使用变色龙7色谱数据系统遵循CFR第11部分
2018/06/08   下载量: 8
方案下载
应用领域 其他
检测样本 其他
检测项目
参考标准 CFR
21 CFR Part 11 established requirements to ensure that electronic records and electronic signatures are trustworthy, reliable and equivalent substitutes for paper records and traditional handwritten signatures. Commonly known as Part 11, it requires Food and Drug Administration (FDA)-regulated industries, including medical device manufacturers, drug makers, biotech companies and biologics developers, to have validation documentation and implement controls such as audit trails and electronic signatures. The requirements apply to software and systems involved in processing electronic data that are required to be maintained by or used to demonstrate compliance with FDA predicate rules.
方案下载
配置单
方案详情
Compliance with regulatory requirements is critical for a business. It is often
regarded as something that can add significant cost to the company but with
the acquisition of a chromatography data system (CDS) that provides all of the
necessary functionality built-in to one package, that is easy to use, the effort
required to achieve compliance with 21 CFR Part 11 is significantly reduced.
下一篇 采用 Thermo Scienti?c iCAP RQ ICP-MS 分析 药物产品中杂质元素
文献贡献者
相关方案
当前位置: 赛默飞色谱与质谱 方案 使用变色龙7色谱数据系统遵循CFR第11部分
