海洋会向大气释放巨量的气溶胶。它们选择性地吸收太阳辐射,参与云团的成核,进而影响全球的气候和环境。为了更好地理解气溶胶的作用,科学家需要有合适的工具,对单个气溶胶颗粒进行亚微米级别的表征。最基本的一点是,科学家需要知道这些气溶胶是以什么状态存在的,气态、液态、抑或是固态?
通过牛津仪器MFP3D原子力显微镜,爱荷华大学的科学家研究了不同种类的海洋气溶胶,其中包含无机盐颗粒、有机酸颗粒以及糖类颗粒。
他们将不同种类气溶胶沉积在硅片上,使用轻敲模式进行扫描。MFP3D原子力显微镜的高分辨率能够精确地测定气溶胶的形貌参数。测试在MFP3D配套的湿度样品腔中进行,可以在测试过程中保持已知、稳定的湿度环境。形貌测试之后,科学家通过AFM力曲线测量了颗粒的粘弹性性质,力曲线所提供的纳米力学信息可以用确定这些颗粒的物态。
AFM结果表明,颗粒的形貌和物态之间存在相关性。因此,仅仅通过形貌测试,就可以半定量地辨别颗粒的状态,这提供了一种快速鉴别气溶胶颗粒的新方法。
Measurements of individual sea spray aerosol particles showed correlations between viscoelastic properties, morphology, and phase state that could lead to quicker and simpler assessment of particle phase state.
Sea spray is one of many atmospheric aerosols that impact climate and the environment by absorbing solar radiation, nucleating clouds, and other mechanisms. To model these effects more accurately, tools capable of characterizing individual, sub-micrometer-sized aerosol particles are needed. In particular, techniques to assess a particle’s phase state—whether it is liquid, semisolid, or solid—would be valuable but remain rare.
Towards this goal, University of Iowa researchers examined several different components of sea spray aerosol including inorganic salts, organic acids, and saccharides with an AFM methodology. Nanomechanical measurements revealed correlations between a component’s viscoelastic response distance (VRD), relative indentation depth (RID), and phase state. Morphology imaging further showed that particle aspect ratio could be directly linked to VRD and RID, and thus to phase state.
The results therefore indicate that phase state can be semi-quantitatively evaluated by morphology imaging alone, without prior knowledge of chemical composition. This ability provides a new strategy for rapidly assessing aerosol components that may prove useful for a range of atmospheric studies.
MFP-3D
AFM measurements were made on aerosol particles deposited on silicon wafers. Specifically, components comprised inorganic salts (NaCl and MgSO4), organic acids (malonic, glutaric, azelaic, and palmitic acids), saccharides (glucose, sucrose, and raffinose), lipopolysaccharide from Escherichia coli, and inorganic–organic binary chemical mixtures (NaCl–malonic acid, NaCl–glucose, and MgSO4–glucose). Force curve measurements and tapping mode imaging of topography and phase were performed on the MFP-3D AFM. MFP-3Ds provide the highest performance and lowest-noise force measurements at a low price point. With the Humidity Sensing Cell, a constant relative humidity of ~20% was maintained throughout the experiments.
Citation: K. Ray, H. Lee, M. Gutierrez et al., Correlating 3D morphology, phase state and viscoelastic properties of individual substrate-deposited particles. Anal. Chem. 91, 7621 (2019).
https://doi.org/10.1021/acs.analchem.9b00333
Note: The data shown here are reused under fair use from the original article, which can be accessed through the article link above.
新品发布 | 牛津仪器Xplore EDS探测器全新产品正式发布
全新体验!欢迎关注牛津仪器一站式客户互动平台
快速响应,专业耐心,牛津仪器Oi Service高效助力用户平台取得成功——访北大生命科学学院公共仪器中心覃思颖
响应设备更新政策 | 2024 WITec多功能联用共聚焦拉曼系统选型指南
牛津EMCCD探测器iXon Ultra 897
牛津EMCCD探测器iXon 888
日本电子JED能谱元素分析系统 AZtecTEM
透射电镜元素分析系统 牛津仪器能谱仪Xplore TEM
透射电镜元素分析系统 牛津仪器能谱仪UltimMax TLE
透射电镜元素分析系统 牛津仪器能谱仪UltimMax TEM
台式共聚焦显微镜BC43牛津仪器ANDOR
牛津仪器原子力显微镜 Cypher VRS1250
扫描电镜微量元素分析系统 牛津仪器波谱仪AZtecWave
Sona sCMOS 生命科学显微相机平台
用于天文学和物理科学的超灵敏背照式sCMOS相机
波长色散谱仪
电镜专用微区结构分析---牛津仪器全能型 S2 EBSD
牛津仪器Proteox5mK 稀释制冷机
牛津仪器快速扫描电容显微镜(SCM)
