stevenlang
第12楼2006/09/06
我也来试试,
色谱的历史
色谱-它代表什么意思?
逐字的翻译这个词可以从它的希腊字根:色彩和图谱上理解.色谱最初是由俄罗斯的植物学家Mikhail Tswett在1903年提出的,当时他利用一根填充有碳酸钙的柱子进行植物色素的分离,并用色彩来描述其结果.目前,色谱已经发展成为实验室用来分离和鉴别物质一种重要的工具.虽然色彩在这个过程中不再有任何意义,但是色谱的基本原理还是在广泛的应用.
为什么要使用色谱?
在这里答案就是用于分离.分离在实验中起什么作用呢?在任何一种化学分析中,化学物质的分离是至关重要的.当我们尝试去鉴定一种未知的物质时,样品首先要被分离成组成它的简单组分.然后通过对其组分的分析来认识它.这不是说那些组分经过分离和鉴定后,原来被鉴别的样品就可以恢复的.一般来说,这个过程是不可逆的.然后将被分离物与已知的标准相比较,便可做出判断.对于大多数的化学发现,怎么找出第一个要被分析的化合物极为重要.
crystal_cai
第15楼2006/09/07
History of Chromatography
色谱的历史
Chromatography -- what does it mean?
色谱--是什么意思呢?
To write with colors -- literally translated from its Greek roots chroma and graphein, chromatography was first developed by the Russian botanist Mikhail Tswett in 1903 as he produced a colorful separation of plant pigments through a column of calcium carbonate. Chromatography has since developed into an invaluable laboratory tool for the separation and identification of compounds. Although color usually no longer plays a role in the process, the same principles of chromatography still apply.
英文色谱这个词由希腊文字的字根色和图发展而来,字面的直译就是由颜色写成。1903年,俄罗斯植物学家Mikhail Tswett用碳酸钙柱分离植物色素时最早发现了色谱。自此色谱发展成为实验室化合物分离和鉴别的不可替代的重要工具,尽管颜色已不再在色谱技术中起作用,其基本原理依然适用。
Why use chromatography? The key here is separation. But what is the importance of separation in the lab?
为什么使用色谱呢?其关键在于分离,那么在实验室中,分离技术的重要性是什么呢?
Separation of chemical components is vital in any type of chemical analysis. When trying to identify an unknown substance, the sample must first be simplified as much as possible into its constituent compounds. The unknown can then be characterized by individual identification of its parts. This does not imply that the separated chemical components are recovered after the separation and analyzed. Usually, the analytes are irretrievable. Separated compounds are compared to known standards. As with most chemical exploration, it is important to have an idea of what compounds are being searched for in the first place.
在各种化学分析中,混合物各个成分的分离至关重要。当试图鉴别未知物质的时候,首先需要将混合物尽量分离成单一物质。然后可以用相应特定的鉴别方式来判断分离出的未知组分。这一过程并不意味着经过分离和分析过程是可逆的,通常,所有的分离出的分析物是不能再复原回原来的混合物的。最后将分离后的化合物与已知标准物进行比较。正如大多数的未知化学品鉴别,从一开始就对所测样品的可能组分有个大致的概念是非常重要的。
molybdenum
第16楼2006/09/07
色谱的历史
色谱——它的意思是什么呢?从它的希腊词根'chroma'和'graphein',逐字翻译过来就是:用颜色来记录。色谱最先由俄罗斯植物学家Mikhail Tswett于1903年提出,当时他通过一根碳酸钙柱子使植物叶绿素产生了色带分离。之后,色谱发展成为实验室化合物分离和鉴定的无比宝贵的工具。尽管颜色在色谱分析过程中大抵不再发挥作用,但相同的色普原理依然在使用。
为什么使用色谱呢?此处的关键在于分离。那么,实验室内分离的重要性是什么呢?
在任何类型的化学分析中,化学组成的分离是至关重要的。当试图鉴别一种未知物时,首先必须将该样品尽可能的纯化为它的组分化合物。然后,该未知物才能被其部分组分的特殊标识表征出来。但这并不意味着经过分离和分析后被分离的化学组分可以再生。通常情况下,被分析物是不可复原的。被分离的化合物被用来与已知的标准物进行对比。由于使用了大部分化学探测方法,因而知道哪一个是首要寻找的化合物非常重要。
在原来的基础上【10楼】修改了一下,请楼主多给点修改意见,本人正在努力学习英语ing。。。
fwz123657
第17楼2006/09/07
色谱的历史
色谱--什么意思呢?
用颜色谱写—字面上色谱来自于希腊词根“chroma”和“graphein”。色谱最早由俄国植物学家Mikhail Tswett于1903年提出,当时,他用一根碳酸钙柱分离得到各种不同颜色的植物色素。之后,色谱发展成为分离和鉴定化合物的不可替代的实验室工具。尽管颜色已不再在分析过程中发挥作用,色谱的原理依然适用。
为什么使用色谱?关键在于它的分离作用。那么,分离在实验室中的起着什么重要作用呢?
在各种化学分析中,化学组分的分离是非常重要的。当试图鉴别一种未知的物质时,样品首先必须尽可能地分离成它的单组分化合物。然后根据对它的各个部位的鉴别再对未知化合物进行描述。但这并不意味着在分离和分析之后被分离的化学成分可以恢复。通常情况下,分析物是不能复原的。被分离的化合物用来与已知的标准物质对比。大多数的化学探索之中,清楚首先要寻找的化合物是重要的。
色谱的历史
chris
第20楼2006/09/12
History of Chromatography 色谱的历史
Chromatography -- what does it mean? 色谱-什么是色谱呢?
To write with colors -- literally translated from its Greek roots chroma and graphein , chromatography was first developed by the Russian botanist Mikhail Tswett in 1903 as he produced a colorful separation of plant pigments through a column of calcium carbonate. Chromatography has since developed into an invaluable laboratory tool for the separation and identification of compounds. Although color usually no longer plays a role in the process, the same principles of chromatography still apply.
用颜色进行记录--色谱这个词从字面上它来源于希腊字根chorma 和graphein.色谱最早于1903年由俄国植物学家Mikhail Tswett提出,当时他用碳酸钙柱子对植物色素进行了分离得到了不同的色带。之后,色谱发展成为实验室化合物分离和鉴定的不可替代的重要工具。虽然颜色在色谱分析过程中已不再发挥作用,但相同的原理依然在使用。
Why use chromatography? The key here is separation. But what is the importance of separation in the lab?为什么使用色谱呢?此处的关键在于分离,但在实验中分离的重要性是什么呢?
在各种化学分析中,化学成分的分离是至关重要的。当试图鉴别一种未知物质时,首先需要将试样尽可能的纯化为它的单一组分化合物。然后该未知化合物才能被它的特殊标识表征出来。但这并不意味着经过分离和分析过程后被分离的化学组分可以再生。通常情况下,被分析物是不可复原的。被分离的化合物与已知的标准物进行对比。在众多的化学测试中,知道哪个是首要寻找的化合物是非常重要的。
