方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Aluminum is a known neurotoxic agent and its neurotoxic effects may be due to its binding to DNA. However, the mechanism for the interaction of aluminum ions with DNA is not well understood. Here, we report the application of isothermal titration calorimetry (ITC), fluorescence spectroscopy, and UV spectroscopy to investigate the thermodynamics of the binding of aluminum ions to calf thymus DNA (CT DNA) under various pH and temperature conditions. The binding reaction is driven entirely by a large favorable entropy increase but with an unfavorable enthalpy increase in the pH range of 3.5–5.5 and at all temperatures examined. Aluminum ions show a strong and pH-dependent binding affinity to CT DNA, and a large positive molar heat capacity change for the binding, 1.57 kcal mol1 K1, demonstrates the burial of the polar surface of CT DNA upon groove binding. The fluorescence of ethidium bromide bound to CT DNA is quenched by aluminum ions in a dynamic way. Both Stern–Volmer quenching constant and the binding constant increase with the increase of the pH values, reaching a maximum at pH 4.5, and decline with further increasing the pH to 5.5. At pH 6.0 and 7.0, aluminum ions precipitate CT DNA completely and no binding of aluminum ions to CT DNA is observed by ITC. Combining the results from these three methods, we conclude that aluminum ions bind to CT DNA with high affinity through groove binding under aluminum toxicity pH conditions and precipitate CT DNA under physiological conditions.
毛细流孔隙仪在均热板毛细液芯性能测试的应用
赛默飞世尔FlashSamrt 元素分析仪对于煤焦油样品中CHNS/O的分析
布鲁克3D XRM 正品飞天茅台挑选记
麦奇克激光粒度仪 S3500系列
Rudolph AUTOPOL VI高精度旋光仪
Rudolph数字式密度计DDM 2911
全自动氨基酸分析仪 Biochrom 30+
纳米颗粒跟踪分析仪(生物纳米追踪)
流式影像仪 FlowCam®8400(cyano)
荷兰TE硫氮分析仪 XPLORER-V系列
自动液体处理系统
TURBISCAN 稳定性分析仪(多重光散射仪)
全自动比表面分析仪 (动态/静态法)
荷兰TE 总氯分析仪XPLORER TX
荷兰TE 总硫分析仪XPLORER TS
荷兰TE 总有机卤素分析仪XPLORER AOX
荷兰TE 总硫总氮分析仪XPLORER NS
