tina_sz
第21楼2007/08/22
对了,我拿到了原始检测条件。您再给看看哈
Molar Mass Measurements. Number-average molar mass (Mn), weight-average molar mass (Mw) and polydispersity index (Mw/Mn) of the resulting sample were determined by GPC, calibrated by polystyrene standards. The GPC system equipped with a Waters 2690D separations module, a Waters 2410 refractive index detector and a Shodex K802.5 & K805 in series. Chloroform was used as eluent at a flow rate of 1.0 mL/min. The temperatures of the columns and detector were 308K and 303K, respectively.
