第11楼2004/04/16
谢谢zzwbj抽出宝贵的时间与我共享这台仪器。
我查了他们的cryodetector资料,发表一下我的看法:
由于低温检测器是在接近于绝对零度(T≤0.4K)的条件下操作的,所以超导膜(superconducting film)中的电子以库柏对形式存在,库柏对的形成导致超导体能谱的改变,为了激发处于超导态的电子系统,至少要破坏一个库柏对,即至少需要一份等于库柏对结合能的能量。粒子撞击到超导膜上产生声子(phonons)(lattice vibrations),声子反过来破坏库柏对使其成为自由电子,这种电子穿隧道通过绝缘的氧化物层,形成可测的电流。因而cyrodetector检测器是根据粒子的能量来检测,对于分子的大小没有影响,更不存在检测器饱和的问题。
第12楼2004/04/16
或许原文对你来说更有帮助,发给你的邮件里有图示。
以下是原文:
How STJs work
Understanding STJs is not difficult. The detector is simply a junction between 2 superconducting films, separated by an ultra-thin oxide layer. Because the detector temperature is close to absolute zero,electrons exist in their superconductive stage as Cooper pairs.
Impinging particles generate phonons (lattice vibrations), which in turn back Cooper pairs into free electrons. Such electrons tunnel through the insulating oxide layer and thus cause a measurable current over the junction. The current is directly proportional to the (kinetic) energy deposited by the original impact. As the phonons diffuse, the Cooper pairs are restored and current ceases to flow. Clearly, every impact transfers energy to the junction and generates a current, hence the detector is 100% efficient. The kinetic energy of an accelerated ion is the same regardless of its mass, hence the current produced by the detector is also independent of its mass.
第13楼2004/04/16
对于你说的离子化效率低的问题,或许下面的原文对你能够解释的比较清楚:
The development of mass independent detection has two key implications in mass spectrometry. The first is realization of high sensitivity at very high mass, allowing development of new high mass applications in analysis of proteins, nucleic acids and polymers. The second is detection of ions with equal efficiency at all masses, reflecting the true relative ion yield. Complete spectra are viewed, rather than spectra biased toward low mass components. Relative ionization efficiencies of different compounds can be determined and more accurate quantitation within mixtures becomes possible.
