方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
文献名: Preparation and application of magnetic graphene oxide coated with a modified chitosan pH-sensitive hydrogel: an efficient biocompatible adsorbent for catechin 作者: Hassan Sereshti, Soheila Samadi, Shohreh Asgaria and Maryam Karimia Department of Chemistry, Faculty of Science, University of Tehran, P.O. Box 14155-64555, Tehran, Iran 摘要:In the present study, graft copolymerization of acrylic acid sodium salt (AAS) onto O-carboxymethyl chitosan (O-CMCs) produced a highly hydrophilic and pH-sensitive hydrogel polymer of O-CMCs-g-AAS with a porous surface morphology. The grafted chitosan copolymer was coated on magnetic graphene oxide (MGO) and characterized with TEM, SEM, and FT-IR techniques. The prepared nanocomposite, [O-CMCs-g-AAS]/MGO, was successfully used as an efficient and biocompatible adsorbent in magnetic solid phase extraction (MSPE) coupled with gas chromatography-mass spectrometry (GC-MS) for preconcentration and determination of catechin in tea beverages. The influence of the main parameters affecting the quality of the coating process was investigated and optimized using a response surface methodology. Under the optimum conditions, the adsorbent demonstrated a satisfactory adsorption capacity (27 mg g?1) for catechin and good linearity in the range of 0.005–5 μg mL?1 with a determination coefficient (R2) of 0.9987. The limit of detection (LOD) and limit of quantification (LOQ) were 0.001 and 0.003 μg mL?1, respectively. The relative standard deviation (RSD) was 4.1% (n = 5, C = 0.5 μg mL?1).
NanoBrook 173Plus多角度粒度分析仪
布鲁克海文高灵敏Zeta电位分析仪ZetaPALS
布鲁克海文Zeta电位分析仪 ZetaPlus
布鲁克海文(Brookhaven)多角度粒度分析仪173Pl
EyeTech 激光光阻粒度粒形分析仪
布鲁克海文 多角度粒度及高灵敏Zeta电位分析仪 Omni
布鲁克海文高灵敏度Zeta电位及粒度分析仪90Plus PALS
布鲁克海文Zeta电位及激光粒度分析仪90Plus Zeta
布鲁克海文激光粒度仪90Plus
布鲁克海文广角动/静态激光散射仪BI-200SM
布鲁克海文多角度激光光散射(绝对分子量测定)仪MwA
布鲁克海文圆盘式离心/沉降粒度仪
布鲁克海文高灵敏在线粒度分析仪NanoDLS
布鲁克海文ACOS实时在线粒度检测系统
高浓度粒度分析仪
