heguang
第14楼2011/04/13
用专门做中性化合物的试剂盒
Separation of Neutral Compounds by CE using CElixir-SDS™
Neutral compounds normally migrate with the Electro-Osmotic Flow (EOF) in CZE. Using the proper buffer additives, MEKC can employed and neutral compounds can be separated along with charged molecules. This pre-made 搗alidated? kit makes MEKC easy to perform, reliable and a powerful addition to any laboratory taking advantage of the power and advantages of CE.
Method Conditions: Catalog No.: 06200-50 Supplied Buffers and Solutions were used without modification Voltage: 25kV Capillary: MicroSolvCE™ Bare Fused Silica, 75祄 x 60cm Injection: 5 sec, 0.5psi followed by post injection Water Plug Run Buffer: CElixir-SDS Accelerator™ 50-50 Borate pH 9.2 Detection: UV, 200nm Polarity: Normal |
cissie-1986
第17楼2011/04/15
谢谢,我的药物中还有一个是可以在碱性条件下电离的,打算做多种一起分离,你的意见我会好好学习一下的,如果有不太明白的地方可能还要打扰到你麻烦了
cissie-1986
第18楼2011/04/15
I agree with you, but when I tried the borate buffer with pH between 9 to 10, the medicine is also invoved in the methanol. So I feel so depressed.
heguang
第19楼2011/04/15
Be careful, some compounds can dissolve in high pH buffer, but it will encounter the danger of decompose in high pH.
