方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Christensen T., Gooden D. M., Kung J. E., and Toone E. J. (2003) Additivity and the physical basis of multivalency effects: a thermodynamic investigation of the calcium EDTA interaction. J Am Chem Soc 125, 7357-7366. Abstract: To better understand the origin of multivalency effects in ligand binding, the binding of a series of mono-, bi-, tri- and tetravalent carboxylate ligands to Ca(II) was examined by isothermal titration calorimetry (ITC). The data are inconsistent with an entropic origin of enhanced affinity, but rather show that at least in this instance the multivalency effect is enthalpic in origin. Analysis of binding data using the Jencks model shows the addition of incremental carboxylate "ligands" produces an unfavorable interaction entropy that is more than offset by a strongly favorable interaction enthalpy. The most likely source of this interaction enthalpy is the relief of repulsive Coulombic interactions in the unbound state. The conformational entropy penalty arising from the restriction of flexible dihedrals is negligible, within experimental error. On the other hand, an enthalpic contribution from linker restriction contributes strongly to the overall thermodynamics of ligand binding. Together, these data suggest that enthalpic effects dominate ligand binding, and design strategies should seek to optimize these interactions. The incorporation of unfavorable interactions in the unbound ligand that are relieved during binding provides an important mechanism by which to enhance ligand affinities.
毛细流孔隙仪在均热板毛细液芯性能测试的应用
赛默飞世尔FlashSamrt 元素分析仪对于煤焦油样品中CHNS/O的分析
布鲁克3D XRM 正品飞天茅台挑选记
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
