PR-water activity and bakery products
2006/11/22   下载量: 528
方案下载
应用领域
检测样本
检测项目
参考标准
Water activity is defined as the current volume and availability of “free” water in a sample and should not be directly compared with the water content (g water/ g substance). The water activity is given as the aw – value and ranges between 0 (absolute dryness) and 1 (condensed humidity). Only this component takes an active part in the exchange with the ambient humidity and can possibly form the ideal medium for microbiological growth on the surface which influences the microbiological stability. The water activity also has an important effect on the chemical reactions in food.
方案下载
上一篇 水分活度在制药上的应用-晶体
下一篇 PR-water activity and dehydration
文献贡献者
相关方案
当前位置: 大昌华嘉 方案 PR-water activity and bakery products
