方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Proteins are not only important nutrient source for human society, but also play a crucial role in devising various protein-based therapies for many terminal diseases [1]. Therapeutic proteins are usually administrated by the parenteral route. Their dosage form needs to be formulated either as a solution, a suspension or a reconstituted solid dosage form. Therefore, for protein therapeutic products development, protein hydrodynamic behavior in solutions or suspensions is proven to be much more relevant than its isolated and denatured characteristics revealed via advanced microscopy tech-niques. This can be manifested as either protein size monitoring for QC purposes of its purification processes or their charge property control for optimized formulation stability. The critical requirements for these applications often include, but not limited to, non-invasive (in-situ) nature of measurement techniques, easy-of-use and rapidness of tests. Laser light scattering techniques satisfy these require-ments and provide vital access to the hydrodynamic characteris-tics of biological macromolecules in their native application envi-ronments [2]. Their diffusive displacement (“Brownian” motion) can be quantified as diffusion coefficient with a dynamic light scattering measurement. In turn, their hydrodynamic radius can be calculated. When placed under an electric filed, the charged proteins undergo a uniform translational movement, the so-called electrophoretic motion or electrophoresis. It results in a Doppler phase/frequency shift of the light signal scattered from the moving proteins, which can be quantitatively evaluated with a carefully designed electrophoretic light scattering experiment. From the measured phase/frequency shift, the charge status of proteins can be extracted.
NanoBrook产品应用-12-ZetaPALS
NanoBrook产品应用-16-ZetaPALS
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
