方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
In order for biodiesel to be used as a motor fuel or blended with petroleum diesel, it must conform to standard specifications (ASTM D 6751 or EN-14214). There are standard GC methods in use today to determine if biodiesel conforms to the standard specifications, one of which is EN-14103, used to determine the ester and linoleic acid methyl ester content. Other methods include EN-14105 / ASTM D 6584 (free and total glycerine and mono, di and triglyceride content) and EN-14110 (residual methanol). Bruker has designed GC solutions for each of these standard methods. This paper describes work conducted on the Bruker 450 gas chromatograph to analyze biodiesel (B-100) in accordance with EN-14103. EN-14103 is used to verify that the ester content of Fatty Acid Methyl Esters (FAME) is greater than 90 % (m/m) and that the linolenic acid content is between 1 % (m/m) and 15 % (m/m) consistent with the EN-14214 specifications. This method is suitable for FAME which contains methyl esters between C14 and C24.
4D-脂质组学高通量工作流程
PASEF应用于COVID-19的高通量定量大规模血浆蛋白质组学研究
布鲁克neofleX™ MALDI-TOF/TOF 空间成像质谱仪
布鲁克 timsTOF Ultra 2 捕集离子淌度质谱系统
布鲁克 timsTOF HT 捕集离子淌度质谱仪
PepSep™ 色谱柱
布鲁克scimaX™磁共振质谱仪
布鲁克 timsTOF fleX with MALDI-2
布鲁克timsTOF Pro 2 捕集离子淌度质谱
布鲁克 timsTOF fleX 组学和成像质谱系统
布鲁克ultrafleXtreme MALDI TOF/TOF质谱
布鲁克 timsTOF MALDI PharmaPulse
autoflex maX MALDI-TOF(TOF) 质谱
布鲁克solariX磁共振质谱仪
布鲁克 maXis II 飞行时间串联质谱
布鲁克 compact 高分辨飞行时间质谱
布鲁克impact II四极杆飞行时间质谱仪
