方案下载应用领域 | 石油/化工 |
检测样本 | 油品 |
检测项目 | |
参考标准 | 暂无 |
Gilson Semi‐Preparative HPLC System ? GX‐281 Liquid Handler ? Direct Injection Module ? 100 μL total sample loop injection ? 321 Pumping System with H2 Pump Heads ? 152 UV/VIS Detector ? 254 nm; sensitivity of 0.01 ? PrepELS™II (Evaporative Light Scattering) Detector ? Drift tube: 25?C ? Spray chamber: 0?C ? Full‐scale setting: 5 V Nitrogen flow: 50 psi VALVEMATE® II 2 positions; 6 port valve Phenomenex Security Guard Semi‐Prep Cartridge (10 x 10 mm) with a 0.20 μm in‐line filter Whatman Partisil Silica 10 μm column (9.4 x 500 mm) Solvents for sample preparation: Hexane (Figure 1) and hexane: dichloromethane (DCM): methanol (1:1:1)
(GPC)凝胶色谱法清洁食用油中的塑料添加剂(R)-(+)-1-苄基丙三醇
(GPC)凝胶色谱法清洁食用油中的塑料添加剂1-乙酸甘油酯
(GPC)凝胶色谱法清洁食用油中的塑料添加剂3-甲基-1,2-环戊二酮
