方案下载应用领域 | 食品/农产品 |
检测样本 | 蔬菜 |
检测项目 | |
参考标准 | / |
非监督的MS/MS二级谱图的相似性代谢轮廓图分析快速找出了17种以前未曾分析出的代谢物,并发现了羟基肉桂酰胺在AtACT-AtdTX18超表达路径中的合成机制。
Solanum tuberosum (potato) wildtype and overexpression lines with an enhanced Phytophtora infestans resistance were analysed for their metabolic response to simulated herbivory.
• Using the data acquired with Bruker LC-ESI-Q-TOF MS and MS/MS instrumentation and methods, the MetaboScape software provided an efficient platform for the straightforward linkage of structural similarities and metabolite abundances. We used various statistical tools (PCA, t-test) in MetaboScape to focus on relevant features. The unsupervised MS/MS similarity metabolite profiling approach enabled a rapid annotation of 17 metabolites which were previously unknown in our analyses.
• The common abundance patterns together with common MS/MS patterns pointed to an overflow of the hydroxycinnamic acid amide biosynthesis in the AtACT-AtDTX18 overexpression lines. This is in perfect accordance with the function of the overexpressed enzyme AtACT that is responsible for the biosynthesis of four HCAAs. The increase of the many other HCAAs might be a metabolic side effect of the plant to compensate for this overflow and to bypass toxic effects for the cell. MetaboScape was very valuable for easy data processing, the annotation of many formerly unknown compounds and an intuitive visualization of metabolic changes.
4D-脂质组学高通量工作流程
PASEF应用于COVID-19的高通量定量大规模血浆蛋白质组学研究
布鲁克neofleX™ MALDI-TOF/TOF 空间成像质谱仪
布鲁克 timsTOF Ultra 2 捕集离子淌度质谱系统
布鲁克 timsTOF HT 捕集离子淌度质谱仪
PepSep™ 色谱柱
布鲁克scimaX™磁共振质谱仪
布鲁克 timsTOF fleX with MALDI-2
布鲁克timsTOF Pro 2 捕集离子淌度质谱
布鲁克 timsTOF fleX 组学和成像质谱系统
布鲁克ultrafleXtreme MALDI TOF/TOF质谱
布鲁克 timsTOF MALDI PharmaPulse
autoflex maX MALDI-TOF(TOF) 质谱
布鲁克solariX磁共振质谱仪
布鲁克 maXis II 飞行时间串联质谱
布鲁克 compact 高分辨飞行时间质谱
布鲁克impact II四极杆飞行时间质谱仪
