方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Phenylketonuria (PKU) is a genetic inborn error of metabolism, that is detectable during the first days of life with appropriate blood testing. The absence or deficiency of an enzyme that is responsible for processing the essential amino acid phenylalanine characterizes PKU. Without treatment, most infants with PKU develop mental retardation. Early detection of PKU can allow patient treatment to prevent mental retardation, as well as other associated problems. Treatment consists of a carefully-controlled pherestricted diet begun during the first days or weeks of life. Frequent blood monitoring of PKU patients is necessary, especially during infancy and early childhood when it is important to keep the blood phenylalanine levels at the safest level. Biochrom Amino Acid Analysers are widely used for the routine analysis of phenylalanine. Clinical laboratories have a continuous requirement for analyses of large numbers of samples. Rapid, accurate analysis is critical to meet the demand of the screening programmes. Improvements in peak resolution, accuracy, run times, and quantitation by using a dedicated instrument has enabled clinical laboratories to screen large numbers of samples per week. Using the Biochrom 30 Amino Acid Analyser phenylalanine can be rapidly and accurately quantified using norleucine as internal standard. The separation is carried out using a 20 cm x 4.6 mm high performance physiological column using buffer DII predominantly. The program enables 25 analyses to be performed a day. In addition tyrosine and homocystine are also well resolved thus enabling screening for the other metabolic diseases such as Tyronisis and Homocystinuria.
毛细流孔隙仪在均热板毛细液芯性能测试的应用
赛默飞世尔FlashSamrt 元素分析仪对于煤焦油样品中CHNS/O的分析
布鲁克3D XRM 正品飞天茅台挑选记
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
