方案下载应用领域 | 钢铁/金属 |
检测样本 | 钢材 |
检测项目 | |
参考标准 | - |
Monitoring and controlling the level of trace element impurities in metals and alloys is important, as impurities can affect the properties of the metal and may degrade the functionality of the finished component. ICP-OES is commonly used for the routine measurement of trace elements in metal samples because of its multi-element capability and tolerance of the high matrix level present in metal sample digests. However, the development of high purity metals and higher-performance alloys requires stricter control of a wider range of trace elements at lower concentrations, so a technique with lower detection limits than ICP-OES is required. ICP-MS offers low detection limits for the elements of interest, but the technique has not previously been considered suitable for the analysis of high matrix samples such as metal digests. For example, conventional ICP-MS instruments may suffer from signal suppression and/or long-term signal drift due to matrix deposition on the interface cones, which affects the signal stability and the accuracy of the analytical results. To overcome this limitation, Agilent’s Ultra High Matrix Introduction (UHMI) aerosol dilution technology has been developed to allow the
Agilent Vaya 手持式拉曼光谱仪的 不透明容器分析能力
使用 Agilent 8890 气相色谱和 TCD/FID 系统分析氢气中的氦气、 氩气、氮气和烃类杂质
使用 Agilent InfinityLab 在线液相色谱 系统实现对流动化学反应器中反应过 程的实时监测
CrossLab企业资产管理服务
Agilent GC 8890 气相色谱系统
Agilent Cary 3500 紫外可见分光光度计
Agilent Resolve 手持拉曼系统
Agilent TRS100 激光拉曼系统
Agilent 1290 Infinity II 二维液相色谱解决方案
Agilent 1290 Infinity II 液相色谱系统
Agilent 1260 Infinity II 液相色谱系统
Agilent 7900 电感耦合等离子体质谱仪
Agilent Bravo 自动液体处理平台
Agilent 7010C 三重四极杆气质联用系统
Agilent 7000E 三重四极杆气质联用系统
Agilent 5977C GC/MSD 单四极杆气质联用仪
Agilent 1290 Infinity II 高通量系统
Agilent 1290 Infinity II 方法转移系统
