闲鹤野云
第21楼2007/09/26
是的,可能英国和受过英国影响的中国香港有类似的表达方式。 Motor总感觉主要指电机的意思,我们的中文有摩托和马达可能就来自这里。汽车应该是Auto或Automobile. Show可以使用的,但Exhibition or Expo可能更正式。
poorlittle
第25楼2007/09/27
Then, it should be an acknowledgement slip. It can be translated as transaction receipt or just simply ATM receipt (see the 4th item under the section “When you use your HSBC Card at any ATM” in
http://www.hsbc.ae/1/2/ALL_SITE_PAGES/hsbc-amanah/amanah-charge-card/amanah-charge-card-security-tips_hidden
何当奇
第26楼2007/09/27
ATM receipt
I has had some english editions of ATM receipt
