reagentlife
第21楼2012/12/04
赞同,顺便把国外标液生产商提供的计算方法供大家参考下,感谢众老师和专家答疑解惑啊。
问题:
I have a question--how do you prepare 100ml of 5% HNO3 as your matrix through using 65% HNO3? Pls give me your
caculation so that I have know more and tell the customer how to dilute its standard solutions.
国外回复:
The 5% HNO3 of 100 ml is based on the volume. So you add 5 ml of concentration HNO3 (65% HNO3) to water into the
gravemetric clean flask, then dilute to 100 mL mark line on the flask. This will make up 5% HNO3.
Hope this help.
依风1986
第23楼2012/12/05
看来大家把简单问题想得过于复杂了!
