tent
第15楼2006/10/10
It should be something wrong with your TEM hardware. I often adust the ronchigram and its stigmation at about 10k magnification on the little screen. There is no obvios different with high magnification. And the contamention will be less in low magnification and easy to find amorphous area to do ranchigram and stigmator adustion.
