zoujiasu
第31楼2014/07/21
同样遇到RF自检错误,自检信息如下。大侠能看看RF哪个版块出问题了不?
CPU test: PASSED
Power test: (5 May 2014 11:21:30)
Power PCB +5V Digital reads 4.9 Volts -> Passed
Power PCB +5V Analog reads 5.0 Volts -> Passed
RF PCB -5V Analog reads -5.1 Volts -> Passed
Power Board +5V Reference reads 5.0 Volts -> Passed
Power PCB +12V reads 11.6 Volts -> Passed
Power PCB -12V reads -11.9 Volts -> Passed
RF PCB +24V Protected reads 22.9 Volts -> Passed
RF PCB -24V Protected reads -22.9 Volts -> Passed
Power PCB 24V Valve Power reads 22.5 Volts -> Passed
Power PCB Line Voltage reads 220.1 Volts -> Passed
Power PCB Battery Voltage reads 10.0 Volts -> Passed
RF PCB +33V reads 32.7 Volts -> Passed
RF PCB -33V reads -32.7 Volts -> Passed
RF PCB +338V High mass DC reads 337.1 Volts -> Passed
RF PCB -338V High mass DC reads -341.3 Volts -> Passed
Power test: PASSED
Heater test: (5 May 2014 11:22:49)
Manifold Heater OK
Source Heater OK
Transfer Line Heater OK
Heater test: PASSED
CPU test: (5 May 2014 11:23:06)
CPU test: PASSED
Power test: (5 May 2014 11:23:06)
Power PCB 24V Valve Power reads 21.5 Volts -> Passed
Power PCB Line Voltage reads 220.3 Volts -> Passed
RF PCB -33V reads -32.8 Volts -> Passed
Power test: PASSED
User dacs test: (5 May 2014 11:23:36)
User DAC 1 OK
User DAC 2 OK
User dacs test: PASSED
Heater test: (5 May 2014 11:24:13)
Manifold Heater OK
Source Heater OK
Heater test: PASSED
Valve test: (5 May 2014 11:24:13)
Valve 2 passed
Valve test: PASSED
Lens test: (5 May 2014 11:24:18)
Lens 1 set to 0 V and reads back -1 V --> Passed
Lens 1 set to 30 V and reads back 28 V --> Passed
Lens 1 set to 60 V and reads back 58 V --> Passed
Lens 1 set to 90 V and reads back 88 V --> Passed
Lens 1 set to 120 V and reads back 118 V --> Passed
Lens 1 set to 150 V and reads back 147 V --> Passed
Lens 1 set to -30 V and reads back -12 V --> Test Failed
Lens 1 set to -60 V and reads back -12 V --> Test Failed
Lens 1 set to -90 V and reads back -12 V --> Test Failed
Lens 1 set to -120 V and reads back -12 V --> Test Failed
Lens 1 set to -150 V and reads back -12 V --> Test Failed
Lens 1 Failed
Lens 2 set to 0 V and reads back 0 V --> Passed
Lens 2 set to 30 V and reads back 30 V --> Passed
Lens 2 set to 60 V and reads back 61 V --> Passed
Lens 2 set to 90 V and reads back 91 V --> Passed
Lens 2 set to 120 V and reads back 121 V --> Passed
Lens 2 set to 150 V and reads back 151 V --> Passed
Lens 2 set to -30 V and reads back -12 V --> Test Failed
Lens 2 set to -60 V and reads back -12 V --> Test Failed
Lens 2 set to -90 V and reads back -12 V --> Test Failed
Lens 2 set to -120 V and reads back -12 V --> Test Failed
Lens 2 set to -150 V and reads back -12 V --> Test Failed
Lens 2 Failed
Lens 3 set to 0 V and reads back -1 V --> Passed
Lens 3 set to 30 V and reads back 29 V --> Passed
Lens 3 set to 60 V and reads back 59 V --> Passed
Lens 3 set to 90 V and reads back 89 V --> Passed
Lens 3 set to 120 V and reads back 120 V --> Passed
Lens 3 set to 150 V and reads back 150 V --> Passed
Lens 3 set to -30 V and reads back -12 V --> Test Failed
Lens 3 set to -60 V and reads back -12 V --> Test Failed
Lens 3 set to -90 V and reads back -12 V --> Test Failed
Lens 3 set to -120 V and reads back -12 V --> Test Failed
Lens 3 set to -150 V and reads back -12 V --> Test Failed
Lens 3 Failed
Lens 4 set to 0 V and reads back -0 V --> Passed
Lens 4 set to 30 V and reads back 30 V --> Passed
Lens 4 set to 60 V and reads back 60 V --> Passed
Lens 4 set to 90 V and reads back 90 V --> Passed
Lens 4 set to 120 V and reads back 120 V --> Passed
Lens 4 set to 150 V and reads back 150 V --> Passed
Lens 4 set to -30 V and reads back -11 V --> Test Failed
Lens 4 set to -60 V and reads back -11 V --> Test Failed
Lens 4 set to -90 V and reads back -11 V --> Test Failed
Lens 4 set to -120 V and reads back -11 V --> Test Failed
Lens 4 set to -150 V and reads back -11 V --> Test Failed
Lens 4 Failed
Quad guide 1 set to 0 V and reads back -0 V --> Passed
Quad guide 1 set to 10 V and reads back 10 V --> Passed
Quad guide 1 set to 20 V and reads back 20 V --> Passed
Quad guide 1 set to 30 V and reads back 30 V --> Passed
Quad guide 1 set to 40 V and reads back 40 V --> Passed
Quad guide 1 set to 50 V and reads back 50 V --> Passed
Quad guide 1 set to -10 V and reads back -10 V --> Passed
Quad guide 1 set to -20 V and reads back -11 V --> Test Failed
Quad guide 1 set to -30 V and reads back -11 V --> Test Failed
Quad guide 1 set to -40 V and reads back -11 V --> Test Failed
Quad guide 1 set to -50 V and reads back -11 V --> Test Failed
Guide 1 Failed
Quad guide 3 set to 0 V and reads back -1 V --> Passed
Quad guide 3 set to 10 V and reads back 9 V --> Passed
Quad guide 3 set to 20 V and reads back 19 V --> Passed
Quad guide 3 set to 30 V and reads back 29 V --> Passed
Quad guide 3 set to 40 V and reads back 39 V --> Passed
Quad guide 3 set to 50 V and reads back 49 V --> Passed
Quad guide 3 set to -10 V and reads back -10 V --> Passed
Quad guide 3 set to -20 V and reads back -10 V --> Test Failed
Quad guide 3 set to -30 V and reads back -10 V --> Test Failed
Quad guide 3 set to -40 V and reads back -10 V --> Test Failed
Quad guide 3 set to -50 V and reads back -10 V --> Test Failed
Guide 3 Failed
Lens test: <<< FAILED >>>
RF test: (5 May 2014 11:24:44)
Quad 0 RF Dac OK
Quad 1 RF Dac OK
Quad 2 RF Dac OK
Quad 3 RF Dac OK
Quad 0 RF OK
Quad 1 RF OK
Quad 2 RF OK
Quad 3 RF OK
RF test: PASSED
DC Rod test: (5 May 2014 11:26:10)
Quad 1 RF/DC Correction OK
Plus Quad 0 driver set to -30 V read -13 V Failed! --> Test Failed!
Plus Quad 0 driver set to -60 V read -12 V Failed! --> Test Failed!
Plus Quad 0 driver set to -90 V read -13 V Failed! --> Test Failed!
Plus Quad 0 driver set to -120 V read -12 V Failed! --> Test Failed!
Plus Quad 0 driver set to -150 V read -13 V Failed! --> Test Failed!
Quad 1 DC- OK
Quad 1 DC+ OK
Quad 3 RF/DC Correction OK
Plus Quad 2 driver set to -30 V read -12 V Failed! --> Test Failed!
Plus Quad 2 driver set to -60 V read -12 V Failed! --> Test Failed!
Plus Quad 2 driver set to -90 V read -12 V Failed! --> Test Failed!
Plus Quad 2 driver set to -120 V read -12 V Failed! --> Test Failed!
Plus Quad 2 driver set to -150 V read -12 V Failed! --> Test Failed!
Quad 3 DC- OK
Quad 3 DC+ OK
DC Rod test: <<< FAILED >>>
Ion gauge test: (5 May 2014 11:26:43)
Ion gauge test: PASSED
filament test: (5 May 2014 11:26:44)
filament ok -- max error is 18uA - Switching filament off Leakage = 0uA
filament test: PASSED
API test: (5 May 2014 11:27:08)
Inlet board LED test -> Passed
Ci gas controller not tested -- not in CI mode
Probe inlet test skipped in field mode
Xfer Line Heater test passed
Probe test skipped in field
12V divider power supply read 1.6 V --> Passed
24V divider power supply read 1.4 V --> Passed
+5V power supply read 5 V --> Passed
CID gas on test -> Passed!
CID gas off test -> Passed!
CID gas Controller Test Passed!
RS232 test for manufacturing only
Inlet Control and API HV tests -> Passed
API test: PASSED
zoujiasu
第32楼2014/07/21
CPU test: PASSED
Power test: PASSED
Manifold Heater OK
Source Heater OK
Heater test: PASSED
CPU test: PASSED
Power test: PASSED
User DAC 1 OK
User DAC 2 OK
Manifold Heater OK
Source Heater OK
Heater test: PASSED
Valve 2 passed
Valve test: PASSED
Lens 1 Failed
Lens 2 Failed
Lens 3 Failed
Lens 4 Failed
Guide 1 Failed
Guide 3 Failed
Quad 0 RF Dac OK
Quad 1 RF Dac OK
Quad 2 RF Dac OK
Quad 3 RF Dac OK
Quad 0 RF OK
Quad 1 RF OK
Quad 2 RF OK
Quad 3 RF OK
RF test: PASSED
Quad 1 DC- OK
Quad 1 DC+ OK
Quad 3 DC- OK
Quad 3 DC+ OK
API test: PASSED
