方案下载应用领域 | 农/林/牧/渔 |
检测样本 | 饲料 |
检测项目 | 理化分析>酚酸和有机酸 |
参考标准 | 无 |
毛细管电泳(CE)技术具有分离效率高、分析速度快、受基质干扰小、试剂样品消耗少且对环境友好等优点。采用毛细管电泳法可以测定青贮饲料和青贮饲料中草酸、甲酸、富马酸、琥珀酸、苹果酸、柠檬酸、乙酸、丙酸、乳酸、苯甲酸、山梨酸、丁酸的质量浓度。该法的检测波长为190nm。
DETERMINATION OF ORGANIC ACIDS
IN FEEDSTUFFS AND FODDER ADDITIVES
Lumex Method M 04-74-2012
The method1 is used for the determination of the mass concentration of oxalic, formic, fumaric, succinic, malic, citric, acetic, propionic, lactic, benzoic, sorbic, butyric acids in fodder additives and butyric acid in silage and haylage by capillary electrophoresis.
For the determination of ascorbic acid and its salts in food additives and fodder additives use the method
М 04-86-2016 (Lumex Instruments set, order No 0300002717).
The measurement method is based on capillary zone electrophoresis with direct UV detection at the wavelength of 190 nm.
The measurement ranges for the components are presented in the table below.
Compound | Measurement range, % | Compound | Measurement range, % |
Acetic acid | 0.1–80 | Lactic acid | 0.12–80 |
Benzoic acid | 0.005–50 | Malic acid | 0.05–80 |
Butyric acid | 0.05–50 | Oxalic acid | 0.03–10 |
Citric acid | 0.05–80 | Propionic acid | 0.1–80 |
Formic acid | 0.15–80 | Sorbic acid | 0.025–50 |
Fumaric acid | 0.005–80 | Succinic acid | 0.05–80 |
Inorganic anions (chloride, sulfate, nitrate and phosphate) in concentrations, typical for the mentioned samples do not deteriorate organic acids determination.
The CAPEL capillary electrophoresis system is used in measurements. Data acquisition, collection, processing and output are performed using a personal computer running under WINDOWS® XP/7/8/10 operating system with installed dedicated software package ELFORUN.
Lumex Instruments set, order No 0300001897.
BGE: phosphate, with CTAB
Capillary: Leff/ Ltot 40/50 cm, ID 50 µm
Injection: 150 mbar x sec
Voltage: – 17 kV
Temperature: + 20℃
Detection: 190 nm
CAPEL毛细管电泳测定大麻及大麻原料中14种大麻素
依据2020年版药典使用 LUMEX毛细管电泳Capel分析佐米曲普坦手性异构体
精对苯二甲酸中4-羧基苯甲醛和对甲苯酸的测定(LUEMX毛细管电泳法)
