方案下载应用领域 | 农/林/牧/渔 |
检测样本 | 饲料 |
检测项目 | 理化分析>其他 |
参考标准 | 无 |
毛细管电泳(CE)技术具有分离效率高、分析速度快、受基质干扰小、试剂样品消耗少且对环境友好等优点,在阳离子分析领域潜力巨大。该法可用于测定各种饲料、复合饲料、饲料、预混料、饲料添加剂和植物、动物、矿物原料的无机阳离子(钾、钠、镁、钙离子)的质量浓度。检测波长在254nm或267nm处,该测定不受其它无机阳离子(Ba, Li, Sr, Mn, Fe)的存在所影响。
The method 1 is used for the determination of the mass fraction of total inorganic cations (ammonium potassium, sodium, magnesium, calcium) in all types of feedstuffs, compound feeds, fodders, premixes, fodder additives, and feed raw materials (of plant, animal, and mineral origin) by capillary electrophoresis.
The measurement method is based on capillary zone electrophoresis with indirect UV detection at the wavelength of 254 or 267 nm.
The measurement range for the components is 0.01–40% for the sample weight of 100 mg.
The determination is not hindered by the presence of other inorganic cations (Ba, Li, Sr, Mn, Fe) in the concentrations that are typical for this type of samples.
The CAPEL capillary electrophoresis system is used in measurements. Data acquisition, collection, processing and output are performed using a personal computer running under WINDOWS® XP/7/8/10 operating system with installed dedicated software package ELFORUN.
Lumex Instruments set, order No 0300001912.
BGE: benzimidazole, with tartaric acid and 18-crown-6
Capillary: Leff/ Ltot 50/60 cm, ID 75 µm
Injection: 150 mbar x sec Voltage: 25 kV Temperature: + 20 ОС Detection: 267 nm
CAPEL毛细管电泳测定大麻及大麻原料中14种大麻素
依据2020年版药典使用 LUMEX毛细管电泳Capel分析佐米曲普坦手性异构体
精对苯二甲酸中4-羧基苯甲醛和对甲苯酸的测定(LUEMX毛细管电泳法)
