phillyrin
第11楼2011/05/12
常见的进口泵油,主要是edwards和inland的。具体标号如下:(两家使用的压力单位不同1torr=1mmHg=1.33mBar)
edwards
http://www.edwardsvacuum.com/uploadedFiles/Resource/Technical_Articles/How%20to%20Select%20the%20Right%20Vacuum%20Pump%20for%20the%20Application.pdf
谁能解释一下,为什么表格线都被吃掉了?
Ultragrade 15 | Ultragrade 19 | Ultragrade 20 | Ultragrade 70 | |
Vapor pressure mbar: | | | | |
20ºC | 5.8 x 10-6 | 1 x 10-8(个人认为这个标错了,应该是-6) | 2.1 x 10-7 | 2.1 x 10-7 |
100ºC | 3.0 x 10-2 | 1.0 x 10-3 | 3.0 x 10-3 | 3 x 10-3 |
Molecular weight | 385 | 420 | 500 | 600 |
Specific gravity at 15ºC | 0.86 | 0.86 | 0.86 | 0.86 |
Viscosity cSt: | | | | |
at 20ºC | 104.2 | 143.7 | 352 | 222 |
at 40ºC | 38.1 | 48.6 | 103 | 70 |
Pour point ºC | -18 | -16 | -12 | -12 |
Flash point ºC | 220 | 230 | 260 | 230 |
Auto ignition point ºC | 355 | 355 | 365 | 360 |
Sulphur content % mass/mass | 0 | 0 | 0 | 0 |
Specification | INLAND 15 ULTRA | INLAND 19 ULTRA | INLAND 20 ULTRA | INLAND 70 ULTRA |
Vapor Pressure @ 25ºC | <1x10-6 torr | <1x10-6 torr | <1x10-7 torr | <1x10-7 torr |
Boiling Pt. @ .01 torr | 159ºC | 166ºC | 168ºC | 166ºC |
Viscosity @ 40ºC | 37 cSt | 55 cSt | 110 cSt | 72 cSt |
Pour Pt. | -15ºC | -10ºC | -9ºC | -10ºC |
Flash Pt. | 233ºC | 247ºC | 252ºC | 249ºC |
Density | 0.86 g/ml | 0.86 g/ml | 0.86 g/ml | 0.86 g/ml |
Color | clear | clear | clear | clear |
Product | Vapor Pressure @ 25ºC (torr) | Boiling Point @ .01 torr (ºC) | Viscosity @ 40ºC | Pour Point (ºC) | Flash Point (ºC) | Fire Point (ºC) | Density @ 25ºC (g/ml) |
Inland TW | <1x10-6 | 158 | 65 | -12 | 243 | 270 | 0.86 |
Inland HVTW | <1x10-7 | 161 | 106 | -12 | 249 | 277 | 0.86 |
Inland 19 | 1x10-5 | 112 | 55 | -15 | 213 | 244 | 0.87 |
Invoil 20 | <1x10-6 | 127 | 58 | -10 | 224 | 259 | 0.87 |
Convoil 20 | <1x10-6 | 120 | 71 | -7 | 226 | 266 | 0.88 |
Inland 21 | 3x10-5 | 112 | 55 | -15 | 213 | 244 | 0.87 |
Inland 33 | <1x10-6 | 166 | 67 | -10 | 247 | 275 | 0.86 |
Inland 35 | <1x10-7 | 168 | 115 | -9 | 252 | 281 | 0.86 |
Inland 43 | 2x10-4 | 95 | 68 | -10 | 230 | 250 | 0.88 |
Inland 45 | <1x10-7 | 133 | 53 | -59 | 264 | 288 | 0.83 |
Inland 45Z | <1x10-7 | 137 | 67 | -55 | 285 | 305 | 0.83 |
Inland 77 | <5x10-5 | 138 | 100 | -9 | 257 | 291 | 0.88 |
Inland 87 | <1x10-4 | 100 | 175 | -29 | 210 | >240 | 0.89 |
Inland 97 | <4x10-4 | 158 | 207 | -12 | 235 | 277 | 0.90 |
Inland 220 | <1x10-5 | 107 | 47 | -20 | 225 | none | 1.150 |
Inland 300 | <1x10-5 | 100 | 65 | -1 | 240 | none | 1.151 |
Inland 550 | <1x10-5 | 116 | 117 | -7 | 246 | none | 1.155 |
