方案下载应用领域 | 医疗/卫生 |
检测样本 | 其他 |
检测项目 | |
参考标准 | - |
Automated protocols to facilitate sample preparation in lipidomics have been previously developed. The aim of these procedures is to minimize human errors resulting from handling large quantities of samples, and to decrease the amount of time spent in sample preparation. This application note describes the semi-automated extraction of phospholipids and sphingolipids from human plasma using the Agilent Bravo Automated Liquid Handling Platform. This procedure includes the transfer of the starting material (plasma is usually delivered in 1.5-mL tubes) to 96-well plates, which can be either stored or used for the lipid extraction. In the latter case, a butanol/methanol (BuMe) mixture is added to the sample. Although the samples are still transferred manually to the sonicator and the centrifuge during the lipid extraction procedure, the reported protocol allows a high number of samples to be processed uniformly, decreasing the sample preparation time and yielding high reproducibility according to the results obtained after analysis of the extracted lipids with an Agilent UHPLC/MS/MS system.
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
使用配备氦气节省模块以进行载气 切换的 Agilent 8850 气相色谱系统 分析香草提取物的方法转换
应用 QuEChERS 方法结合 Agilent 7000 系列三重四极杆气质联用仪测定甜菜中 的多农药残留
CrossLab企业资产管理服务
Agilent 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
