peterhello
第20楼2012/03/02
[/quote]
"单个分子流经光路的时间变短,其吸收紫外光的能量减少" >
[/quote][/quote]
[/quote][/quote]
如果照这么说放在紫外分光光度计中的样品吸收值将随时间变化,只要不把比色皿取出来,吸收值就会越来越高了?
A=ELC和时间完全没有关系
样品区带体积一定,通过体积更小的流通池,时间必然更长.所以流通池体积要和峰容量相匹配
As a rule-of-thumb the flow cell volume should be about 1/3 of the peak volume at half height. To determine the volume of your
peaks, take the peak width as reported in the integration results multiply it by the flow rate and divide it by 3).
流通池体积不是越小越好,也不是越大越好.
