方案下载应用领域 | 石油/化工 |
检测样本 | 柴油 |
检测项目 | |
参考标准 | - |
Biodiesel is usually an effective blending component for petroleum-based diesel fuel. However, biodiesel-mixed diesel fuel can be a problem in engines designed for only petroleum-based diesel. Also, blended biodiesel can promote biological growth and increase instability of the diesel fuel resulting from the buildup of oxidation products. Thus, biodiesel-blended diesel fuel can cause issues in stationary standby diesel engines, such as those used in nuclear plants. The ASTM D7806-12 test method was developed for the determination of biodiesel (FAME) content in diesel fuel oils in the concentration range from 1 to 30% by volume. In this application note, we demonstrate the applicability of any of the three Agilent FTIR spectrometers (4500, 5500, and Cary 630) to this method. The Agilent systems can be used for: ? Quality control in the production and distribution of diesel fuel and biodiesel blends containing FAME ? Routine checks of incoming blended diesel fuels from a distributor The Agilent FTIR spectrometers demonstrated excellent repeatability (X ± 0.02%), better than X ± 0.3% as defined in the ASTM D7806-12 method, where X is the biodiesel concentration. Whether the biodiesel content of a blended fuel needs to be tested in the lab or in the field, the three Agilent spectrometers provide an easy, accurate, and portable means for measurement. This gives analysts the flexibility to choose the best instrument based on their routine analysis requirements.
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
