何当奇
第21楼2008/10/21
METHOD III (GRAVIMETRIC)
Procedure for Chemicals— Proceed as directed in the individual monograph preparing the chemical as directed under Loss on Drying 731 .
Procedure for Biologics— Proceed as directed in the individual monograph.
Procedure for Articles of Botanical Origin— Place about 10 g of the drug, prepared as directed (see Methods of Analysis under Articles of Botanical Origin 561 ) and accurately weighed, in a tared evaporating dish. Dry at 105 for 5 hours, and weigh. Continue the drying and weighing at 1-hour intervals until the difference between two successive weighings corresponds to not more than 0.25%.
方法III(重量分析法)
化学药品的操作---参照各论所示进行操作,准备化学药品如干燥失重所示。
生物药品的操作---参照各论所示进行操作。
植物起源的药品的操作---参照(植物起源的药品<561>的分析方法)所示,准备10g药品,准确称量,置一个去皮重的蒸发皿中。于105℃干燥5小时,称重。继续干燥,间隔1小时后称重,直到连续两次称重的差别不超过0.25%。
影子
第30楼2009/02/20
请教有过操作经验的各位:
一原料药,水分含量应不超过1%,按USP规定应该用酒石酸钠作为水标准物质标定F值,但当我按上述操作程序标定时,却发现消耗的卡尔试剂非常少,因此计算出来的F值过大(超过20),这显然是失真的;我直接用水作标准物质标定出的F值一般在3点几。标定时所用溶剂均为甲醇,请大家帮我分析下这是什么原因?
