带G-P 层
    Gun metal 炮铜
    Gunite[ 喷涂用]水泥浆
    gunning 射补[法]
    Gypsum 石膏
    Gypsum cement 石膏水泥
    Gypsum mold 石膏模
    Gypsum pattern 石膏模型
  • 熊猫宝宝
    第29楼2008/07/27
    H steelH 钢(硬化能带钢)
    H-bandH 带(硬化能带
    Harden ability Band)
    H-beamH 型梁
    H-MonelH 蒙镍合金
    H.A.Z. crack (heat affected zpne crack)热影响区裂痕
    habit plane 晶癖面
    hack 格架
    Hacksaw 弓锯
    Hadfield [manganese] steel 哈德菲[高锰]钢
    hafnium (Hf,72)金合
    Haigl machine 海氏疲劳试验机
    hair crack 毛裂,毛状微裂痕
    hair line 毛纹
    Hair seam 毛状叠纹
    half cutting 半厚度切割
    Half dislocation 半差排
    Half life 半衷期
    Half martensite 半麻田散体
    Half nut 对开螺帽
    Half thickness 半阻厚度(核子_)
    half-bat 半砖
    Half-hard cold work 全硬级冷加工
    halite 岩盐
    Hall coefficient 哈耳系数
    Hall effect 哈耳效应
    Hall process 哈耳法
    halloysite 多水高岭土
    halogen lamp annealer 卤素灯退火处理机
    Halogen leak detector 卤素测漏器
    Hammer 鎚
    Hammer dies 鎚模
    hammer mill 鎚碎机
    Hammer weld 锻接
    Hammer, air 空气鎚
    Hammer, air-driven 气动鎚
    Hammer, air-lift gravity drop 气提自落鎚
    Hammer, beit 皮带鎚
    Hammer, belt drop 皮带落鎚
    Hammer, board 板鎚
    Hammer, board drop 板落鎚
    Hammer, C-frame 弓架鎚
    Hammer, counterblow 对击鎚
    Hammer, crusher 鎚碎机
    Hammer, double frame 双架鎚
    Hammer, double-arch 双拱鎚
    Hammer, drop 落鎚
    Hammer, float die 平模鎚
    Hammer, forging 锻鎚
    Hammer, gravity drop 自落鎚
    Hammer, hardening 鎚击硬化
    Hammer, pneumatic 气动鎚
    Hammer, power 动力鎚
    Hammer, power drop 动力落鎚
    Hammer, rod 杆鎚
    Hammer, rod drop 动力杆落鎚落鎚
    Hammer, single frame 单架鎚
    Hammer, single-arch 单拱鎚
    Hammer, single-blow 单击鎚
    Hammer, steam 蒸汽鎚
    Hammer, steam drop 蒸汽落鎚
    Hand bellow 手风箱
    Hand charging 手工加料
    hand core/soft core 硬体核心/软体核心
    Hand forging 手锻
    Hand molding 手造模
    handler 程序处理机
    Hanover metal 汉诺威金属(轴承金属8%Sb, 5%Cu, 其余为Sn)
    Hansgrig magnesium process 汉斯格里炼镁法
    Hard chrome plating 镀硬铬
    Hard coke 硬质焦[碳]
    Hard cold work 硬级冷加工
    Hard drawing 硬拉,硬抽
    Hard drawn wire 硬拉线
    hard macro cell 硬性巨集功能电路胞
    Hard magnetic material 硬磁材料
    Hard metal 硬金属(黏结碳化物另一名称)
    hard soldening 硬焊
    hard solder 硬焊料
    Hard steel 硬钢
    Hard water 硬水
    Hard zone cracks 熔接区裂纹
    hard-bake 硬性烘烤处理
    Hard-drawn steel 硬拉钢
    Hard-facing[ 加焊]硬面法
    hardenability 硬化能
    Hardened steel 硬化钢
    Hardened structure 硬化组织
    Hardener 硬化剂
    Hardening 硬化
    Hardening agent 硬化剂
    Hardening capacity 硬化能
    Hardening crack 硬化龟裂
    Hardening furnace 淬火炉
    Hardening penetration 硬化深度
    Hardening temperature 硬化温度
    Hardening thickness 硬他厚度
    Hardness 硬度
    Hardness factor 硬度因数
    Hardness test 硬度试验
    hardware bronze 器皿青铜
    hardware description language 硬体记述语言
    hardware/software co-design 硬体/软体协同设计
    hare's fure glaze 兔毫岫
    Harris process 哈举斯法
    Hartman lines 哈特曼线(即
    Luder's line)
    Hastelloy 赫史特合金(镍基耐酸耐热合金)
    haydite 海德石(从矿)
    Haynes alloy 海恩斯合金
    haze 雾状
    Hazelett stripcasting machine 赫兹莱特铸片机
    head 头部
    Headability 锻粗性
    Header 锻粗机
    Header slider (on upsetters)锻粗滑块 (锻粗机)
    Heading 锻粗
    Health hazards 健康危害
    Heap leaching 堆集浸滤,堆集浸洗
    Hearth 炉膛
    Heat balance 热平衡
    heat block 加热组合单元
    heat capacity 热容量
    Heat checking 热裂
    Heat content 热含量
    Heat cycle 热循环
    Heat exchanger 热交换器
    Heat flow 热流
    Heat insulating brick 隔热砖
    heat insulation plate 隔热板
    Heat loss 热(量)损失
    Heat of formation 生成热
    Heat of friction 摩擦热
    Heat of fusion 熔解热
    Heat of hydration 水化热
    Heat of reaction 反应热
    heat oven 乾燥炉
    heat plate 加热板
    Heat recovery 热回收
    Heat resistant alloy 耐热合金
    Heat resistant casting 耐热铸件
    heat resistant steel 耐热钢
    Heat resisting cast iron 耐热铸铁
    Heat resisting cast steel 耐热铸钢
    Heat resisting steel 耐热铸钢
    Heat shock 耐震
    Heat sink 散热体
    Heat spotting 局部热处理
    Heat tinting 热蚀法
    Heat transfer 热传递
    Heat transfer coefficient 热传递系数
    Heat transmission 热传递
    Heat tratable alloy 可热处理合金
    Heat tratment 热处理
    Heat treating film 热处理膜
    heat treatment 热处理
    Heat treatment furnace 热处理炉
    heat up stage 加热夹片台
    heat value 热值
    Heat-affectred zone 受热变质区
    Heat-treated structure 热处理织
    heat-work 热功
    heated capillary shank 毛细管压接加热柄
    heated wedge shank 楔型压接加热柄
    Heating element 发热元件
    Heating process 加热过程
    Heating rate 加热速率
    Heating temperature 加热温度
    Heating time 加热时间
    Heating warpage test 加热翘幽试验
    Heating zone 加热区
    Heavy metal 重金属
    Heavy modia separation 重介质分离
    Heavy weight concrete 重质混凝土
    Hecnum 海克能合金(含55%Cu, 45%Ni 电阻用合金)
    Hegeler roaster 海格勒焙烧机
    Heisenberg uncertainty principle 海森堡不确定原理
    helical etching system 螺旋型蚀刻系统
    helicon etching system 螺旋波蚀刻系统
    Helium (He,2)氦
    Helium leak detector 氦测漏器
    Helium leak-test 氦漏气试验
    Hematite 赤铁矿
    Hematite pig iron 赤铁矿生铁
    Hemming 摺边
    Henderson cinder roasting process 汉得逊结块焙烧法
  • 熊猫宝宝
    第30楼2008/07/27
    Henry's activity 亨利活性
    Henry's constant 亨利常数
    Henry's law 亨利定律
    Herber hardness tester 哈柏特硬度试验机
    Herculoy 赫可金金(一种矽青铜)
    hercynite 热铝尖晶石
    hermetic seal 密封
    Heroult electric arc furnace 海洛式电弧炉
    Herrenschmidt furnace 海仑斯密特炉
    Herreschmidt process 海仑斯密特法
    Herreshoff roaster 哈里肖夫焙烧机
    Hess's law 海斯定律
    Heterogeneity 非均质
    Heterogeneous materials 非均质材料
    Heterogeneous nucleation 非均质成核
    Heterogeneous reaction 非均质反应
    Heterogeneous structure 非均质组织
    Heusler alloy 豪斯勒合金(一种强磁性非铁合金)
    Hexagonal close-packed lattice (hcp)六方密格子
    Hexagonal indices 六方指标
    Hexagonal system 六方晶系
    hexode type reactive ion etching system 六角柱型反应性离子蚀刻系统
    Heyn stress 海恩应力(金属晶粒内微观残留应力)
    HF added pure water 添加氢氟酸纯水
    HF vapor cleaning equipment 氢氟酸蒸汽洗条设备
    hi tile 肩脊瓦
    Hidurax 希杜拉合金(一种复杂铝青铜)
    hierarchical design 阶层式设计
    High bainite (upper bainite)上变勒体
    high brass 高黄铜
    High carcon steel 高碳钢
    high current ion implanter 大电流离子值入机
    high density plasma enhanced CVD 高密度等离子体增强型
    CVD High duty cast iron 高强铸
    High duty fire clay 高级耐火粘土
    High duty fire clay brick 高粘土质耐火砖
    High duty fire clay refractory 高级粘土质耐火材料
    High duty silica brick 高级矽砖
    high energy ion implanter 高能量离子值入机
    High expansion steel 高膨胀钢
    high frequency test head interface 高频测试头介面
    high frequency ultrasonic bonding 高频超音波接合
    high level description language 高阶记述语言
    high level synthesis 高阶合成器
    High power direct arc electric furnace 高电力直接电弧炉
    high pressure Czochralski method 高压CZ 法
    high pressure jet spray 高压喷射喷雾机
    high pressure method 高压法
    High pressure operation 高压操作
    high pressure thermal oxidation furnace 高压热氧化炉
    High siliceous brick 高矽质砖
    high speed buffer memory 高数缓冲记忆器
    high speed circuit technology design 高速电路工程设计
    high speed steel 高速钢
    High test cast iron 高级铸铁
    high vacuum method 高真空法
    high voltage electron micro-scopy 高压电子显微镜学
    high voltage electron microscopy 高压电子显微镜学
    high voltage terminal 高压端子
    high wind velocity burn-in system 高风速老化测试系统
