用Digitalmicrograph做粒径分析,到analyze particles时,跳出窗口:An expected error has prevented the operation from finishing(internal failure),然后不能进行下去,这是怎么回事?给工程师打电话,只说这种分析可能不稳定、不可靠
urumqi发表:用Digitalmicrograph做粒径分析,到analyze particles时,跳出窗口:An expected error has prevented the operation from finishing(internal failure),然后不能进行下去,这是怎么回事?给工程师打电话,只说这种分析可能不稳定、不可靠
