方案下载应用领域 | 石油/化工 |
检测样本 | 合成纤维 |
检测项目 | |
参考标准 | - |
Release agents are applied as a liquid that forms a thin film coating to aid removal of carbon-fiber-reinforced polymer (CFRP) parts from a mold or peel ply. This process, however, leads to inevitable contact transfer, causing release agent to remain on the part or repair. Before painting or bonding of the CFRP component to other structures, proper post-treatment to remove vaporizable components of the release agent is required. Improper or inadequate post-treatment leads directly to reduction of bond strength of joined parts or topcoat paint adhesion. The complexity of CFRP systems requires the use of new nondestructive analysis technologies such as FTIR spectroscopy, for the analysis of the surface matrix of the material. The primary objective of this application note is to demonstrate that FTIR spectroscopy can nondestructively measure the level of release agent on a carbon fiber epoxy system before bonding. The analysis uses an Agilent 4100 ExoScan FTIR. This handheld spectrometer enables in-situ inspection during manufacturing, in-service, or repair environments, or ex-situ in a laboratory. The analysis is accomplished in less than 1 minute and does not require any sample pretreatment. This work was part of a joint project commissioned by the European Union entitled ENCOMB (extended nondestructive testing of composite bonds) [1].
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
