方案下载应用领域 | 钢铁/金属 |
检测样本 | |
检测项目 | |
参考标准 | 无 |
The exploration of new metallic systems for high-temperature applications is an important challenge in today’s materials science.
A high entropy alloy, Al8Co17Cr17Cu8Fe17Ni33, has been developed from an equiatomic AlCoCrCuFeNi alloy. Due to its promising properties, such as high corrosion and oxidation resistance and high thermal stability, it is a candidate for various applications at elevated temperature as, e.g., furnace parts, tools and moulds. The exploration of new metallic systems for high-temperature applications is an important challenge in today’s materials science.
However, an increase in the strength of this alloy is desirable and requires further optimization. In order to improve these mechanical properties, knowledge of the microstructure is necessary. Therefore, Al8Co17Cr17Cu8Fe17Ni33 high entropy alloy has been studied by means of energy-dispersive X-ray spectroscopy (EDS) and electron backscatter diffraction (EBSD).
一文了解 EDS 能谱技术发展历程
应用分享|红外辐射全无惧——牛津仪器新型高温 EDS / EBSD 助力原位分析
AZtecBattery 在锂离子电池清洁度检测中的应用
牛津EMCCD探测器iXon Ultra 897
牛津EMCCD探测器iXon 888
日本电子JED能谱元素分析系统 AZtecTEM
透射电镜元素分析系统 牛津仪器能谱仪Xplore TEM
透射电镜元素分析系统 牛津仪器能谱仪UltimMax TLE
透射电镜元素分析系统 牛津仪器能谱仪UltimMax TEM
台式共聚焦显微镜BC43牛津仪器ANDOR
牛津仪器原子力显微镜 Cypher VRS1250
扫描电镜微量元素分析系统 牛津仪器波谱仪AZtecWave
Sona sCMOS 生命科学显微相机平台
用于天文学和物理科学的超灵敏背照式sCMOS相机
波长色散谱仪
电镜专用微区结构分析---牛津仪器全能型 S2 EBSD
牛津仪器Proteox5mK 稀释制冷机
牛津仪器快速扫描电容显微镜(SCM)
