Yes , this 直接固体原子吸收光谱法 was the topic for the past 20 years, still going;
this 连续光源原子吸收光谱法 is new technique especially for manufacturer of AAS; including optical system renovation,electronic control and signal collection system renovation. We can have details in the future - 完全可以独立一个讲座来进行的!
双面娃娃(xiashi120) 发表:十二、直接固体原子吸收光谱法
十五、连续光源原子吸收光谱法
原子吸收光谱的发展趋向于两个方向,poplar_yang老师,如果能将其细化分析介绍,完全可以独立一个讲座来进行的~~
期待能有更多更详细的介绍~~
