poplar_yang
第51楼2011/04/14
sample which is not easy to grind; fg, ash fly; quartz; quarry; metal; ore; etc.
sample which is not easy to digest: fg, food, slag, residue; etc.
sample which you do not want to waste your time of acid digestion
样本不容易磨: 灰分飞;石英;采石,金属,矿石,等等样本是不容易消化: 食品,矿渣,残留,等等样品,你不想浪费你的时间酸消化
poplar_yang
第57楼2011/04/14
simply to understand , the 连续光源 is one spare part of this machine, before we use one wavelength beam, now we have a scan; this spare part was first used in physics, optics, 天文望远镜, then later somebody used it into UV, then into ICP, now it is time to use it into AAS
poplar_yang
第59楼2011/04/15
for our AAS iCE3300, the acetylene 9psi and air 35 psi v.s 1 atm, so supposed the vacuum can be maximum 35psi or minimum 9psi for sample introduction.
如果将原吸雾化装置引入原子荧光系统,会出现怎样的结果, it will be no signal , because pressure too high and sample carrier run too fast.
