学无止境
第19楼2010/12/01
欧盟1935-2004-EC中有这么一个条款
Article 3
General requirements
1. Materials and articles, including active and intelligent mate-
rials and articles, shall be manufactured in compliance with good
manufacturing practice so that, under normal or foreseeable con-
ditions of use, they do not transfer their constituents to food in
quantities which could:
(a) endanger human health;
or
(b) bring about an unacceptable change in the composition of
the food;
or
(c) bring about a deterioration in the organoleptic characteris-
tics thereof.
要求不会对食物成分发生改变,不会导致感官的劣变,
这个算是对感官的要求吧
vic
第20楼2010/12/02
如果脱色程度很轻,应该不算感官的劣变,严重的脱色可以判Fail。
感官测试也是有等级的区别的。。。
