方案下载应用领域 | 食品/农产品 |
检测样本 | 茶叶 |
检测项目 | 营养成分>风味品质分析 |
参考标准 | -- |
The Biochrom 30 Amino Acid Analyser is a well established analytical instrument for clinical diagnosis as its IVD approval allows the diagnosis of inborn errors of metabolism such as Phenylketonuria. This robust and reliable instrument is also capable of other types of applications far from the clinical market e.g. its usage in the food industry allows routine analysis of amino acid content in food and feedstuff in quality control laboratories. The Biochrom 30 can also be used for analysing rare, unusual amino acids or derived molecules for research purposes. In order to develop new methods for analysing molecules of interest in the scientific market, a new application has been developed to analyse the theanine content in green tea leaves. Theanine is a molecule derived from the amino acid glutamine and is usually found in tea (infusions of Camellia sinensis), and also in the basidiomycete mushroom Boletus badius. Because it can enter the brain, theanine has psychoactive properties. Theanine has been shown to reduce mental and physical stress, may produce feelings of relaxation, and improves cognition and mood when taken in combination with caffeine. These effects are believed to be caused by the ability of theanine to increase GABA production in the brain. The chemical structure of theanine allows it to be separated and detected in green tea samples using a Biochrom 30 Amino Acid Analyser.
毛细流孔隙仪在均热板毛细液芯性能测试的应用
赛默飞世尔FlashSamrt 元素分析仪对于煤焦油样品中CHNS/O的分析
布鲁克3D XRM 正品飞天茅台挑选记
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
