Transmission Kikuchi Diffraction (TKD) of Metals
2020/06/15   下载量: 0
方案下载
应用领域 钢铁/金属
检测样本 其他
检测项目 理化分析>晶体结构, 其他, 形貌观察分析
参考标准
Transmission Kikuchi diffraction (TKD) is a relatively recent development in EBSD that allows high resolution analysis of electron transparent samples. Most applications in the literature have used TKD for targeted measurements of relatively small areas, on samples where conventional EBSD struggles to deliver the required resolution [1]. These samples are typically nanocrystalline metals and alloys, although increasingly the technique is also being used to characterise highly
方案下载
配置单
方案详情
metals and alloys, although increasingly the technique is also being used to characterise highly.
上一篇 一文了解 EDS 能谱技术发展历程
下一篇 Sub-10nm-EDS-analysis-in-the-SEM
文献贡献者
相关方案
当前位置: 牛津仪器 方案 Transmission Kikuchi Diffraction (TKD) of Metals
